Home » Modeling » EMF » JF
JF [message #428415] |
Fri, 20 March 2009 14:43 |
J F Messages: 256 Registered: July 2009 |
I have eclipse 3.5M4; Version: 3.5.0
Build id: I20081211-1908
I'm having problems updating my EMF installation to M6.
I use the P2 GUI to view what software there is to update, and choose
EMF2.5.0M6 and get the following message;
Eclipse Modeling Framework (EMF) All-In-One SDK is already installed, so
an update will be performed instead.
EMF - Eclipse Modeling Framework Core Runtime is already installed, so an
EMF - Eclipse Modeling Framework Runtime and Tools is already installed,
so an update will be performed instead.
EMF Code Generation is already installed, so an update will be performed
instead.
EMF Code Generation UI is already installed, so an update will be
performed instead.
EMF Common is already installed, so an update will be performed instead.
EMF Common UI is already installed, so an update will be performed instead.
EMF Data Binding is already installed, so an update will be performed
instead.
EMF Documentation is already installed, so an update will be performed
instead.
EMF Ecore Code Generator is already installed, so an update will be
performed instead.
EMF Ecore Code Generator UI is already installed, so an update will be
performed instead.
EMF Ecore Edit is already installed, so an update will be performed
instead.
EMF Ecore Mapping is already installed, so an update will be performed
instead.
EMF Ecore Mapping Editor is already installed, so an update will be
performed instead.
EMF Edit is already installed, so an update will be performed instead.
EMF Edit Data Binding is already installed, so an update will be performed
instead.
EMF Edit UI is already installed, so an update will be performed instead.
EMF Examples is already installed, so an update will be performed instead.
EMF Examples Source is already installed, so an update will be performed
instead.
EMF Mapping is already installed, so an update will be performed instead.
EMF Mapping UI is already installed, so an update will be performed
instead.
EMF Model Converter is already installed, so an update will be performed
instead.
EMF Sample Ecore Editor is already installed, so an update will be
performed instead.
EMF SDK - Eclipse Modeling Framework SDK is already installed, so an
EMF Source is already installed, so an update will be performed instead.
XSD - XML Schema Definition Runtime is already installed, so an update
XSD Documentation is already installed, so an update will be performed
instead.
XSD Ecore Converter is already installed, so an update will be performed
instead.
XSD Edit is already installed, so an update will be performed instead.
XSD Sample Editor is already installed, so an update will be performed
instead.
XSD SDK - XML Schema Definition SDK is already installed, so an update
XSD Source is already installed, so an update will be performed instead.
XSD to Ecore Mapping is already installed, so an update will be performed
instead.
XSD to Ecore Mapping Editor is already installed, so an update will be
performed instead.
Cannot find a solution satisfying the following requirements
org.eclipse.ui.ide.application [1.0.100.I20081026-2000].
I have posted to eclipse.technology.equinox for help with tracking down
what this could be, but hoping that this may be something that someone has
seen before when updating EMF components, I am also posting here. The
problem with P2 is that I'm never sure how to track down WHERE the
problems are coming from...
Re: JF [message #428430 is a reply to message #428415] |
Fri, 20 March 2009 18:28 |
Ed Merks Messages: 33142 Registered: July 2009 |
JF,
I really haven't a clue. Fortunately I never update anything. I
extract it all from CVS and bootstrap from that...
Weird how the sender and subject are switched by the way... Is there a
wire crossed at your end?
> performed instead.
> performed instead.
> instead.
> instead.
> instead.
> performed instead.
> performed instead.
> instead.
> instead.
> performed instead.
> performed instead.
> instead.
> performed instead.
> instead.
> performed instead.
> performed instead.
> instead.
> performed instead.
> instead.
> performed instead.
> performed instead.
> down what this could be, but hoping that this may be something that
> someone has seen before when updating EMF components, I am also
> posting here. The problem with P2 is that I'm never sure how to track
> down WHERE the problems are coming from...
Ed Merks
Current Time: Sun Apr 28 16:05:00 GMT 2024
Powered by FUDForum. Page generated in 0.03023 seconds
