Namespaces [message #43007] |
Fri, 30 April 2004 08:56  |
Originally posted by: invalid.soft-gems.net
And here is another little question:
Is it possible to get the original namespace identifier from a
targetNamespace reference back? What I have is XSDTypeDefinition from
which I would like to show its base type in the format it was written in
the xsd file (e.g. as in <xs:extension base="odie:tdType">. We have a
relatively large namespace set with a complex element hierarchy so it
would be very helpful to have that info included.
Thanks a bunch.
Mike
www.soft-gems.net
Re: Namespaces [message #43195 is a reply to message #43162] |
Mon, 03 May 2004 08:58   |
--------------FC4433DC305F83B1AB5E8F22
Content-Type: text/plain; charset=us-ascii
Mike,
The mapping from URL to prefix is not necessarily unique. The choice of
prefix is also context dependant, that's why there is a getQName method that
takes a context argument so that you can get the QName that would be used in
that particular context. I don't understand your comment about it only
working for standard types; the sample editor uses it for all types:
[Image]
Maybe I've misunderstood what you are trying to do?
Mike Lischke wrote:
> Ed Merks wrote:
> > Mike,
> > There's XSDSchema.getQNamePrefixToNamespaceMap() and there's also
> > XSDNamedComponent.getQName().
> Thank you Ed. Unfortunately, this does not help much. getQName only
> returns the name with prefix for standard types not my own types. The map
> returned by the first function contains the mappings, right, but only for
> one schema and lookup can only be done from prefix to URL. So I will not
> only have to iterate the implicitely loaded schemas but also their maps.
> Quite a lot of work just to get the namespace prefixes.
> I wonder why it was not considered as being worth to create a field in
> XSDTypeDefinition, which gets this prefix.
> Mike
> www.soft-gems.net
Content-Type: multipart/related;
boundary="------------C3C5DE0B0E2F9DB2DF5F462C"
--------------C3C5DE0B0E2F9DB2DF5F462C
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Mike,
<p>The mapping from URL to prefix is not necessarily unique. The choice
of prefix is also context dependant, that's why there is a getQName method
that takes a context argument so that you can get the QName that would
be used in that particular context. I don't understand your comment about
it only working for standard types; the sample editor uses it for all types:
<blockquote><img SRC="cid:part1.40964202.968459F@ca.ibm.com" height=127 width=667></blockquote>
