Home » Eclipse Projects » Subversive » Different results using compare view and svn diff
Different results using compare view and svn diff [message #43019] Mon, 09 March 2009 15:24
When I use "Compare With" to compare two revisions, in this case trunk and
branch, I see results for files that only seem to differ in revision
number (the file content is identical). When I compare the same revisions
using an "svn diff" command the results only includes files with actual
content differences.
Is there a configuration setting to alter the plugin's comparison behavior
to ignore revision number differences?
Previous Topic:Cannot install connectors - dependency problem
Next Topic:external compare editor failed
Current Time: Sun Sep 07 19:55:25 EDT 2025
Powered by FUDForum. Page generated in 0.40675 seconds
