Schema diagnostics [message #42914] |
Fri, 30 April 2004 06:15  |
Originally posted by: invalid.soft-gems.net
Hi group,
I'm trying currently to get diagnostics information as described in the
FAQs but somehow I've got the feeling they do not work as expected. What I
have is an xsd file, which includes 3 other schemas. I made one of the
references invalid (non-existing file) and expected to find an entry
telling me about a missing reference but the diagnostic information from
my main schema is empty.
Additionally, XML Spy reports an error in one of my included schemas,
which I would expect to be reported too, but which also not appears.
Btw., may I ask an slightly off-topic question? Why does XML Spy consider
the following text invalid?
<xs:schema targetNamespace="http://msgax1i.msg.de/afis/odie"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns="http://msgax1i.msg.de/afis"
xmlns:io="http://msgax1i.msg.de/afis/io"
xmlns:layout="http://msgax1i.msg.de/afis/layout"
xmlns:local="http://msgax1i.msg.de/afis/localization"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:annotation>
<xs:documentation xml:lang="de">
Copyright 2004 msg systems ag. All rights reserved.
</xs:documentation>
</xs:annotation>
<xs:element name="td" type="tdType"/>
<xs:complexType name="tdType">
<xs:attribute name="colspan" type="xs:positiveInteger" default="1"/>
</xs:complexType>
<xs:element name="table" type="tableType" substitutionGroup="td"/>
<xs:complexType name="tableType">
<xs:complexContent>
=====> Error message here: undefined value for 'base' encountered.
=====> tdType is defined just a couple lines above.
<xs:extension base="tdType">
<xs:sequence>
<xs:element ref="tr" maxOccurs="unbounded"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
<xs:element name="tr" type="trType"/>
<xs:complexType name="trType">
<xs:sequence>
<xs:element ref="td" minOccurs="0" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
For me it looks ok, however I'm a beginner with XML Schemas so I likely
overlooked an important part.
Mike
www.soft-gems.net
Re: Schema diagnostics [message #43059 is a reply to message #42976] |
Fri, 30 April 2004 09:39  |
Mike,
You're welcome. I just don't give other people much of a chance, do I. ;-)
Mike Lischke wrote:
> Ed Merks wrote:
> > Mike,
> > Have a look at XSDMainTest and how it implements -validate to walk all the
> > resources to find all the schemas to report all the errors. The
> > XSDSchema.getAllDiagnostics method will only get the diagnostics that apply
> to
> > components directly contained by that schema; the included and imported
> schemas
> > are in separate resources and have their own lists of diagnostics.
> > You left "odie" out of your xmnls=".../odie"; I assume it should match your
> > target namespace.
> I should tell you how much I appreciate your help, Ed. Thank you very
> much. It appears you are almost the only one replying to the questions in
> this group. Excellent work!
> Mike
> www.soft-gems.net
Re: Schema diagnostics [message #586384 is a reply to message #42914] |
Fri, 30 April 2004 07:58  |
Mike,
XSDSchema.getAllDiagnostics method will only get the diagnostics that apply to
components directly contained by that schema; the included and imported schemas
target namespace.
Mike Lischke wrote:
> Hi group,
> <xs:annotation>
> </xs:documentation>
> </xs:annotation>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> Mike
> www.soft-gems.net
Re: Schema diagnostics [message #586395 is a reply to message #42945] |
Fri, 30 April 2004 08:49  |
Ed Merks wrote:
> Mike,
to
schemas
> target namespace.
Mike
www.soft-gems.net
Re: Schema diagnostics [message #586424 is a reply to message #42976] |
Mike,
Mike Lischke wrote:
> Ed Merks wrote:
> > Mike,
> to
> schemas
> > target namespace.
> Mike
> www.soft-gems.net
FUDForum. Page generated in 0.04239 seconds