<br>
<p>Mike Lischke wrote:
<blockquote TYPE=CITE>Ed Merks wrote:
<p>> Mike,
<p>> There's XSDSchema.getQNamePrefixToNamespaceMap() and there's also
<br>> XSDNamedComponent.getQName().
<p>Thank you Ed. Unfortunately, this does not help much. getQName only
<br>returns the name with prefix for standard types not my own types. The
map
<br>returned by the first function contains the mappings, right, but only
for
<br>one schema and lookup can only be done from prefix to URL. So I will
not
<br>only have to iterate the implicitely loaded schemas but also their
maps.
<br>Quite a lot of work just to get the namespace prefixes.
<p>I wonder why it was not considered as being worth to create a field
in
<br>XSDTypeDefinition, which gets this prefix.
<p>Mike
<br>--
<br>www.soft-gems.net</blockquote>
</html>
Content-Type: image/jpeg
Content-ID: <part1.40964202.968459F@ca.ibm.com>
Content-Disposition: inline; filename="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\nsmailE5.jpeg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDACAWGBwYFCAcGhwkIiAmMFA0MCws MGJGSjpQdGZ6
eHJmcG6AkLicgIiuim5woNqirr7EztDOfJri8uDI8LjKzsb/2wBDASIkJDAq MF40NF7GhHCE
xsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbG xsbGxsb/wAAR
CAB/ApsDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDS2xZIEQJHXEef6UqrC4O1 E4OD8vQ0yUO0
LCNwpMo+Xfs3/L0B7ev4UyAoTG6F/mRt285OQcfpzzVkk/lRf880/wC+RR5U X/PNP++RVVrm
RJJFkwhwfLXZnPIAOc46kccdfxqM3s43BlVTErs4K/ewFOBgnH3vegRe8qL/ AJ5p/wB8ijyo
v+eaf98iqonuGn8gNGGXduYoSDgKeBnj73r2qCK6lZmMMfzSneeA2BsTjkj1 oA0fKi/55p/3
yKPKi/55p/3yKiE5a3Dgxq+wOQWyAPqO3XmonupfJEoAWM5LMVLbAOxAIOeu cdOnvQBa8qL/
AJ5p/wB8ijyov+eaf98iqhkklngclQgmZQuOeAwznPt6VLNGklxDlBI3ICns DjLA9iMDn8Op
FAybyov+eaf98iliijMrgxoRgH7o9/8ACqxjiNxC6sJByVnyCXPIK5HAAHbv 17GrcH+tf/dX
+tJ7Atx/kQ/88k/75FHkRf8APJP++RUlJUlEfkRf88k/75FHkRf88k/75FSU UAR+RF/zyT/v
kUeRF/zyT/vkVJRQBH5EX/PJP++RR5EX/PJP++RT6KAGeTF/zyT/AL5FJ5MX /PJP++RUlFAE
fkxf88k/75FHkxf88k/75FSUlADPJi/55J/3yKPJi/55J/3yKfRQBH5MX/PJ P++RR5MX/PNP
++RUlFAEfkxf880/75FHkxf880/75FSUlADPJi/55p/3yKPJi/55p/3yKfRQ AzyYv+eaf98i
k8mL/nmn/fIqSigCPyYv+eaf98ijyYv+eaf98in0UgGeTF/zzT/vkUeTF/zz T/vkU+igBnkx
f880/wC+RSeTF/zzT/vkVJSUAM8mL/nmn/fIo8mP/nmn/fIp9FADPJj/AOea f98ijyo/+eaf
98in0UAM8qP/AJ5p/wB8ik8qP/nmn/fIqSkoAZ5Uf/PNP++RR5Uf/PNP++RT 6KAGeVH/AM80
/IUeVH/zzT8qfRQAzyo/+ea/lSeVH/zzX8qfRQAzyo/+ea/lR5Uf/PNfyp9F ADPKj/55r+VH
lR/881/Kn0lAxvlR/wDPNfypPKj/AOea/lT6KAGeVH/zzX8qPKj/ALi/lT6K AGeVH/cX8qPK
j/uL+VPpKAG+VH/cX8qPKj/uL+VOooArefZf89bf/vpam8qP+4v4CoPs0f8A YW/dLn7NnHnP
