Home » Archived » M2M (model-to-model transformation) » [ATL] An internal error occurred during: "Launching".
[ATL] An internal error occurred during: "Launching". [message #43201] Wed, 30 May 2007 18:44 Go to next message
Originally posted by: aquamp.gmail.com
hello,
I am new to ATL and trying a transformation using the same ource and
target metamodel (AADL by uri:http:///AADL/core, both source and target
models AADL)
It was working for a few rules, as I added another the Launching error
popped up. I reverted back to the state where it was working but it
continued to throw the error. Also tried with the option 'Continue
execution after errors in run mode'.
I have gone back to the point where there is a single rule and a very
simple input file but does not help. In ATL debugger, main thread
terminates at once.
Can someone help me get thru this? Thanks in advance for your time.
The ATL console had printed the following socketexception once but has
been displaying "Dumping ASM to /AADL2AADL/AADL2AADL1.asm" for some time
now.
java.net.SocketException: Software caused connection abort: socket write
error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(Unknown Source)
at java.net.SocketOutputStream.write(Unknown Source)
at java.io.BufferedOutputStream.flushBuffer(Unknown Source)
at java.io.BufferedOutputStream.flush(Unknown Source)
at java.io.DataOutputStream.flush(Unknown Source)
org.atl.engine.vm.adwp.ADWPDebugger.realSendCommand(ADWPDebu gger.java:34)
at org.atl.engine.vm.adwp.ADWPDebugger.sendCommand(ADWPDebugger .java:23)
org.atl.eclipse.adt.debug.core.AtlDebugTarget.breakpointChan ged(AtlDebugTarget.java:291)
org.eclipse.debug.internal.core.BreakpointManager$Breakpoint Notifier.run(BreakpointManager.java:801)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.debug.internal.core.BreakpointManager$Breakpoint Notifier.notify(BreakpointManager.java:821)
org.eclipse.debug.internal.core.BreakpointManager.fireUpdate (BreakpointManager.java:735)
org.eclipse.debug.internal.core.BreakpointManager.access$1(B reakpointManager.java:725)
org.eclipse.debug.internal.core.BreakpointManager$Breakpoint ManagerVisitor.update(BreakpointManager.java:605)
org.eclipse.debug.internal.core.BreakpointManager.resourceCh anged(BreakpointManager.java:541)
org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:280)
org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:274)
org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:148)
org.eclipse.core.internal.resources.Workspace.broadcastBuild Event(Workspace.java:240)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:146)
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:208)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
----- and the exception: java.lang.NullPointerException
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:247)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:168)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:145)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:121)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .launch(AtlLaunchConfigurationDelegate.java:97)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:754)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:944)
Re: [ATL] An internal error occurred during: "Launching". [message #43236 is a reply to message #43201] Wed, 30 May 2007 19:13 Go to previous messageGo to next message
The SocketException you list is caused by the debugger. This should not
appear in run mode.
Moreover, it seems to be caused by the transmission of breakpoint
information. Could you please remove all breakpoints, and try launching
in debug mode again?
Frédéric Jouault
aquamp wrote:
> hello,
> models AADL)
> execution after errors in run mode'. I have gone back to the point
> where there is a single rule and a very simple input file but does not
> help. In ATL debugger, main thread terminates at once.
> now.
> error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [ATL] An internal error occurred during: "Launching". [message #43266 is a reply to message #43236] Wed, 30 May 2007 19:26 Go to previous messageGo to next message
Thank you for the quick reply. I tried debugging after removing
breakpoints, still get the same error. The console prints:
****** BEGIN Stack Trace
exception:
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:26 5)
at org.atl.engine.vm.ASMOperation.exec(ASMOperation.java:155)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 60)
at org.atl.engine.vm.nativelib.ASMOclAny.invoke(ASMOclAny.java: 50)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:21 4)
at org.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:276)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:1 36)
at org.atl.eclipse.engine.AtlLauncher.launch(AtlLauncher.java:9 4)
at org.atl.eclipse.engine.AtlLauncher.debug(AtlLauncher.java:84 )
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .runAtlLauncher(AtlLaunchConfigurationDelegate.java:228)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate .access$0(AtlLaunchConfigurationDelegate.java:107)
org.atl.eclipse.adt.launching.AtlLaunchConfigurationDelegate $1.run(AtlLaunchConfigurationDelegate.java:85)
A.main() : ??#22 null
local variables = {self=AADL2AADL1 : ASMModule}
local stack = []
A.__matcher__() : ??#5 null
local stack = []
A.__matchsystemImpl() : ??#2 null
local stack = []
****** END Stack Trace
Trying to continue execution despite the error.
I also tried naming source and target metamodels different, thought they
point to the same metamodel by uri, does not help.
Re: [ATL] An internal error occurred during: "Launching". [message #43299 is a reply to message #43266] Wed, 30 May 2007 20:01 Go to previous messageGo to next message
We now have the stack trace from the actual error :-).
It seems that rule systemImpl cannot be matched. This is very likely to
be caused by a launch configuration issue:
- the metamodel name used in the launch config must be the same as the
name declared in the transformation header (this is case sensitive),
- you may have assigned the wrong metamodel (e.g., .ecore file) to your
metamodel in the launch config.
Can you please double check these?
Frédéric Jouault
> at
> at
> at
> at
> at
> at
> local stack = []
> local stack = []
> local stack = []
Re: [ATL] An internal error occurred during: "Launching". [message #43330 is a reply to message #43299] Wed, 30 May 2007 20:29 Go to previous message
You are right, I missed the case sensitive part of metamodel in systemImpl
rule.
THANKS A TON :)
Previous Topic:[ATL] How to create a new model element that contains a text.
Next Topic:Cannot call a CalledRule on a Seqeunce()
Current Time: Thu Jul 17 20:36:29 EDT 2025
Powered by FUDForum. Page generated in 0.08139 seconds
