Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Build, P2 metadata: Category setup, site.xml
PDE Build, P2 metadata: Category setup, site.xml [message #43096] |
Thu, 29 January 2009 15:09  |
I promise this is the last one today -- didn't want to get threads
confused. :D Any thoughts/hints on the following would be greatly
appreciated..even the url for a good example build as the one's I'm
coming up w/ only build raw features:
I can't grok how to get categories created properly. I can generate the
update site just fine using the built in p2 support, but there don't
appear to be any hooks for specifying categories. To be clear, here I'm
talking about the broad categories that show up under p2 Install, e.g.
"Models and Model Development" "OpenArchitectureWare", etc..
My reading of newsgroup and wiki traffic is that that has to happen
through a site.xml file. (Which I thought was a p1 mechanism, but
anyway..) OK, but I'm also seeing that the site.xml file is *not*
produced by the PDE Build p2 generator. So that means that we have to
create and synchronize the site.xml file manually? But the site file
isn't finding the artifacts created in the target PDE Build P2 site.
Does this mean that we actually need to edit the site.xml file by hand
with the new version information every time we do a release?
Re: PDE Build, P2 metadata: Category setup, site.xml [message #44300 is a reply to message #43096] |
Tue, 03 February 2009 14:20   |
Try M5, generation from site.xml is a little shaky and still needs work.
We introduced a property "p2.category.site" (starting in pde.build
v20090105) which is a url to a site.xml to generate categories from.
However, build has never managed site.xml files and doesn't touch
versions in them.
The metadata.generator starting in v20090203 can handle .qualifier so
you wouldn't need specific versions in the site.xml (the category will
get versions based on the features it has seen.
-Andrew
Re: PDE Build, P2 metadata: Category setup, site.xml [message #46383 is a reply to message #44300] |
Tue, 10 February 2009 17:18  |
Thanks Andrew, the 0205 build handled qualifiers perfectly. I think I
may actually have an honest-to-goodness automated build solution now!
> versions in them.
> -Andrew
Re: PDE Build, P2 metadata: Category setup, site.xml [message #591197 is a reply to message #43096] |
versions in them.
-Andrew
Re: PDE Build, P2 metadata: Category setup, site.xml [message #591797 is a reply to message #44300] |
> versions in them.
> -Andrew
Current Time: Tue Jul 15 11:29:36 EDT 2025
Powered by FUDForum. Page generated in 0.11167 seconds
