Home » Eclipse Projects » Remote Application Platform (RAP) » An entry point named 'default' does not exists
An entry point named 'default' does not exists [message #3721] Sat, 24 February 2007 10:47 Go to next message
Originally posted by: uprushworld.yahoo.co.jp
Hi:
I started the server successful, but when i access
"http://localhost/rap", an error comes like this. Waiting for your help.
java.lang.IllegalArgumentException: An entry point named 'default' does
not exists.
org.eclipse.rap.rwt.internal.lifecycle.EntryPointManager.cre ateUI(EntryPointManager.java:70)
org.eclipse.rap.rwt.internal.lifecycle.PrepareUIRoot.execute (PrepareUIRoot.java:32)
org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.execute( RWTLifeCycle.java:60)
at com.w4t.engine.W4TModel$ServiceAdapter.execute(W4TModel.java :47)
com.w4t.engine.service.FormRequestServiceHandler.service(For mRequestServiceHandler.java:65)
com.w4t.engine.service.ServiceManager$HandlerDispatcher.serv ice(ServiceManager.java:90)
at com.w4t.engine.W4TDelegate.doPost(W4TDelegate.java:75)
org.eclipse.rap.ui.internal.servlet.RequestHandler.service(R equestHandler.java:41)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:129)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:91)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:110)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:60)
org.eclipse.equinox.http.jetty.internal.Activator$InternalHt tpServiceServlet.service(Activator.java:182)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
2007/02/25 0:23:05 org.mortbay.jetty.servlet.ServletHandler handle
Thank you.
Best wishes.
Re: An entry point named 'default' does not exists [message #4096 is a reply to message #3721] Mon, 26 February 2007 06:53 Go to previous message
Originally posted by: rherrmann.innoopract.com
we assume that You installed the M1 release, that unfortunately comes
with a pitfall. In order to run the demo You also need to install the
'RAP Source Plug-in' feature.
Please let us know if that doesn't solve Your problem.
RAP Team
uprush wrote:
> Hi:
> not exists.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thank you.
> Best wishes.
Previous Topic:First milestone released
Next Topic:Images in TreeViewer
Current Time: Tue Jul 15 03:16:10 EDT 2025
Powered by FUDForum. Page generated in 0.03381 seconds
