Home » Eclipse Projects » SWTBot » Target Executable from the Command Line
Target Executable from the Command Line [message #42907] Fri, 10 July 2009 13:04 Go to next message
I have been using SWTBot successfully for the past few weeks and am now
trying to get my tests running from the command line. I am trying to get
my tests to run on an executable file but adding the path of this file to
the -application flag doesn't work. How can I an executable file from the
command line.
-Mike
Re: Target Executable from the Command Line [message #43000 is a reply to message #42907] Fri, 10 July 2009 17:03 Go to previous messageGo to next message
> to the -application flag doesn't work. How can I an executable file from
> the command line.
http://wiki.eclipse.org/SWTBot/Ant
And a new video someone contributed a few days ago:
http://download.eclipse.org/technology/swtbot/docs/videos/be ginners/SWTBotHeadlessTestingForNovices/
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
Re: Target Executable from the Command Line [message #43167 is a reply to message #43000] Mon, 13 July 2009 13:16 Go to previous messageGo to next message
Great,
Thanks for your help. I found the web page somewhat confusing, but the
video explains things very well.
Re: Target Executable from the Command Line [message #43270 is a reply to message #43167] Mon, 13 July 2009 20:24 Go to previous messageGo to next message
Ketan,
So I have followed your tutorials for ant and I got my ant build to work,
but whenever I run the ant script from the command line it opens eclipse
and not my custom product. Below is my build file:
<?xml version="1.0" encoding="UTF-8" ?>
<project name="testsuite" default="run" basedir=".">
<property name="eclipse-home" value="C:\eclipse" />
<property name="plugin-name" value="test.eclipse.swt" />
<property name="test-classname"
value="test.eclipse.swt.simple.FooBarTest" />
<property name="library-file"
value=" ${eclipse-home}/plugins/org.eclipse.swtbot.eclipse.junit4.he adless_2.0.0.368-dev/library.xml "
<target name="suite">
<property name="jvmOption" value=""></property>
<property name="temp-workspace" value="workspace" />
<delete dir="${temp-workspace}" quiet="false" />
<ant target="swtbot-test" antfile="${library-file}"
dir="${eclipse-home}" >
<property name="data-dir" value="${temp-workspace}" />
<property name="plugin-name" value="${plugin-name}" />
<property name="os" value="win32" />
<property name="ws" value="win32" />
<property name="arch" value="x86" />
<property name="classname" value="${test-classname}" />
<property name="vmargs" value=" -Xms128M -XX:MaxPermSize=512m -Xmx512M
${jvmOption}" />
</ant>
</target>
<target name="cleanup" />
<target name="run" depends="suite,cleanup">
</target>
</project>
How can I get this script to open up a custom product. Even when I add the
following line nothing changes.
<property name="product" value="com.fnfr.svt.editions.team.iTest_team" />
Do you have any idea what I could be doing wrong?
- Mike
Re: Target Executable from the Command Line [message #43310 is a reply to message #43270] Tue, 14 July 2009 00:34 Go to previous messageGo to next message
This one seems to have slipped my mind. I've filed a bug to remind
myself about it. Add yourself to cc to be notified when it gets fixed
(should be a couple of days)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=283370
Ketan
On 14/7/09 05:54, Michael Wiederhold wrote:
> Ketan,
> work, but whenever I run the ant script from the command line it opens
> eclipse and not my custom product. Below is my build file:
> <ant target="swtbot-test" antfile="${library-file}" dir="${eclipse-home}" >
> ${jvmOption}" />
> </ant>
> </target>
> </target>
> </project>
> the following line nothing changes.
