Home » Language IDEs » Java Development Tools (JDT) » IJavaProject - How do I determine build status (i.e., OK, warnings, errors)?
IJavaProject - How do I determine build status (i.e., OK, warnings, errors)? [message #43200] Thu, 29 May 2003 12:48 Go to next message
Originally posted by: hallorant.yahoo.com
Within jtd.core, given a IJavaProject, how can I determine the Java
compilation status? I am within a builder (that occurs after the Java
builder) and I want to know if the IJavaProject is OK, has warnings, or
has errors.
Nothing is jumping out at me in the jdt.core API (now I'm starting to
look into the jdt.core source code), any pointers would help...thanks!
Tim Halloran
Carnegie Mellon University
Re: IJavaProject - How do I determine build status (i.e., OK, warnings, errors)? [message #43622 is a reply to message #43200] Thu, 29 May 2003 16:29 Go to previous messageGo to next message
> has errors.
> Tim Halloran
I appear to have solved my problem. The solution was to examine the markers
attached to the IProject related to the IJavaProject. My code is below:
* Check if the compilation state of an {@link IJavaProject} has errors.
* @param javaProject the {@link IJavaProject} to check for errors
* @return <code>true</code> if the project has compilation errors (or has
* never been built), <code>false</code> otherwise
* @throws CoreException if we have trouble getting the project's
* {@link IMarker} list
private boolean hasCompilationErrors(IJavaProject javaProject)
throws CoreException {
boolean result = true; // assume it has errors or has never been built
if (javaProject.hasBuildState()) {
result = false; // ok, we have a build state so assume no errors
IMarker[] problems =
javaProject.getProject().findMarkers(
IMarker.PROBLEM,
true,
IResource.DEPTH_INFINITE);
// check if any of these have a severity attribute that indicates an error
for (int problemsIndex = 0;
problemsIndex < problems.length;
problemsIndex++) {
result =
(IMarker.SEVERITY_ERROR
== problems[problemsIndex].getAttribute(
IMarker.SEVERITY,
IMarker.SEVERITY_INFO));
return result;
Re: IJavaProject - How do I determine build status (i.e., OK, warnings, errors)? [message #43833 is a reply to message #43622] Thu, 29 May 2003 17:59 Go to previous message
Your code only indicates whether the last IMarker has a problem or not,
since you are re-writing over your result variable every time in the
loop. Instead, it should probably read:
problemsIndex++) {
if (IMarker.SEVERITY_ERROR
IMarker.SEVERITY,
return true;
>> or has errors.
>> Tim Halloran
> markers attached to the IProject related to the IJavaProject. My code
> is below:
> has
> IMarker.PROBLEM,
> true,
> an error
> problemsIndex++) {
> result =
> IMarker.SEVERITY,
> return result;
Previous Topic:Associate .java files with Eclipse (Windows)
Next Topic:Ant, Eclipse Config and JRE
Current Time: Thu Jul 17 21:33:14 EDT 2025
Powered by FUDForum. Page generated in 0.06700 seconds
