Home » General (non-technical) » Eclipse Foundation » Problem while using eclipse3.2
Problem while using eclipse3.2 [message #43130] Sun, 17 December 2006 00:34 Go to next message
hi
we are using eclipse 3.2 for our project with the follwoing properties
specified in target of eclipse shorcut.
E:\Eclipse\eclipse3.2\eclipse.exe -vm
C:\jrockit-j2sdk1.4.2_08\bin\javaw.exe -vmargs -Xmx452m
The problem we are facing with it is many a times inbetween the javaw.exe
task takes 100% CPU tilization and eclipse just gets hanged. it also
happenes in debug mode.
can anyone let me know what might be the problem?
thanks
Re: Problem while using eclipse3.2 [message #43178 is a reply to message #43130] Sun, 17 December 2006 07:18 Go to previous message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
You'd have better luck if you post your question in the
eclipse.newcomers group:
http://www.eclipse.org/newsportal/thread.php?group=eclipse.n ewcomer
This newsgroup is for questions about the operations of the Eclipse
foundation itself.
Denis
rakesh wrote:
> hi
> javaw.exe task takes 100% CPU tilization and eclipse just gets hanged.
> it also happenes in debug mode.
> thanks
Previous Topic:How to use the External Jars In plugin project
Next Topic:error when starting eclipse
Current Time: Tue Jul 08 18:15:26 EDT 2025
Powered by FUDForum. Page generated in 0.04327 seconds
