Home » Archived » OHF » New stable build of IHE and Bridge components now available
New stable build of IHE and Bridge components now available [message #43031] Thu, 01 May 2008 14:32 Go to next message
Greetings,
We are pleased to announce a new major build of the Eclipse OHF IHE and
Bridge components is now available. This build reflects stable code tested
and validated by multiple vendors at the 2008 IHE North American and
European Connectathons.
About the Build
The new build is numbered 0.3.0 Milestone 1. This build reflects
substantial changes over the 0.2.x builds, conforms to the 2007-2008 IHE
ITI Technical Framework, and was tested by multiple vendors at the 2008 IHE
Connectathons. All major bugs are now closed and any outstanding issues
are deemed minor.
IHE updates include:
* Updates to all existing IHE profile implementations for 2007-2008,
including all relevant CPs
* Added support for IHE XDS.b Document Source and Document Consumer,
* Added support for IHE XCA - Cross Community Access
* Added support for IHE PDVQ - Patient Demographic Visit Query
Bridge updates include:
* Updates for API changes to the IHE components
* Separation of configuration manager into separate component
Specifically this build implements the following IHE profiles, actors, and
transactions:
Audit Trail and Node Authentication (ATNA) - Secure Node and Secure
Application
* ITI-19: Authenticate Node
* ITI-20: Record Audit Message
Patient Demographic Query (PDQ) - Patient Demographics Consumer
* ITI-21: Patient Demographics Query
* ITI-22: Patient Demographics and Visit Query
Patient Identity Cross-Referencing (PIX) - Patient Identity Source and PIX
Consumer
* ITI-8: PIX Feed
* ITI-9: PIX Query
Cross-Enterprise Document Sharing A (XDS.a) - Document Source and Document
Consumer
* ITI-15: Provide and Register Document Set
* ITI-16: Query Registry
* ITI-17: Retrieve Document
* ITI-18: Registry Stored Query
Cross-Enterprise Document Sharing B (XDS.b) - Document Source and Document
Consumer
* ITI-18: Registry Stored Query (w/XDS.b semantics)
* ITI-41: Provide and Register Document Set-b
* ITI-43: Retrieve Document Set
Cross Community Access (XCA)
(no actors implemented, but supported through XDS)
With this release, we are discontinuing interim / daily builds that were
kept for Connectathon users. Please use the stable builds if you wish to
use the IHE or Bridge components. If you are interested in using OHF with
legacy IHE infrastructure (2006-2007), please use build 0.2.0.
Downloads
For binary downloads of the 0.3.0 versions, please see the official OHF
Downloads page:
http://www.eclipse.org/ohf/downloads/
Help and Support
For questions and support with OHF, we encourage the use of the newsgroup.
For more information:
http://www.eclipse.org/ohf/newsgroup.php.
To submit bugs, please use the Eclipse Bugzilla site. See:
http://www.eclipse.org/ohf/bugs.php.
-Matt Davis
IBM Almaden Research Center
Re: New stable build of IHE and Bridge components now available [message #43361 is a reply to message #43031] Wed, 02 July 2008 22:55 Go to previous messageGo to next message
I tried both the 0.3.0 Milestone and the earlier released 0.2.x build
(the download packages) and both equally fail on Windows in the
described environment:
Tomcat 5.x
Java 5
Is this known to work on Windows, or has it mostly been used on Unix
systems only?
Werner
Re: New stable build of IHE and Bridge components now available [message #43386 is a reply to message #43361] Sat, 05 July 2008 00:01 Go to previous messageGo to next message
Hi Werner,
Could you post a log file of the errors? We primarily have tested them
in Windows, but it should work on both Windows and Linux.
-Matt
Werner Keil wrote:
> Tomcat 5.x
> Java 5
> systems only?
> Werner
Re: New stable build of IHE and Bridge components now available [message #43418 is a reply to message #43386] Sat, 05 July 2008 09:57 Go to previous messageGo to next message
That is where it failed.
Unfortunately the client where this was used to demonstrate custom
Exception Handling and usage of Log4J has no clue of what to log and how ;-/
Therefore the demonstration does not exist any more. And they keep
chatting until the end of time (or till their budget runs out)
Matthew Davis wrote:
> Hi Werner,
> Thanks
> -Matt
> Werner Keil wrote:
>> Tomcat 5.x
>> Java 5
>> systems only?
>> Thanks,
>> Werner
Re: New stable build of IHE and Bridge components now available [message #43549 is a reply to message #43418] Tue, 08 July 2008 17:05 Go to previous message
Hi Werner,
I don't completely follow your issue here ... did you not even get a
stack trace you could give us from Tomcat?
- Sarah
>> Hi Werner,
>> them in Windows, but it should work on both Windows and Linux.
>> Thanks
>> -Matt
>> Werner Keil wrote:
>>> Hi,
>>> Tomcat 5.x
>>> Java 5
>>> systems only?
>>> Thanks,
>>> Werner
Re: New stable build of IHE and Bridge components now available [message #585702 is a reply to message #43031] Wed, 02 July 2008 22:55 Go to previous message
Tomcat 5.x
Java 5
systems only?
Werner
Re: New stable build of IHE and Bridge components now available [message #585714 is a reply to message #43361] Sat, 05 July 2008 00:01 Go to previous message
Hi Werner,
-Matt
Werner Keil wrote:
> Tomcat 5.x
> Java 5
> systems only?
> Werner
Re: New stable build of IHE and Bridge components now available [message #585727 is a reply to message #43386] Sat, 05 July 2008 09:57 Go to previous message
> Hi Werner,
> Thanks
> -Matt
> Werner Keil wrote:
>> Tomcat 5.x
>> Java 5
>> systems only?
>> Thanks,
>> Werner
Re: New stable build of IHE and Bridge components now available [message #585776 is a reply to message #43418] Tue, 08 July 2008 17:05 Go to previous message
Hi Werner,
- Sarah
>> Hi Werner,
>> Thanks
>> -Matt
>> Werner Keil wrote:
>>> Hi,
>>> Tomcat 5.x
>>> Java 5
>>> systems only?
>>> Thanks,
>>> Werner
Previous Topic:STEM : Exception launching the Eclipse Platform
Next Topic:How to use the http://localhost:8080/bridge/services/ohf-bridge
Current Time: Tue Jul 22 22:54:17 EDT 2025
Powered by FUDForum. Page generated in 0.04518 seconds