j7vpnH4VaoENgAkaMOAwKZIPc8f407fBn/j1+Xds3bVxnOPXPWm25w0f/XM/ 0puIt/8ArJse
ZnG35c7vXHr71URNlryoP+eUf/fIo8mH/nlH/wB8iq1tGRhntoY2B6qACOO2 M9896jd28ma4
3uJo2YKgY44Pyjb3zx7/ADcdqTBF3yYf+eUf/fIo8mH/AJ5R/wDfIqhdXcgs mZcKzNKmRwRt
D4I9/lFMuZ5ba4dyVZxGDkAgHCykcZ9hQM0vJh/55R/98ijyYf8AnlH/AN8i qUt1cRP5OFkl
JXDKuByGPQt/s+o6+3Nm3leSENIoV8kEAg9DjsT+WeKAJPJh/wCeUf8A3yKZ PFEIXIiQEKSM
KKqQQxJbhEAxgiOMMFFyAOCR+hPfqeMCpYlSPT2WMgrhjwNoBJJIx2wc8dqA JvJi/wCeaf8A
fIpPJi/55p/3yKkooAj8mL/nmn/fIpPJi/55p/3yKkopAR+TH/zzT/vkUnlR /wDPNP8AvkVJ
SUAM8qP/AJ5p+Qo8qP8A55r+VPpKAIHVmDLmMoxyVdN3+elCqwZSzLhV2qqr tAHH+FWCsQJH
z8fSlSONzgFq0uibMriKIb8RoN/38KPm+vrSLBCilVijUEEEBR36/wAhVoQo WIy3FL9nT1ai
6FZlKS2hlkDyRqxAPBUEHOOfrwKe8UUgIeNGBOSGUHnpmrX2dPVqPs6erUXQ WZWKqTkqCeOS
PTkUjRRMwZo0LA5BKjIPr+g/KrX2dPVqPs6erU+ZBZlXyovN83y08z+/tGfz pJIklYFwSQCO
GIyD1B9Rx0NW/s6erUfZ09WpXQWZUMSGUSYO4HP3jjOMZx0zjjNT2/8ArZP9 1f61J9nT1akN
rExyRn64obTGkyWkqL7HD/d/QUfY4f7v6CpGS0VF9jh/u/oKPscP939BQBLR UX2OH+7+go+x
w/3f0FAElFR/Y4f7v6Cj7HD/AHf0FFgJKKj+xw/3f0FH2OH+7+gosBJSUz7H D/d/QUfY4f7v
6CiwD6KZ9jh/u/oKPscP939BSsA+imfY4f7v6Cj7HD/d/QUWAfSU37HD/d/Q UfY4f7v6CiwD
qKb9jh/u/oKPscP939BRYB1FN+xw/wB39BR9jh/u/oKLALRSfY4f7v6Cj7HD /d/QUWGLRSfY
4f7v6Cj7HD/d/QUWAWko+xw/3f0FH2OH+7+gosAUUfY4f7v6Cj7HD/d/QUWA KKPscP8Ad/QU
fY4f7v6CiwBSUv2OH+7+go+xw/3f0FFguJRS/Y4f7v6Cj7HD/d/QUWC4lFL9 jh/u/oKPscP9
39BRYLjaKd9jh/u/oKPscP8Ad/QUWC42infY4f7v6Cj7HD/d/QUWC42kp/2O H+7+go+xw/3f
0FFguMop/wBjh/u/oKPscP8Ad/QUWC4yin/Y4f7v6Cj7HD/d/QUWC4ykqT7H D/d/QUhtIQM7
f0FFguMopfs8H93/ANBpjpbI6KVOXJAwAe2aLILkf2O1/wCfaH/vgVNR5Vv/ AHD+QoMEOxmV
OR6gUWC5HCcGL/rn/hR5T9PMGzfuxt5659aIRloR6p/hVlhChw8gU+hYChNr YGkyJYlRgwL5
Hq7H+ZpTHGZBIUUyAYDEcj8alRYnzsk3Y64INJIm3aFBYsccnHYn09qNQIvK i83zfKTzP7+0
Z9OtIIIAu0QxhcYxtGO/+J/M0nnwiTazpgHDFJA20+h44/8ArVa8lfU0AQPH HIGDorBgAcjO
cdKVcKoVQAoGAB0FTeSvqaPJX1NIColtCkZjVTtwByxJAHTBPIx29KUosVs6 JnGGPJJOTknk
1a8lfU0xEjmiV1YsjqCPcGgBaKT7JD/cH5Cj7JD/AHB+QpgFFNFvbmRowo3K AxGOxzj+Rp32
SH+4PyFIBKSnfZIf7g/IUfZIf7g/IUANpKf9kh/uD8hR9kh/uD8hQBG/32+t Pg++fpTH++31
p8H3z9KBkq/6x/wp9MX/AFj/AIU+mIKKKKACiiigAooooAKKKKAI55GijLJG 0h9B29//ANWT
7VA00iWnnpNHN8wJKrwwzjauD19OTz+lumNDGxy0aE7g/Kj7w6H60AVhcTta iRBGXdzsXHIH
PBBIywxyMjHPpy2O5uGUI3lrK0vl8p935N3Iyc/ge4+lWWtoHUq0EbKW3kFB gt6/Wl8iHyfJ
8qPyv7m0bfXpQBVtpJBFenzIyySNhmYlAdo/IZzx25FStNJ5NuFaMyTEDeMs oO0sSOeRx696
lWCFQwWKMBwFYBRyAMAH8KVoY2i8po0MeANhUYwOnFAFczTjEZaHzGl2BlyQ o27skZ6nHTPG
R17sa4ufMWJTEW80xMSpAPybgQM9vTv6irXkQ+T5PlR+V/c2jb69KT7NAAgE EeIzlPkHyn29
KAKYvp3hDqkYZhE4UkkbXOMZ9e+ce2O9WoXaVZopSCyNsLJlc5UHjnI6+vam zWMMsHkqoiTI
