Home » Language IDEs » AspectJ » CodeAssist auto activation does not work.
CodeAssist auto activation does not work. [message #42913] Fri, 15 October 2004 07:47 Go to next message
When using the AspectJ/Java Editor the CodeAssist auto-activation
does not work. I always have to hit Ctrl-Space to call up the
CodeAssist (so the CodeAssist itself seems to work), even though
I have enabled Auto activation, I have set a delay of only
100 and I have specified an activation character ('.').
I thought that I read, that CodeAssist AutoActivation should be
working in this version (AspectJ version 1.2.0.20041013155315)
Michael
Re: CodeAssist auto activation does not work. [message #42944 is a reply to message #42913] Fri, 15 October 2004 08:31 Go to previous message
> Michael
Hi Michael,
I'm not sure we specifically said that AutoActivation should be working -
the new and noteworthy mentions that content assist now works in a number
of cases, as does code assist for thisJoinPoint and
thisJoinPointStaticPart. We do, however, fail to say whether this is by
using Ctrl + Space or auto activation or both :-) It's good that that the
code completion is working for you, even if auto activation isn't!
There is a bug already open covering code completion (74419). If you think
what you're seeing is relevant to this, could you add comments here. It
might, however, be better to raise a new bug for this.
Thanks, Helen
Re: CodeAssist auto activation does not work. [message #584251 is a reply to message #42913] Fri, 15 October 2004 08:31 Go to previous message
> Michael
Hi Michael,
Thanks, Helen
Previous Topic:CodeAssist auto activation does not work.
Next Topic:Plugin and Fragment with AspectJ
Current Time: Tue Jul 15 12:09:31 EDT 2025
Powered by FUDForum. Page generated in 0.85994 seconds
