Home » Language IDEs » PHP Development Tools (PDT) » Some little feature request
Some little feature request [message #43087] Wed, 15 August 2007 09:11 Go to next message
I'm an "old" programmer but new to php and eclipse/pdt.
Can I ask some feature for the debugger?
I don't know where else I can send them :(
- Assign a function key to the "Relaunch" menu voice.
On the Debug tab I can right click a debug and relaunch it, but a function
key for the selected one may be more handy.
I can relaunch with F11, but it lauch another debug and each time I have to
choose the debug type from the dialog window.
- It is not possible to implement the classic "immediate tab" where I can
write and evaluate code?
- The tab "Expressions" would be nice if I could add/edit an expression to
the list without open the dialog for it.
The classic editing of a treeview...
- Is it not possible to add the possibility to set the current code line to
be debugged?
I want to say: I'm debugging and I'm on the line 10, I go on on the line 11
(with F6), I want to return to the line 10 and re-execute from it... or
maybe I want to pass to the line 13 skipping the 12... I'm clear? :)
I thank you for the patience :)
Re: Some little feature request [message #43297 is a reply to message #43087] Wed, 15 August 2007 11:17 Go to previous messageGo to next message
Originally posted by: dserodio.gmail.com
Fabio wrote:
https://bugs.eclipse.org/bugs/ is the right place. Choose PDT as the
Plugin/Component, and "Enhancement" as the severity
I don't understand; F11 works fine for me, I don't have to choose the
debug type.
> be debugged?
Right-click on the line you want to stop and choose "Run to Line", or
hit Ctrl+R.
HTH,
Daniel Serodio
Re: Some little feature request [message #43334 is a reply to message #43297] Wed, 15 August 2007 11:39 Go to previous messageGo to next message
"Daniel Serodio" <dserodio@gmail.com> ha scritto nel messaggio
news:f9v5e3$7fa$1@build.eclipse.org...
>> function
>> to
> debug type.
take a look at this:
http://img403.imageshack.us/img403/7176/pdtke8.png
If I press F11 on the debug tab it's ok (I think it does a relaunch) but if
I press F11 on the starting .php file I get the dialog and I must choose the
debug mode.
And if I have the debugger stopped on a breakpoint and I press F11 the
process is not relaunched but a new one is started.
>> to
>> be debugged?
>> 11
> hit Ctrl+R.
"Run to line" run *up* to the next breakpoint as the F8 :( but I cannot
choose the line I want to go to, also if that line is already passed :)
Re: Some little feature request [message #43382 is a reply to message #43087] Wed, 15 August 2007 12:28 Go to previous messageGo to next message
With regard to "Is it not possible to add the possibility to set the current code line to
> be debugged?", you should be able to do run to line. Select the line you want to break
on, bring up the context menu and select run to line.
Dave Kelsey
Fabio wrote:
> be debugged?
Re: Some little feature request [message #43413 is a reply to message #43334] Wed, 15 August 2007 12:31 Go to previous messageGo to next message
> debug mode.
Did you look at Preferences->PHP->Debug->Launching->Allow multiple debug
sessions?
James
Re: Some little feature request [message #43444 is a reply to message #43334] Wed, 15 August 2007 12:35 Go to previous messageGo to next message
There is an option in Eclipse to tell it to ignore any breakpoints when
you do a run to line. It can be found in the Preferences menu Run/Debug
and an option to "Skip breakpoints". However I know that the XDebug support
currently doesn't honour that (This is on my list of things to support).
It is not possible to retreat your steps in PHP as far as I know (maybe the
zend debugger has the option, but XDebug doesn't). the only way you can return
to a previous line would be if you are in a loop and going around on the next
iteration.
Dave Kelsey
Re: Some little feature request [message #43537 is a reply to message #43413] Wed, 15 August 2007 14:18 Go to previous messageGo to next message
"James" <james@gnr-inc.com> ha scritto nel messaggio
news:f9v9km$q4q$1@build.eclipse.org...
> sessions?
I set it to Never but nothing changes :(
Re: Some little feature request [message #44373 is a reply to message #43334] Fri, 17 August 2007 15:47 Go to previous messageGo to next message
>>> function
>>> to
>> debug type.
> debug mode.
Weird, even if I ask for options, I don't have as many options as you
do, only "Run on Server", "PHP Script" and "PHP Web Page".
Don't know if it makes any difference, but I noticed you're using
XDebug, while I'm using Zend Debugger.
That's expected, you should use F8 to resume the current session, F11 is
for starting new sessions.
>>> to
>>> be debugged?
>>> 11
>> hit Ctrl+R.
Like others have already mentioned, stopping at breakpoints is configurable.
Returning to a previous line, AFAIK is not possible. Eclipse is able to
do this for Java apps with the "Drop to Frame" feature, that returns to
the previous "frame" (function invocation), so you can restart the
current function.
I'm new to PHP, but I don't think that's possible with PHP.
Daniel Serodio
Re: Some little feature request [message #44403 is a reply to message #44373] Fri, 17 August 2007 21:24 Go to previous message
news:fa4u01$stf$1@build.eclipse.org...
> current function.
I'm new too to php, but I tryied the debugger of PhpED and it can do it, but
it does not use xdebug (I think it use the Zend).
The other really handy is its immediate window for the debug.
Previous Topic:Eclipse Europa, mouse drag&drop
Next Topic:Breakpoints with Server Debug?
Current Time: Thu Jul 17 18:12:33 EDT 2025
Powered by FUDForum. Page generated in 0.06679 seconds