yEVeQDkDkHjPNS+RD5Pk+VH5X9zaNvr0oAqLcTJp1mYwZJZVUZPJztyTyRnp 608z3KWpkkjV
GRxkEcuvHQBjg84HJ5+tTi2gERiEEYjY5KBBgn6ULbQIoVYI1UNvACDAb1+t AEUateQK8rso
LlgsbFCByNrYPUd/ce1V4vNh02O5jlYs0aNJ5pZwBj5iBn3z+FXxDGFdRGgV ySw2jDE9c+tJ
5KrD5UP7kdvLAGPoMYoAqvcXISSRDEyicRoCpGRuCnJzxycZx26c0SXU6KY1 VXmEvl5VeD8m
7OCR246+/tUslkklmlrvcRoFHYkgdM5GOwqXyIfJ8nyo/K/ubRt9elADbV5n jP2iPYwOB0GR
64BOPz7Ul5JJFCrxBC29Vw2cEEgde3XrzUkUMcK7Yo0jUnOFUAZolhjmXbLG kig5wygjNAFV
7mdUZAEaZZfLBC8N8u7gE+nqe34VHHeXMmxVEYfzjC24d9u7PBPT0yc+oq59 mgIcGCPEhy/y
D5j7+tJ9ktt4f7PFuXGG2DIx0oApjUJ3WMJCu+UIyAHdgMGPcjP3fUdfbmbz b02+fJxKHxja
DkY6438enU/4T/ZoBGY/Ij2EYK7BgjOen1Jp0UMcK7Yo0jUnOFUAZoArFLm5 s2SRmhkLj5l+
QhcjOMM3bNIUkhUI8rkTTtubcfkU5wAe3RR+PHartIyh1KsAykYII4IoAqyW 263khguJAS65
Pmksg4yAeSOP51LbRPEsnmSM5eRm5OdoJ4A/DFSRxpEgSNFRR0VRgCnUAQXc skSKIgDI7bVB
GexPTI9PUf0NL7VLKYSWVJEuDCcthTlCeQCR1xxnqO2a0pI0lQpIiup6qwyD Uf2S23bvs8Wc
bc7B0xjH5cUAQm4nEciKI2mSTZkDG75Q3Ck+h6Z7E+1Rme6Nsx3RpKs6If3f QErwRuPr2J49
D0tm2gMQiMEZjU5CFBgH6U5YY1i8pY0EeCNgUYwevFAEE800VuCjxSSrIqMM EA5IGOpx1Hr9
KJpLiGJRmOSV32rtTHbPQtz0Pcf0MptoDEIjBGY1OQhQYB+lL5EPk+T5Uflf 3No2+vSgCpFe
TSoEwiy+cYixGQCF3dAT9Ov+FOmlulgOJIVkEyJlQW4JUcjPB5z9Pzqx9mg2 svkR7WADDYME
Dpn6U5YY1i8pY0EeCNgUYwevFAEMr3Cw4iKSzK2H2oMDjPQsMdu9MKXNzZsk jNDIXHzL8hC5
GcYZu2atRxpEgSNFRR0VRgCnUAUZEuLe3YrP873AOX+YBWcAAdMcY/X61JPN NFbgo8UkqyKj
DBAOSBjqcdR6/SrLKHUqwDKRggjgiozbQGIRGCMxqchCgwD9KAI5XnhhVmeN mMqKcIQNpIHr
1561C95N+8SIJI/nmJSo6Dbu5BIyRyOo/pVxYY1i8pY0EeCNgUYwevFN+zQb WXyI9rABhsGC
B0z9KAICtzdWbRyboJC4G5TtJXIJIwTjjI605d9pbzO7NK7SMVUt6nCqPTt+ dTxQxwrtijSN
Sc4VQBmlZFdkZhkody+xwR/ImgCAoba0H79Iypy0jj5WJPJIz3Jzwf8ACpYJ GljDPG0Z9D39
/wD9eD7U8qCQSASpyMjoaWgAooooAKKKKACmv0/Efzp1Rzb/ACj5YUtxjccD rQBl3d5JBOiR
20sq5+dlU8D29T/n6SSkNPbEZwSTyMfw0/ZeekH/AH0f8KTybhpY3k8oKhJ+ Uk9Rj0pATU4f
6qT8KbTh/qpPwprcHsQwffg/3f8ACp5nZZm2yxxsVXmQZBGW9xUEH34P93/C tCgCtCzPI372
N2CjLKvHVu2fp3qSTO+LP98/yNS0ySJJVAcEgHPBI/lQBlopSKZFjfyliIBk jwyf7IPcf4Vq
TZ8mTaxVtpwwXcQcdcd/pUItIWLghiAcY3t6fWrNNu4GWfNNuq7ZUXeT5mZX JwBj5chhnng8
DHfINECXEvltOZwXdQ/zMuB5QJ4HT5u4+lXBP5kpWOaLrgDqTx9acruJxG5U 5UtkDHQj396Q
GfbPNI2WM5ud8eR8wUDahbI+6Ore/wClJapcqbcM0ibVjCp5bEbdozk5Cjnd 1Gf0rSkmgtzm
WSOIuc/MwXcf69qloAqzvI6qYVlWTLDGMcA4J54+n4ds1Xk87zW+z+a58s+X u3r5fy8Zz8rZ
PryM+3GlRQBSslUXUzRibYUQZlD5Jy2cbue4q7RRQAUUUUAFFFFAFR/vt9af B98/Sqc16qTO
vlyHDEZG3H8/r+R9DU1jciaYqI5FwucsB/j/AJwfSizC5bX/AFj/AIU+owwW R8+1O3j3oAdR
Td496N496AHUU3ePejePegB1FN3j3o3j3oAdRTd496N496AHUU3ePemGdRKs eDllLD8Mf40A
S0U3ePejePegB1FN3j3o3j3oAdRTd496N496AHUU3ePejePegB1FN3j3o3j3 oAdRTd496N49
