Home » Eclipse Projects » Plugin Development Environment (PDE) » How to reuse the errorlog view ???
How to reuse the errorlog view ??? [message #42936] Thu, 29 January 2009 05:11 Go to next message
Is is possible to reuse the errorlog view?
I have a xml file which need to be populated in a view, as in error log
view. I can parse the xml file and send the parameters as per the error
log view needs. Any help on this will be really useful.
Ganeshraj.S
Re: How to reuse the errorlog view ??? [message #42968 is a reply to message #42936] Thu, 29 January 2009 09:32 Go to previous message
Originally posted by: jacek.pospychala.pl.ibm.com
Ganeshraj.S,
that's not possible with current error log implementation. You could
however create your own very similar plug-in and modify the default log
parser with your own. You may also need to better adjust view's columns.
Finally, feel free to create an enhancement request for a customizable
error log view at https://bugs.eclipse.org/bugs/enter_bug.cgi?product=PDE
GaneshrajS pisze:
> Ganeshraj.S
Re: How to reuse the errorlog view ??? [message #590703 is a reply to message #42936] Thu, 29 January 2009 09:32 Go to previous message
Ganeshraj.S,
GaneshrajS pisze:
> Ganeshraj.S
Previous Topic:How to reuse the errorlog view ???
Next Topic:Problem : Indirect referenced from required .class files
Current Time: Wed Jul 16 08:33:55 EDT 2025
Powered by FUDForum. Page generated in 0.32996 seconds
