eclipse linux sightings [message #43054] |
Wed, 22 January 2003 16:11  |
Hi like I mentioned earlier I once a while ago recognized that eclipse
is faster on certain high patched kernels. Well to check it again I patched
a plain vanilla kernel (2.4.20) with the low latency , preemptive kernel
patches, and what can I say. Wohoo Eclipse GTK2 has become significantly
faster (M4), switching workspaces now is quite ok speedwise and also the
whole reaction of the IDE has become snappier. I don't know how those
patches will affect my system, but I don't mind since it is a toy system
anyway, but if you can spend a spare system give those kernel patches a try
or try to get a prepatched kernel, the difference of java generally is
amazing. So far it looks really good, I gave Eclipse a small testrun and no
single crash like with older very high patched kernels (gentoo kernel).
Memory Dragon
Re: eclipse linux sightings [message #43320 is a reply to message #43054] |
Thu, 23 January 2003 10:40   |
> patched a plain vanilla kernel (2.4.20) with the low latency ,
> preemptive kernel patches, and what can I say. Wohoo Eclipse GTK2 has
> become significantly faster (M4), switching workspaces now is quite ok
> speedwise and also the whole reaction of the IDE has become snappier. I
> don't know how those patches will affect my system, but I don't mind
> since it is a toy system anyway, but if you can spend a spare system
> give those kernel patches a try or try to get a prepatched kernel, the
> difference of java generally is amazing. So far it looks really good, I
> gave Eclipse a small testrun and no single crash like with older very
I'm curious. What's the difference in reaction time between running
Eclipse M4 on a patched kernel and an unpatched one? What kernel patches
are you running?
I've seen no big improvements with the low-latency/pre-emption patches. I
do know that Eclipse/GTK in general has become a lot faster in the last
months...
Klaasjan
Re: eclipse linux sightings [message #43360 is a reply to message #43320] |
Thu, 23 January 2003 10:50  |
Klaasjan Brand <kjb@dds.nl> wrote in news:b0p1a5$bkt$1@rogue.oti.com:
I
I
patches
> are you running?
I
> months...
Hard to measure (unless you can give me a hint how)
Lets say it that way, I only patched in the preemtion and low latency
patch on kernel 2.4.20, the rest is the same. X uses DGA DRI and XV on
standard NVidia drivers. The reaction time, subjectively is around 20% -
50% less than before. It is especially noticable during heavy switching
processes like going from Java to the Debug view. My GTK2 is compiled
against the multithreading tag in gentoo and I compiled the whole system
against AthlonTB and -O2 flags in GCC.
Re: eclipse linux sightings [message #589310 is a reply to message #43054] |
are you running?
months...
Klaasjan
Re: eclipse linux sightings [message #589320 is a reply to message #43320] |
I
I
patches
> are you running?
I
> months...
FUDForum. Page generated in 0.08262 seconds