6AHUU3ePejePegB1FN3j3o3j3oAdRTd496N496AHUU3ePejePegB1FN3j3o3 j3oAdRTd496N
496AHUU3ePejePegB1FN3j3o3j3oAdRTd496N496AHUU3ePejePegB1FN3j3 o3j3oAdRTd49
6N496AHUU3ePejePegB1FN3j3o3j3oAdRTd496N496AHUU3ePejePegB1FN3 j3o3j3oAdTX+
6aN496RnBGOaAGf5/wA/5/8Artf7p/z/AJ/z+Lv8/wCf8/8A12v90/5/z/n8 UBHTh/qpPwpt
OH+qk/CmtwexDB9+D/d/wrQrPg+/B/u/4VoUAFFFIzBRliAB3JoAaMlmwRwe /PYe/wDn+bJ3
eKEvlTjH8P09/rSpNGWI8xDk8fMOePrUtDGtzLtlX7ZGQ6Dy92RyMjGO/uau 7g16mCD+7bp9
RVdYreS5coYCzHox357njNTxKIrgIEiG5Scom3oR/jSslsShu/7PcTNKsjeY QVZEL8AAY4HH
OT+P1q1VSS9SLHmyRpnpuOM0/wC0HcV+XIGSKYyxRVfz29BURmmk3FX2AZAA weQT1yKVxpXL
tFUd9z/f/Uf/ABNOjuJigIEbgjIbd1/IUXG4+ZcoqkL9BN5LPGJf7uc1cU5U H1FMTVhaKKKB
GFcH/SZTn+M859/r7evbtj5LGlj/AEluOiHt05Ht7e3T2wte4P8ApMpz/Gec +/19vXt2x8lj
Sx/pLcdEPbpyPb29unthbewi+3+sb8KKXaWkfHtS7D7VmMbRTth9qNh9qBDa KdsPtRsPtQA2
inbD7UbD7UANop2w+1Gw+1ADaq3MjR3UbLG0h8t+B25X/PGT7Vc2H2qNoGNw kmRhUZT+JH+F
AFdpXW185Zo5fmBJVeGHTC89fTk8/ognna2EihC7sdq45A9MEjLDHPI7+nNp rdGOWRCdwbkd
/X601rOFlKtDEVLbiCowT6/WgCqlxOVCNsWVpdnK/d+XdyM8/ge4+lFvI4jv D5iFkkOGZiVB
2j8hnPHarf2WPyvK8uPy/wC5tGPXpQLWNQwWOMBgFYBRyAMYP4UAQtLJ5UAV ozJKQNw5UfKT
keo49e9NMs4xGWh8xpNgK5IHy7uR68dM9x1qy1ujReUyIY8AbSOPypPssfle V5cfl/3Nox69
KAKhnuPMWNTEW80xsSpAPybsjnt6d/UUwXs7RB1SMMREwUkkYc4xn175x+He rv2OEBB5MWIz
lPlHy/T0pk2nxSQ+UoEa5GQijnByByOmeaAEhZpRLHKQWRthZMrnIB45yOvr UCzypYWhQGSW
VVGTyfu5J5Iz09aufZY/K8ry4/L/ALm0Y9elILOERGIQxCMnJUKMH8KAK5mu FtjJIioyMMgj
l19gCcHsOTz9adGGuoVaR2UbiwWMlSByMNg9R39xUy2cKqFWGIKG3ABRgH1+ tOFugV1CIFck
sMcNnrn1oAoReZDpyXEcrFmjRn80lwB/EQM++fwp7T3ASSRTEyiYIgKkZGQp yc+pxnHbpzVv
7Nti8uIiEdtgAx+GMVHJYLJaJbb2CIFHYk46ZyMdqAIHuZ1UxqqvKJfLyo4P y7s4J9OOv+FT
2zzPGfPTYwOB05HrgE4/PtUn2WPyvK8uPy/7m0Y9elLHbpCu2JERSc4UYFAE N3JJFEGiClt6
rhuhyQOvbr71E1xMqMgCtMJPLBC8N8u7gE+nv2/Crcluky7ZUR1BzhhkU37H CQ48mLEhy/yj
5vr60AUo7u4k2KojDeaYm3D/AGd2eCenpnn1FH26dlQLEu+UKygc4BDHuRn7 vqOvtzd+xQbw
/kRblxg7BkY6UfY4dhTyYthGCu0Y65/maAK/mXZt8+ViQNj7oORjrjfx+ZoK XFxaMjs0Tlh8
y/KQuRnGC3bNWo7dIV2xIiKTnCjAp+w+1AFEpJEoV5WImnO5t33VOcAHt0A/ HjtUqRBUkSOa
QHdyS24rwOOc/r61YaLcpVgCpGCD0NM+yx+V5Xlx+X/c2jHr0oAqoklxpcKi Vld0Qlw2G7E8
+uM07Y8EMjvchSZC+6Q5UAngc44xjv1qzHbpCu2JERSc4UYFOMWSCQCQcjPa gCKGRpIwzRtG
fQ9/8++D7VJTth9qNh9qAG0U7YfajYfagBtFO2H2o2H2oAbRTth9qNh9qAG0 U7YfajYfagBt
FO2H2o2H2oAbRTth9qNh9qAG0U7YfajYfagBtFO2H2o2H2oAbRTth9qNh9qA G0U7YfakKEDP
FACf5/z/AJ/+u1/un/P+f8/i7/P+f8//AF2v90/5/wA/5/EGR04f6qT8KbTh /qpPwprcHsQw
ffg/3f8ACtCs+D78H+7/AIVoUAFRXBAjBJwAy5J/3hUtIzBRliAB3JoAoRtL 5knm3ETq0q7A
o/3enzHA68fjVqd3ihL5U4x/D9Pf60qTRliPMQ5PHzDnj61LQxrcy7ZV+2Rk Og8vdkcjIxjv