> - Mike
Re: Target Executable from the Command Line [message #43333 is a reply to message #43310] Tue, 14 July 2009 02:29 Go to previous messageGo to next message
Here's a temporal workaround until the next build:
- download the library.xml[1] file to your .headless plugin
- in your ant script where you specify properties passed to the
'swtbot-test' target, add another property called 'testApplication' or
'testProduct' that point to the product or application id.
http://github.com/ketan/swtbot/blob/44233b4a4ea6dc9362ef8759 a54bbcaa2af2e37c/org.eclipse.swtbot.eclipse.junit4.headless/ library.xml
Ketan
Re: Target Executable from the Command Line [message #43695 is a reply to message #43333] Thu, 16 July 2009 13:20 Go to previous messageGo to next message
Ketan,
Thanks for filing the bug and getting around to fixing it so quickly. I
downloaded yur new library.xml script but I am still having problems.
Below is my update script.
value="C:\Clister\trunk/../junit-workspace" />
<property name="testProduct"
<property name="nl" value="en_US" />
${jvmOption}" />
</ant>
</target>
</target>
</project>
When I run this script the same thing happens as before. Eclipse is
launched and my test fails because my actual product did not launch. In
the results folder there is a file that contains error messages and after
the header information the first error is:
!ENTRY org.eclipse.equinox.app 0 0 2009-07-16 10:15:02.423
!MESSAGE Product com.fnfr.svt.editions.team.iTest_team could not be found.
Application Started: 12262
When I run the test from inside eclipse everything works fine, but on the
command line it seems that my product can suddenly not be found. Do you
have any idea why I am still getting error messages?
Below I am also attaching the command line argument that eclipse uses to
run my test:
"C:\Program Files\Java\jre6\bin\javaw.exe"
-agentlib:jdwp=transport=dt_socket,suspend=y,address=localho st:1142
-Xmx384M -Dfile.encoding=UTF-8 -XX:PermSize=64M -XX:MaxPermSize=128M
-classpath
C:\eclipse\plugins\org.eclipse.equinox.launcher_1.0.101.R34x _v20080819.jar
org.eclipse.equinox.launcher.Main -launcher C:\eclipse\eclipse.exe -name
Eclipse -showsplash 600 -product com.fnfr.svt.editions.team.iTest_team
-data C:\Clister\trunk/../runtime-team.product -configuration
file:C:/Clister/trunk/.metadata/.plugins/org.eclipse.pde.cor e/team.product/
-dev
file:C:/Clister/trunk/.metadata/.plugins/org.eclipse.pde.cor e/team.product/dev.properties
-os win32 -ws win32 -arch x86 -nl en_US
Thanks for your help,
- Mike
Re: Target Executable from the Command Line [message #43718 is a reply to message #43695] Thu, 16 July 2009 14:22 Go to previous messageGo to next message
On 16/7/09 22:50, Michael Wiederhold wrote:
> Ketan,
<snipped/>
> after the header information the first error is:
> the command line it seems that my product can suddenly not be found. Do
> you have any idea why I am still getting error messages?
> run my test:
The bootstrap application that is launched from within eclipse is
different from the one launched from within ant. The difference being
the way they report junit results -- one writes back results via a
socket to eclipse. The other writes it to a file.
Having said that, could you try using testApplication instead of
testProduct to see if that works for you.
Ketan
Re: Target Executable from the Command Line [message #43784 is a reply to message #43718] Thu, 16 July 2009 15:47 Go to previous messageGo to next message
I have tried that already below is the result:
!ENTRY org.eclipse.osgi 4 0 2009-07-16 12:44:34.438
!MESSAGE Application error
!STACK 1
junit.framework.AssertionFailedError: null
A mixture of both testProduct and testApplication also produces the same
result. Any other ideas?
Thanks again,
- Mike
Re: Target Executable from the Command Line [message #43841 is a reply to message #43718] Thu, 16 July 2009 17:57 Go to previous messageGo to next message
Ketan,
I made the neccesary changes and tried the build script with the
testApplication property as well as a mixture of both testProduct and
testApplication. When I ran these tests both failed and gave me an error:
!ENTRY org.eclipse.osgi 4 0 2009-07-16 12:46:45.604
!STACK 1
Any other ideas on what my problem may be.
