Home » Eclipse Projects » Nebula » Listener for resize and moving of columns in grid view
Listener for resize and moving of columns in grid view [message #42895] Wed, 07 November 2007 07:16 Go to next message
I have to get the width of a column in the grid veiwer, whenever user
resizes it. And also i need to know the order of columns when the columns
are moved.
For column order I tried with dragdetect listener but it is fired when
there is a drag of column, not when there is a drop after drag! I need the
order of columns after the drop not on drag.
Can anyone please tell me how or what type of event I could get on resize
and move operation done on columns?
Supreetha H R
Re: Listener for resize and moving of columns in grid view [message #42928 is a reply to message #42895] Wed, 07 November 2007 07:54 Go to previous messageGo to next message
Hi Supreetha,
Just listen for SWT.Move and SWT.Resize on each column.
-Chris
Supreetha H R wrote:
> Hello,
> columns are moved.
> the order of columns after the drop not on drag.
> resize and move operation done on columns?
> Supreetha H R
Re: Listener for resize and moving of columns in grid view [message #500258 is a reply to message #42928] Wed, 25 November 2009 09:14 Go to previous messageGo to next message
Hi Chris,
The problem is that SWT.Move is also fired when the column is resized.
So is there a way to listen only to the drop (actual move) of the column?
thks,
André
Re: Listener for resize and moving of columns in grid view [message #586218 is a reply to message #42895] Wed, 07 November 2007 07:54 Go to previous messageGo to next message
Hi Supreetha,
-Chris
> Hello,
> columns are moved.
> Supreetha H R
Re: Listener for resize and moving of columns in grid view [message #598702 is a reply to message #42928] Wed, 25 November 2009 09:14 Go to previous message
Hi Chris,
thks,
André
Previous Topic:Rich text editor widget
Next Topic:Grid - using the Selection Service
Current Time: Wed Jul 16 01:40:49 EDT 2025
Powered by FUDForum. Page generated in 0.21957 seconds