7mru4Nepgg/u26fUVXWK3kuXKGAsx6Md+e54zU8SiK4CBIhuUnKJt6Ef40rJ bEop7vJmlaRX
O8gqVQtwAOOOnOT+P1ojwL+bCEbkXLbSASM9+/BFW5TbwY86ZY89N7AZpQID KYhKDIoyUDDI
H0oGVJBmYrlwGABP8OPm6e/r+FVmSRY2VTIp80l+GIC5bGMH6fd/GtcwIRg5 IqNLZMfu5W25
P3cYBzyOnrQVe6sZqiUPDuMkn+zhkwMnknODxjhuePU4MlonlwW6YmDKcMOc Z285z/D9OM4q
95Ug/hU++/Gf0pFR3UMqoykZBEnBH5UBYq2zBI0gdX3gYY7CQT3OenPX8fWr tuvls0YJ27Qw
HHGSc1DuXzvJ3Q+b/c875vXpirEMbJlnbLHjHYAE47e9A9kyWiiimQYVwf8A SZTn+M859/r7
evbtj5LGlj/SW46Ie3Tke3t7dPbC17g/6TKc/wAZ5z7/AF9vXt2x8ljSx/pL cdEPbpyPb29u
nthbewjSX/WP+FPpi/6x/wAKfUDCiiigAooooAKKKKACiiigAooooAKKKKAI 55GijLJG0h9B
29//ANWT7VA00iWnnpNHN8wJKrwwzjauD19OTz+lumNDGxy0aE7g/Kj7w6H6 0AVhcTtaiRBG
XdzsXHIHPBBIywxyMjHPpy2O5uGUI3lrK0vl8p935N3Iyc/ge4+lWWtoHUq0 EbKW3kFBgt6/
Wl8iHyfJ8qPyv7m0bfXpQBVtpJBFenzIyySNhmYlAdo/IZzx25FStNJ5NuFa MyTEDeMsoO0s
SOeRx696lWCFQwWKMBwFYBRyAMAH8KVoY2i8po0MeANhUYwOnFAFczTjEZaH zGl2BlyQo27s
kZ6nHTPGR17sa4ufMWJTEW80xMSpAPybgQM9vTv6irXkQ+T5PlR+V/c2jb69 KT7NAAgEEeIz
lPkHyn29KAKYvp3hDqkYZhE4UkkbXOMZ9e+ce2O9WoXaVZopSCyNsLJlc5UH jnI6+vamzWMM
sHkqoiTIyEVeQDkDkHjPNS+RD5Pk+VH5X9zaNvr0oAqLcTJp1mYwZJZVUZPJ ztyTyRnp608z
3KWpkkjVGRxkEcuvHQBjg84HJ5+tTi2gERiEEYjY5KBBgn6ULbQIoVYI1UNv ACDAb1+tAFfz
pJYYi7BUmlKnbkFFwcAnPDZAB9zgc804/uMRQSFmkl25kYvsO3PrnoOme9WB DGFdRGgVySw2
jDE9c+tJ5EPk+T5Uflf3No2+vSgCs9zOkT48tpI5kjOQQGDbfc4+979KSWe4 8lwrxrJHOkZb
ZwwO3tnj73r27drJtoDEIjBGY1OQhQYB+lKIIV8zEUY8z7+FHzfX160AQTzz RRIibJZ2fYdq
8A4LdC3oPXvn2prT3aWodo0WQSquG4DAkDsTjr79PerPkQ+T5PlR+V/c2jb6 9Kb9ktvL8v7P
Fszu27BjPrigCvLPceS4V41kjnSMts4YHb2zx9717du00jssBLXMSPGfmcrh foRnjqO/p9Kk
EEK+ZiKMeZ9/Cj5vr69aVIY0VVSNFVDlQFAAPt+Z/OgBIJGljDPG0Z9D39// ANeD7VJRRQAU
UUjMFUsxwAMmgBaKj3yN9yLj1c4z/P8AWjEr/eIjH+wck/mKB2Hk4BPp6UiO HXcvT3GKbskH
IlZj6MBg/kKYIQz5e3h56nOT/KkOyJ6Kj+zw/wDPGP8A75FIbePIKKI2ByCg AP8AKgLLuS0V
EUlUgpIX55V8AEfgKXzGX/WJgdimW/pRcOXsSUUxJFc4GQfQqR/On0ybWCii igAooooAKKKK
ACiiigAooooAKa/3TTqa/wB38RQBH/n/AD/n/wCu1/un/P8An/P4pvHofz/+ tUM0rCaFF6OT
nPPakA+nD/VSfhTacP8AVSfhTW4PYhg+/B/u/wCFaFZ8H34P93/CtCgAqK4I EYJOAGXJP+8K
looAz42l8yTzbiJ1aVdgUf7vT5jgdePxq1O7xQl8qcY/h+nv9amooY1uZdsq /bIyHQeXuyOR
kYx39zV3cGvUwQf3bdPqKBZ24kaTywWbOd3I9ehqRIo4ySkaKT/dUCiyWxKV iDf9nuJmlWRv
MIKsiF+AAMcDjnJ/H602N1kugpjkQRu2xfKYAnnLE4xzk457+p4uUUDI1/4+ H/1n3F6/d6np
7+v4VntHIkTqhlQmdmkOHYbSWIwAR6rnb+PetSigDNQTCS3DNLL0+Xa8eBuP zE5IPGPlbnj1
ODJZJ5VtbRkThkIVwc4DBDnOf4fpxnFXqKAKto/lRx27rIJVGGOw7Se53Yxz 1/H1q1RRQAUU
UUAYVwf9JlOf4zzn3+vt69u2PksaWP8ASW46Ie3Tke3t7dPbC17g/wCkynP8 Z5z7/X29e3bH