- Mike
Re: Target Executable from the Command Line [message #43903 is a reply to message #43841] Fri, 17 July 2009 02:08 Go to previous messageGo to next message
Hi Mike,
I've pushed a new build with this change, please pull in the new build
and reopen the bug if the problem still persists.
Ketan
On 17/7/09 03:27, Michael Wiederhold wrote:
> Ketan,
> !STACK 1
> - Mike
Re: Target Executable from the Command Line [message #44363 is a reply to message #43903] Mon, 20 July 2009 19:40 Go to previous messageGo to next message
Ketan,
This still didn't fix the problem. I tried to re-open the bug, but I think
I need to be a commiter to the project in order to do that so could you
reopen the bug for me. Thanks again for all your help.
- Mike
Re: Target Executable from the Command Line [message #44396 is a reply to message #42907] Mon, 20 July 2009 20:41 Go to previous messageGo to next message
Hi Michael,
I have worked on a similar task and am able to launch my test cases from
cmd line using ant against my eclipse rcp application. I tried using the
wiki, but I was not able to get it to work with the packages available, so
I found an older post by Hans,
http://swtbot.org/bugzilla/show_bug.cgi?id=76 , that I used as a base to
get my test cases to run. I don't know how Keaton feels about this
approach, all I am saying is that it works correctly. Here is the step by
step:
Machine preperation
1. Download apache-ant-1.7.0/ and pde.test.utils.jar from the internet
2. Put the apache-ant-1.7.0/ on your root drive
3. Update your PATH enviornment variable to have an entry that points
to apache-ant-1.7.0/bin
4. Download Eclipse RCP (for plugin developers) from eclipse.org and
unzip it to your root directory
5. put the pde.test.utils.jar file into the eclipse/plugins directory
of the ECLIPSE INSTANCE YOU DOWNLOADED IN STEP 4
6. Go to the eclipse/plugins directory of the ECLIPSE APPLICATION THAT
YOU WISH TO TEST (different then eclipse instance in step 5). In the
plugins dir, create a new dir called reports/
7. In the reports dir, create 2 files, one called demotest.txt and the
other called demotest.err.txt
8. Copy the build.xml file (posted at the end of this response, update
the fields to reflect your product.
9. Make sure your Java_Home env variable points to your JDK
Incase you wonder why you have the additional eclipse for pde.utils.jar,
it's becuase of what Keaton said about getting the results using an open
socket.. technically, a different eclipse is not requiered, but this was
the easiest way for me to do it.
Application under test setup
1) If your AUT is a simple eclipse instance that could be unzipped and
launched (such as what you download from eclipse.org, or developer builds
of the application)
* Go to your workspace where your test plugins are. Make sure they run
using the GUI.
* Select all the plugins that your test cases require
* Right click and select export.
* Copy the exported plugins to the <AUT Directory>/eclipse/plugins
directory
Running your tests from CMD line
* Bring up the command window
* Go the the AUT/eclipse/plugins directory (where the build.xml file
is located)
* Type "ant test"
Results
* An xml file will be generated in the AUT/eclipse/plugins dir that
will say which tests ran with what results.
* In AUT/eclipse/plugins/reports/ there will be two files,
demotest.txt and demotest.err. There will be some useful logging
information in these files as well
* In demotest.txt toward the bottom there will be a line that has a
summary of how many tests passed and failed.
Here is my build.xml file. Some of the initial properties are not used at
all, but I still tend to udpate them.. Here are some comments on things
you need to edit:
-classNames is your test class name.. I point it to my test suite.
-testpluginname is the plugin name that has the class in classNames
-product is the product that I want to launch
-data is the execution workspace
make sure to update the <fileset dir> in the first target to point to your
AUT's plugins dir (where the equinox.launcher is)
in the listen target, the first <arg line=> should point to your test
plugin (on port 2625)
In the listen target, the first and third <fileset dir> commands need to
point to the eclipse rcp that has your pde.util.jar plugin.
