Home » Archived » BIRT » Changing Property Edit Window
Changing Property Edit Window [message #43161] Sat, 04 June 2005 10:58 Go to next message
If I wanted to submit a suggested change to BIRT like putting the fonts in
the property window in alphabetical order or changing the way the size
drop down works how would I go about that? Is it a matter of changing the
appropriate UI jar file?
Stephen Jung,
Maximize, Inc.
Re: Changing Property Edit Window [message #43237 is a reply to message #43161] Sun, 05 June 2005 22:08 Go to previous messageGo to next message
Hi Stephen,
If you wanted to submit a suggested change or a potential defect to BIRT,
please submit a request in Bugzila. We'll work on it ASAP.
Thanks.
Nina
Re: Changing Property Edit Window [message #43331 is a reply to message #43237] Mon, 06 June 2005 11:56 Go to previous messageGo to next message
Stephen,
If you put a bug in Bugzilla for that, please set it up as an
enhancement. The developers are really trying to close out any 'bugs'
in Bugzilla right now and they sometimes get over-zealous and close out
enhancement requests. We are actively looking at enhancement requests
and will try to integrate them into future builds of the product.
Scott Rosenbaum
BIRT PMC
Nina Li wrote:
> Hi Stephen,
> BIRT, please submit a request in Bugzila. We'll work on it ASAP.
> Thanks.
> Nina
Re: Changing Property Edit Window [message #43520 is a reply to message #43331] Mon, 06 June 2005 23:11 Go to previous messageGo to next message
How do I submit an enhancement request to Bugzilla?
Re: Changing Property Edit Window [message #45765 is a reply to message #43520] Tue, 14 June 2005 12:50 Go to previous message
Originally posted by: none.none.com
Stephen,
Go to this page https://bugs.eclipse.org/bugs/ and click on "Enter an
enhancement/feature request", then choose BIRT on the next page.
David
"Stephen Jung" <scjung1@sbcglobal.net> wrote in message
news:ae23783dc6929985d685fd17b78979fa$1@www.eclipse.org...
Previous Topic:IRunAndRenderTask
Next Topic:How do I limit the data set to a particular schema for Oracle JDBC connection?
Current Time: Fri Jul 18 00:26:26 EDT 2025
Powered by FUDForum. Page generated in 0.33382 seconds