yWNLH+ktx0Q9unI9vb26e2Ft7CNJf9Y/4U+mL/rH/Cn1AwooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKAI55GijLJG0h9B29//wBWT7VA00iWnnpNHN8wJKrwwzja uD19OTz+lumN
DGxy0aE7g/Kj7w6H60AVhcTtaiRBGXdzsXHIHPBBIywxyMjHPpy2O5uGUI3l rK0vl8p935N3
Iyc/ge4+lWWtoHUq0EbKW3kFBgt6/Wl8iHyfJ8qPyv7m0bfXpQBVtpJBFenz IyySNhmYlAdo
/IZzx25FPmuJktoDGEkllIGU5XO0kkZIyOPWp1ghUMFijAcBWAUcgDAB/Cla GNovKaNDHgDY
VGMDpxQBWM9ylqZJI1RkcZBHLrx0AY4POByefrTXnuGs1lR40ZpVAGzO1SwG Dz19fxHvVlba
BFCrBGqht4AQYDev1pwhjCuojQK5JYbRhieufWgCvPPNFEiJslnZ9h2rwDgt 0Leg9e+famtP
dpah2jRZBKq4bgMCQOxOOvv096s+RD5Pk+VH5X9zaNvr0pv2S28vy/s8WzO7 bsGM+uKAITcT
iORFEbTJJsyBjd8obhSfQ9M9ifanW8lxLFKGMaSq+3lOnAPI3e/Y+n0qRrS2 bdut4juO5soO
T6n8z+dO8iHyfJ8qPyv7m0bfXpQBXjnkNnZ7NoecKMtlgPlLeuT09aR7mdIn x5bSRzJGcggM
G2+5x9736VYFtAIjEIIxGxyUCDBP0oNtAYhEYIzGpyEKDAP0oAS3kdzKkm0t G+0sowDwD05x
1qK+ZkktWRwrGXZ8zEKcqeo78gY/pVhIY42Zo40VnOWKqAWPvRJDHKQZI0cg EDcoOAetAFV7
mdUZAEaZZfLBC8N8u7gE+nqe34U2O8nkgfaqeckvl445OMnA3Yz7buxPtVvy IfJ8nyo/K/ub
Rt9elNNpbMCDbxEHHBQdhgfkKAKv2u5EW0orTGXywAuNvy7uRuwf++u/4Ush upLYF7cGRX4U
qpDDB5I3ccn1PT8rfkQ+T5PlR+V/c2jb69KWKGOFdsUaRqTnCqAM0DTsVStx dWkkbOYpPMA3
KNhABGcYJ7ZpJEuLe3YrP873AOX+YBWcAAdMcY/X61bdTncnDD8iPQ01vNdS rRRMpGCC5wR+
VAWvsQzzzRRIibJZ2fYdq8A4LdC3oPXvn2pPOuxb/NEqzF9qg4+YYzkDd9eN 3bPtUnk/ufJ+
zQeV/cz8vr02037Knl+X9jttmd23tn1xtouHKyEz3RtmO6NJVnRD+76AleCN x9exPHoelou6
28hMkRlQHLEbVBxkZ5OO1IqbIvL+zxCHBBRDkYPXjFCmBYvKWIiPBGwRHGD1 4xRcOVjJJHaC
3DOuJSBI8Z45BPB7ZOBn39aSS23W8kMFxICXXJ80lkHGQDyRx/Opcq0flRwg pjaVdSq49OlE
aOiCNI4okH9w9PoMUXDlZWYNbg77gBzK0heTLKinIA7Y7cZ61bgkaWMM8bRn 0Pf3/wD14PtS
rDGpBCLkHOcc59c/ifzp9AN9gooooEFFFFABRRRQAUUUUAFFFFABTX6fiP50 6mv0/EfzoAq1
BN/x82/1b+VT1BN/x82/1b+VIZPTh/qpPwptOH+qk/CmtxPYhg+/B/u/4VoV nwffg/3f8K0K
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAwrg/6TKc/wAZ5z7/ AF9vXt2x8ljS
x/pLcdEPbpyPb29untha9wD9qlHOd5/mPf3X9On8E+lEfaD05Q4/8d9vQj07 fRbewjTX/WP+
FPpi/wCsf8KfUDCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigCOeRo
oyyRtIfQdvf/APVk+1QNNIlp56TRzfMCSq8MM42rg9fTk8/pbpjQxsctGhO4 Pyo+8Oh+tAFY
XE7WokQRl3c7FxyBzwQSMsMcjIxz6ctjubhlCN5aytL5fKfd+TdyMnP4HuPp VlraB1KtBGyl
t5BQYLev1pfIh8nyfKj8r+5tG316UAVbaSQRXp8yMskjYZmJQHaPyGc8duRU skswtY2j8t5X
A+6cgnGTtyRn8xxz7VKsEKhgsUYDgKwCjkAYAP4UPBDJGsbxRsi9FKggfhQB T+13Ii2lFaYy
+WAFxt+XdyN2D/313/CpBPc+XGrxrHLJJsDMMjG0tnAY+hHX39qseRD5Pk+V H5X9zaNvr0pB
bQCIxCCMRsclAgwT9KAKq3U5EhLQkRzpEdoJyDtB78H5vwxjnrQ95N+8SIJI /nmJSo6Dbu5B
IyRyOo/pViG1SLzRkskp5RgNoGMYAA6YAH4U77NBtZfIj2sAGGwYIHTP0oAr tPdpah2jRZBK
q4bgMCQOxOOvv096X7RNnycx+b5vl79p2/c3525/Dr7+1TfZLby/L+zxbM7t uwYz64pfs0BD
gwR4kOX+QfMff1oAry3FzGm3EbytLsXy+cDbuyQSOeDxnuOvdwln+zF52S2Z G+84G0j3G446