(NOTE: IF YOU DO NOT KNOW WHAT SOME OF THE PARAMETERS ARE FOR THE
BUILD.XML, HERE IS A GOOD TIP... run your test cases from the eclipse UI,
and put a break point in the first line of your test case. In the debug
perspective and debug view (the one in the top left) right click on the
thread the swtbot thread and select properties, and it will give you the
command that was used to run your tests... in this command, you can find
all the properties you want)
Hope this helps, post replies here and I'll continue to check if you need
more help.
Jack
build.xml
<project name="thirdparty-test" basedir=".">
<!-- ignore these variables -->
<property name="test.workspace"
location="C:\ODA\workspaces\junit-workspace"/>
<property name="testcase" location="BackupConnectedTest"/>
<property name="testplugin"
location="com.ibm.datatools.adm.db2.luw.swbtest.ui"/>
<property name="build.home" location="C:\Program Files\IBM\ODS2.2"/>
<property name="build.plugins" location="${build.home}/plugins"/>
<property name="java.home" location="C:\Program
Files\IBM\ODS2.2\jdk"/>
<property name="ant.home" location="C:\apache-ant-1.7.1\bin"/>
<!-- end ignore these variables -->
<target name="test">
<parallel>
<daemons>
<antcall target="listen" />
</daemons>
<sequential>
<sleep seconds="10" />
<!-- Give the listener a few seconds to startup -->
<antcall target="execute" />
</sequential>
</parallel>
</target>
<target name="execute">
<echo>Debut target execute</echo>
<!--echo>${test.workspace}</echo-->
<!--delete dir="${test.workspace}" />
<mkdir dir="${test.workspace}" /-->
<!-- -classpath
/plugins/org.eclipse.equinox.launcher_1.0.101.R34x_v20080819 .jar
org.eclipse.core.launcher.Main equinox" dir="${build.home}"-->
<java classname="org.eclipse.core.launcher.Main" fork="true"
output="reports/demotest.txt" error="reports/demotest.err.txt">
<!--append="true"-->
<!--arg line="-Xms128M -Xmx368M -XX:MaxPermSize=256M" /-->
<arg line="-os win32" />
<arg line="-ws win32" />
<arg line="-arch x86" />
<arg line="-nl en_US" />
<arg line="-application" />
<arg line="org.eclipse.swtbot.eclipse.core.swtbottestapplication " />
<arg line="-classNames" />
<arg
line=" com.ibm.datatools.adm.db2.luw.swbtest.ui.ConnectedTaskAssist antGenericTestSuite "
<arg line="-testpluginname" />
<arg line="com.ibm.datatools.adm.db2.luw.swbtest.ui" />
<arg line="-version" />
<arg line="3" />
<arg line="-testLoaderClass" />
<arg line="org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader " />
<arg line="-loaderpluginname" />
<arg line="org.eclipse.jdt.junit4.runtime" />
<arg line="-product" />
<arg line="com.ibm.datastudio.administrator.product.ide" />
<arg line="-port" />
<arg line="2625" />
<arg line="-pdelaunch" />
<arg line="-data" />
<arg line="C:\ODA\workspaces\junit-workspace" />
<arg line="-debug" />
<arg line="-consolelog" />
<classpath>
<fileset dir="C:\Program Files\IBM\ODS2.2\plugins">
<include name="org.eclipse.equinox.launcher_*.jar" />
</fileset>
</classpath>
</java>
</target>
<target name="listen">
<echo>Debut target listen</echo>
<java classname="pde.test.utils.PDETestResultsCollector">
<arg line="com.ibm.datatools.adm.db2.luw.swbtest.ui 2625" />
<classpath>
<fileset dir="C:\ODA\eclipse-rcp\plugins">
<include name="*.jar" />
</fileset>
<fileset dir="${java.home}/lib">
<include name="**/*.jar" />
</fileset>
</fileset>
</fileset>
</classpath>
</java>
</target>
</project>
Re: Target Executable from the Command Line [message #45041 is a reply to message #44396] Wed, 22 July 2009 19:55 Go to previous message
Thanks for the help. I went through what you have written and have made
the necessary changes to your script to allow it to work with my product.
