SetCommand and actionbar questions [message #429417] |
Wed, 22 April 2009 13:40  |
I have a couple newbie EMF.Edit questions.
For my EMF.Edit plugins, I'm trying to simplify the popup context menu so
that it has grand total of 4 entries, Undo, Redo, SetMyFeatureToValue1,
and SetMyFeatureToValue2.
I'd like to completely eliminate the rest of the menu entries such as
CreateSibling, CreateChild, copy, paste, cut, etc. (actually, I'd like to
enable the rest of these actions conditionally depending on who is using
the plugin, but that is a completely different question and is not part of
this post).
So, this brings up a few questions, most of which are due to my ignorance
of EditingDomains and EMF commands.
1) What is the best way to eliminate the default set of actions?
At the moment, for testing purposes, I'm simply commenting out all of the
existing code inside of MyPackageActionBarContributor.menuAboutToShow()
and then adding my own actions via the menuManager.add() method.
2) How do I properly create and associate an Action based upon the
existing SetCommand?
This is actually several questions in one and refers to the
SetMyFeatureToValue1 and SetMyFeatureToValue2 popup menu entries that I
mentioned in the opening paragraph.
* These menu's should only be enabled when the user has selected the
appropriate object in the viewer tree.
* They should only be enabled if the value hasn't already been set.
* Full undo and redo support is needed.
I've tried creating my own class SetMyFeatureToValue1Action (extending
CommandActionHandler), and overriding the createCommand() method to create
a CompoundCommand for each object in the collection. But so far this has
been a dud. The domain isn't getting set (not sure why).
Wondering if someone can give me a few pointers.
Richard
Re: SetCommand and actionbar questions [message #429418 is a reply to message #429417] |
Wed, 22 April 2009 14:18  |
Richard,
Comments below.
Richard Memory wrote:
> so that it has grand total of 4 entries, Undo, Redo,
> SetMyFeatureToValue1, and SetMyFeatureToValue2.
> to enable the rest of these actions conditionally depending on who is
> using the plugin, but that is a completely different question and is
> not part of this post).
Hmmm.
> ignorance of EditingDomains and EMF commands.
Negative shopping can be hard. You'd have to look at what
EditingDomainActionBarContributor is giving you for free that eliminate
what you don't want via derivation.
> the existing code inside of
> MyPackageActionBarContributor.menuAboutToShow() and then adding my own
All the existing actions delegate to commands, so you could look at any
one of them as an example.
> I mentioned in the opening paragraph.
Most of the existing actions operate on the selection.
The action will be enabled if the command to which it delegates is enabled.
The command already support that.
> create a CompoundCommand for each object in the collection. But so far
> this has been a dud. The domain isn't getting set (not sure why).
Look at how copy works...
> Richard
FUDForum. Page generated in 0.05734 seconds
