Home » Eclipse Projects » Subversive » js files not being numbered/decorated?
js files not being numbered/decorated? [message #43146] Thu, 12 March 2009 11:56 Go to next message
hi,
I have an eclipse project and the js files contained in the proect are not
showing the revision number. All other folders/files are fine. The history
shows all the info but not in the project explorer.
Are .js files filtered out for some reason? I'm on version
0.7.7.I20090224-1900. I have done a quick bug check and there's nowt
listed. What have I not configured or not doing correctly?
Re: js files not being numbered/decorated? [message #43198 is a reply to message #43146] Thu, 12 March 2009 12:10 Go to previous message
I found the issue, it's the javascript elements toggle in project explorer
> customise view > content > javascript elements.
This setting changes the javascript file icon in project explorer and
hides the number.
Should adding a project to svn change these settings to allow numbering to
be seen?
Previous Topic:external compare editor failed
Next Topic:Weekly builds for Subversive Connectors
Current Time: Fri Jul 18 00:09:27 EDT 2025
Powered by FUDForum. Page generated in 0.19294 seconds