When I run it however I get a product not found error. I am attaching my
script as well as the beginning of the error log. Any ideas?
<echo>Vars</echo>
location="C:\Clister\trunk/../junit-workspace"/>
<property name="testcase" location="FooBarTest"/>
<property name="testplugin" location="test.eclipse.swt"/>
<property name="build.home" location="C:\eclipse"/>
<property name="java.home" location="C:\Program Files\Java\jre6"/>
<property name="ant.home" location="C:\ant-1.7.1\bin"/>
<parallel>
<daemons>
</daemons>
<sequential>
</sequential>
</parallel>
</target>
<echo>Debug target execute</echo>
<!-- -classpath
<arg line="test.eclipse.swt.simple.FooBarTest" />
<arg line="test.eclipse.swt" />
<arg line="3" />
<arg line="com.fnfr.svt.editions.team.iTest_team" />
<arg line="2625" />
<arg line="C:\Clister\trunk/../junit-workspace" />
<classpath>
<fileset dir="C:\eclipse\plugins">
</fileset>
</classpath>
</java>
</target>
<arg line="test.eclipse.swt.simple.FooBarTest 2625" />
<classpath>
<fileset dir="C:\commandplugins\plugins">
</fileset>
<fileset dir="${java.home}\lib">
</fileset>
</fileset>
</fileset>
</classpath>
</java>
</target>
</project>
Install location:
file:/c:/eclipse/
Configuration file:
file:/c:/eclipse/configuration/config.ini loaded
Configuration location:
Framework located:
file:/c:/eclipse/plugins/org.eclipse.osgi_3.4.2.R34x_v200808 26-1230.jar
Framework classpath:
Debug options:
file:/C:/.options not found
Time to load bundles: 15
Starting application: 1016
!SESSION 2009-07-22 16:49:57.437
eclipse.buildId=M20080911-1700
java.version=1.6.0_13
Framework arguments: -classNames test.eclipse.swt.simple.FooBarTest
-testpluginname test.eclipse.swt -application
org.eclipse.swtbot.eclipse.core.swtbottestapplication -version 3
-testLoaderClass org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader
-loaderpluginname org.eclipse.jdt.junit4.runtime -product
com.fnfr.svt.editions.team.iTest_team -port 2625 -pdelaunch
Command-line arguments: -os win32 -ws win32 -arch x86 -classNames
test.eclipse.swt.simple.FooBarTest -testpluginname test.eclipse.swt
-application org.eclipse.swtbot.eclipse.core.swtbottestapplication
-version 3 -testLoaderClass
org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader -loaderpluginname
com.fnfr.svt.editions.team.iTest_team -port 2625 -pdelaunch -data
C:\Clister\trunk/../junit-workspace -debug -consolelog
!ENTRY org.eclipse.equinox.app 0 0 2009-07-22 16:49:58.656
Application Started: 5563
!ENTRY org.eclipse.osgi 4 0 2009-07-22 16:50:04.375
!MESSAGE An error occurred while automatically activating bundle
com.fnfr.svt.configuration (275).
!STACK 0
org.osgi.framework.BundleException: Exception in
com.fnfr.svt.configuration.ConfigurationPlugin.start() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
- Mike
Previous Topic:How to test the ControlDecoration?
Next Topic:SWTBotToolbarButton click does not depress the button on the menubar
Current Time: Tue Jul 15 04:27:35 EDT 2025
Powered by FUDForum. Page generated in 0.07867 seconds
