Re: UnRegistered Package Predicament [message #426481 is a reply to message #426475] |
Wed, 07 January 2009 20:08 |
Geoffry,
I'm really not sure about the nature of your effort, but some words in
your note made me think that the CDO model repository and distributed
shared model framework could help you. Perhaps our approach to send
ad-hoc models and meta models through the wires (and store them in a
central repository) could be helpful for you. You could have a look at
our wiki: http://wiki.eclipse.org/CDO
Please tell me if you are interested and nedd more infos...
Cheers
/Eike
Geoffry Roberts schrieb:
> All,
> Is there any way to register a package if all one has available is
> either the nsURI or the fully qualified class name of a class in the
> package?
> A situation has reared its ugly head and I am at bit of a loss as to
> what to do.
> I am transporting emf models between computers by serializing them
> into strings and shooting them through the wire. This all works well
> enough until it comes time to deserialize them back into emf. On
> occasion--and this is one of those intermittent things--the
> deserialize fails because the package has not yet been registered. I
> need a way to force a registration when the critical moment arises.
> Here's is what I have to work with: A java.lang.Class of the emf
> object and that's it! I can use the class name to determine the
> nsURI. I can also assemble a qualified name of the package for the
> class in question. This is possible because of the naming
> conventions I have adopted, but I am less than sanguine about going
> this route. Heaven help me if I break those conventions.
> Thanks
Cheers
/Eike
http://www.esc-net.de
Re: UnRegistered Package Predicament [message #426488 is a reply to message #426482] |
Thu, 08 January 2009 04:54 |
Geoffry,
Yes, it does not describe completely what CDO can do, but it can
basically do what Teneo can. We even have one kind of backend
integration that is based on Teneo. From this perspective one could say
that CDO adds a network distribution layer between Teneo/Hiobernate/DB
and EMF.
Cheers
/Eike
> Eike Stepper wrote:
>> Geoffry,
>> in your note made me think that the CDO model repository and
>> distributed shared model framework could help you. Perhaps our
>> approach to send ad-hoc models and meta models through the wires (and
>> store them in a central repository) could be helpful for you. You
>> could have a look at our wiki: http://wiki.eclipse.org/CDO
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>>> All,
>>> package? A situation has reared its ugly head and I am at bit of a
>>> loss as to what to do.
>>> well enough until it comes time to deserialize them back into emf.
>>> On occasion--and this is one of those intermittent things--the
>>> I need a way to force a registration when the critical moment arises.
>>> Thanks
> I noticed CDO sometime back but have had neither the time nor mental
> bandwidth to dig into it. Tell me this, can it do what teneo does?
Cheers
/Eike
FUDForum. Page generated in 0.04106 seconds