+vb8Kn8iHyfJ8qPyv7m0bfXpRHBDEAI4o0AO4BVAwcYz+VABBI0sYZ42jPoe /v8A/rwfapKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigApr9P xH86dTX6fiP5
0AVagm/4+bf6t/Kp6gm/4+bf6t/KkMnpw/1Un4U2nD/VSfhTW4nsQwffg/3f 8K0Kz4Pvwf7v
+FaFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAf//Z
--------------C3C5DE0B0E2F9DB2DF5F462C--
--------------FC4433DC305F83B1AB5E8F22--
Re: Namespaces [message #43250 is a reply to message #43195] |
Mon, 03 May 2004 10:05  |
Ed Merks wrote:
> The choice of
OK, I found the reason: default namespaces. Most of the types where not
using namespace prefixes and so belong to the default namespace. getQName
finds them but cannot extract any prefix from the reference. After I
specified a prefix for these namespaces to and added prefixes to every
type I could finally display the layout as I need it.
Mike
www.soft-gems.net
Re: Namespaces [message #586435 is a reply to message #43007] |
Fri, 30 April 2004 09:44  |
Mike,
> Thanks a bunch.
> Mike
> www.soft-gems.net
Re: Namespaces [message #586481 is a reply to message #43077] |
Mon, 03 May 2004 08:31  |
Ed Merks wrote:
> Mike,
Mike
www.soft-gems.net
Re: Namespaces [message #586501 is a reply to message #43162] |
Mike,
[Image]
Mike Lischke wrote:
> Ed Merks wrote:
> > Mike,
> Mike
> www.soft-gems.net
<html>
Mike,
<br>
<p>> Mike,
map
for
not
maps.
in
<p>Mike
<br>--
</html>
Re: Namespaces [message #586534 is a reply to message #43195] |
Mon, 03 May 2004 09:43  |
Yes, that's clear. However it would have been easy to store the prefix in
the type definition during the parse process. This way there would neither
be the need to do a reverse lookup nor would such an relatively expensive
implementation necessary as used for getQName.
>The choice of
> [Image]
Unfortunately, during the day I can access the newsgroups only via web so
I don't see your image nor can I post one. What happens in my
implementation is that sometimes prefixes are shown and sometimes not.
E.g. when I use getQName() then only for type definitions of predefined
XML types are prefixes returned (e.g. xs:anyType). If I use getQName with
a context of the parent of my type (the ancestor) then it depends on the
location of this type whether the prefix is returned or not. I assume this
is the result of included schemas, which are not looked up when searching
for the prefix.
Mike
Re: Namespaces [message #586551 is a reply to message #43195] |
Ed Merks wrote:
> The choice of
Mike
www.soft-gems.net
FUDForum. Page generated in 0.08327 seconds
