Re: Basic validation [message #427368] |
Sat, 14 February 2009 13:17 |
Ed Merks Messages: 33141 Registered: July 2009 |
Adrian,
Please use the EMF newsgroup, which I've included in the "to" list of
the reply, for asking questions about EMF.
Yes, it's possible to create a circular containment. We should ensure
that this doesn't break EcoreUtil.getURI with an out of memory exception
and should ensure that the Diagnostician diagnoses it rather then stack
overflowing. Please open an EMF bugzilla and I'll look into addressing
both issues.
Adrian Rutle wrote:
> Hi
> I want to learn how to validate Ecore models against basic constraints
> such as multiplicity and containment. I have created a simple Ecore
> model and generated code for it (attached). I have also written a test
> class to populate the model programmatically (attached).
> Have I done everything correct? If yes, why the validation of "re"
> returns true even though I have a cyclic containment: c1 contains e1 and
> e1 contains c1.
> I have also generated the edit and editor plugins. When I run the editor
> plugin, I still can create cyclic containment without getting any
> validation problems. However, I think in that case the names of the
> objects are not considered as identifiers.
> Best regards
> Adrian
Ed Merks
Re: Basic validation [message #427370 is a reply to message #427368] |
Sat, 14 February 2009 14:37 |
Adrian Rutle Messages: 20 Registered: July 2009 |
Junior Member |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Ed Merks wrote:
> Adrian,
Thanks, and sorry about this, I must have overseen the "to" field when I
sent the email ;-/
> both issues.
A bug is reported. I assume the methods which I use to validate the
model are two of many existing validation methods, however, I am not
sure whether I have chosen the best way validate my model. Any comments
about this?
Best regards
Adrian
> Adrian Rutle wrote:
>> Hi
>> e1 contains c1.
>> Best regards
>> Adrian
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.9 (GNU/Linux)
Comment: Using GnuPG with SUSE - http://enigmail.mozdev.org
iEYEARECAAYFAkmW1zoACgkQtwhuhvDfdhiHOgCdGv4D00ZydTEBxaYKzLjw T2DH
VhEAn3bRpTjJimmPs4Xh+EvHil0TucUF
=GB+e
-----END PGP SIGNATURE-----
Re: Basic validation [message #427372 is a reply to message #427370] |
Sat, 14 February 2009 17:59 |
--------------010808000803090908030104
Adrian,
Diagnostician.INSTANCE.validate is the best way. Using model specific
ones like EcoreValidator isn't generally a good idea because your actual
object might be of a derived class from another package...
> Hash: SHA1
> Ed Merks wrote:
>> Adrian,
> sent the email ;-/
>> both issues.
> about this?
> Best regards
> Adrian
>> Adrian Rutle wrote:
>>> Hi
>>> e1 contains c1.
>>> Best regards
>>> Adrian
> =GB+e
<html>
<head>
</head>
Adrian,<br>
<br>
actual object might be of a derived class from another package...<br>
<br>
<br>
Adrian Rutle wrote:
<blockquote cite="mid:gn6l0f$ud8$1@build.eclipse.org" type="cite">
<pre wrap="">-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Adrian,
</pre>
</blockquote>
<pre wrap=""><!---->Thanks, and sorry about this, I must have overseen the "to" field when I
sent the email ;-/
</pre>
<pre wrap="">Yes, it's possible to create a circular containment. We should ensure
both issues.
</pre>
</blockquote>
about this?
Best regards
Adrian
</pre>
<pre wrap="">
Adrian Rutle wrote:
</pre>
<pre wrap="">Hi
e1 contains c1.
Best regards
Adrian
</pre>
</blockquote>
</blockquote>
Comment: Using GnuPG with SUSE - <a class="moz-txt-link-freetext" href="http://enigmail.mozdev.org">http://enigmail.mozdev.org</a>
=GB+e
</pre>
</blockquote>
</body>
</html>
--------------010808000803090908030104--
Ed Merks
FUDForum. Page generated in 0.10869 seconds
