Home » Modeling » OCL » OCL to constrain the use of an association
OCL to constrain the use of an association [message #42875] |
Mon, 05 November 2007 14:37  |
Originally posted by: bastian.merches.web.de
I've modeled an UML-Profile with a stereotype <<employs>>, which extends
UML Association, and a stereotype <<hierarchy>>, which extends UML Class.
Now I want to make sure, that the <<employs>> Association is only used
to connect <<hierarchy>> Elements.
I used OCL to write the constraints into the <<employs>> stereotype:
self.endType[0].stereotype.name='Hierarchy'
self.endType[1].stereotype.name='Hierarchy'
But when I try to validate a model I get the following error message:
Non-executabe:Semantic error::Violation of wellformedness rule:
Qualified navigation is not allowed if referred association end has no
qualifiers.
I don't know what it means.
How can I do this with OCL?
Thanks for your help!
Bastian
Re: OCL to constrain the use of an association [message #42906 is a reply to message #42875] |
Mon, 05 November 2007 15:33   |
Hi, Bastian,
Which OCL implementation are you using? I don't recognize the text of the
error message that you quoted.
However, the problem that you are confusing Java's array-indexing syntax
with OCL's collection-indexing. In OCL, [...] is used to specify qualifier
values for traversal of qualified associations. e.g.,
class Bank
property account[0..*] : Account
qualifier id : String
class Account
bank : Bank
can then do OCL constraints such as
context Bank
inv: self.account['00-0000-000'].oclIsUndefined()
to stipulate that an account with ID '00-0000-000' must not exist.
For your situation, you want something more like:
self.endType->at(0).stereotype.name='Hierarchy'
self.endType->at(1).stereotype.name='Hierarchy'
or, even better,
self.endType->forAll(stereotype.name='Hierarchy')
Of course, this is forgetting even that 'stereotype' is not a property of
the UML Element metaclass. In UML 2.x, you need to navigate metaclass
extensions:
self.endType->forAll(not extension_Hierarchy.oclIsUndefined())
HTH,
Christian
Bastian Merches wrote:
> Hello,
> qualifiers.
> Bastian
Re: OCL to constrain the use of an association [message #42937 is a reply to message #42906] |
Mon, 05 November 2007 16:17   |
Thanks for the quick response.
I'm going to try this.
I'm using OCL 2.0 within MagicDraw 12.0 Enterprise.
Unfortunatelly I'm very unexperienced in using OCL. I've got the
..stereotype notation from the MagicDraw Manual.
Thank you for the comprehensive description!
Christian W. Damus schrieb:
> Hi, Bastian,
> class Bank
> class Account
> bank : Bank
> context Bank
> or, even better,
> extensions:
> HTH,
> Christian
>> Hello,
>> qualifiers.
>> Regards,
>> Bastian
Re: OCL to constrain the use of an association [message #43191 is a reply to message #42937] |
Thu, 08 November 2007 11:02   |
I tried it and it didn't work because of special notation in MagicDraw.
Correct notation is:
self.endType->forAll(et| et.oclIsKindOf(hierarchy))
Thanks anyway!
>> Hi, Bastian,
>> the
>> qualifier
>> class Bank
>> class Account
>> bank : Bank
>> context Bank
>> or, even better,
>> extensions:
>> HTH,
>> Christian
>>> Hello,
>>> Class.
>>> qualifiers.
>>> Regards,
>>> Bastian
Re: OCL to constrain the use of an association [message #43224 is a reply to message #43191] |
Thu, 08 November 2007 12:14  |
Hi, Bastian,
Wow, so the semantics of stereotyping in this implementation of UML is
specialization, not extension? (the stereotyped element is a dynamically
generated metaclass specializing both the base metaclass and the
stereotype). Interesting.
cW
> Hello,
> Thanks anyway!
-----8<-----
Current Time: Wed Jul 16 12:34:20 EDT 2025
Powered by FUDForum. Page generated in 0.09678 seconds
