Home » Eclipse Projects » Plugin Development Environment (PDE) » Problem : Indirect referenced from required .class files
Problem : Indirect referenced from required .class files [message #42998] Thu, 29 January 2009 12:41 Go to next message
I am developing a plugin that adds a new view to the eclipse platform. I
have included the necessary info in my plugin.xml file(it has no
errors).My class looks like:
*********************************BEGIN CLASS******************************
package org.eclipse.examples.helloworld;
import org.eclipse.swt.widget.*;
import org.eclipse.ui.part.*;
import org.eclipse.ui.*;
import org.eclipse.core.runtime.*;
public class LabelView extends ViewPart{
private LabelView(){
public void setFocus(){
public void createPartControl(Composite parent){
**************************END CLASS**********************************
I have included many .jar files in the build path including:
org.eclipse.core.runtime_3.3.100.v20070530.jar
org.eclipse.core.boot......jar
org.eclipse.swt......jar
org.eclipse.core.runtime.......jar
org.eclipse.ui.workbench.......jar
and others
but i still receive the following errors:
(1) At the package declaration the error is :
The type "org.eclipse.core.runtime.IConfigurationElement" cannot be
resolved. It is indirectly referenced from required .class files.
(2) At the class declaration i get the following errors:
- The type "org.eclipse.core.runtime.IAdaptable" cannot be resolved. It is
- The type "org.eclipse.core.runtime.IExecutableExtension" cannot be
- The hierarchy of the type LabelView(my class name) is inconsistent.
I am using Eclipse version "3.3.0 Java EE" and i have searched its plugin
folder to find the jar file with the name "org.eclipse.core.runtime.jar"
but i only find "org.eclipse.core.runtime_3.3.100.v20070530.jar". I don't
know if they are the same. I don't think they are the same looking at the
error messages.
I am asking if someone can kindly halp me to solve this problem. I have
spent the whole day trying to fix it but no answer. I have googled so many
times but no answer.
Re: Problem : Indirect referenced from required .class files [message #43443 is a reply to message #42998] Sat, 31 January 2009 22:31 Go to previous message
Don't include the jar files manully. Use the dependencies tab in your
plugin.xml editor to manage the dependencies on the plugins
- Prakash
http://blog.eclipse-tips.com
"Kap Pak" <win1for@yahoo.com> wrote in message
news:9b46d03f8e5b3a041443e4e710d8540a$1@www.eclipse.org...
> and others
> error messages.
> Thanks
Re: Problem : Indirect referenced from required .class files [message #590882 is a reply to message #42998] Sat, 31 January 2009 22:31 Go to previous message
- Prakash
> and others
> error messages.
> Thanks
Previous Topic:Web Start Eclipse Platform failing
Next Topic:Web Start Eclipse Platform failing
Current Time: Wed Jul 23 05:58:16 EDT 2025
Powered by FUDForum. Page generated in 0.28280 seconds
