Home » Modeling » EMF » [CDO] CDO View throws OutOfMemoryError
[CDO] CDO View throws OutOfMemoryError [message #426107] Tue, 16 December 2008 10:00 Go to next message
I am using CDO 2.0.0M3. I tried to use CDO View to browse repository
content. After entering server address and pressing OK, it throws out of
memory error. Heap limit is 1024mb, before connecting it was using about
150mb. And repository database is empty.
Saulius
java.lang.OutOfMemoryError: Java heap space
org.eclipse.emf.cdo.spi.common.CDOIDLibraryDescriptorImpl.<init >(CDOIDLibraryDescriptorImpl.java:54)
org.eclipse.emf.cdo.common.id.CDOIDUtil.readLibraryDescripto r(CDOIDUtil.java:235)
org.eclipse.emf.internal.cdo.protocol.OpenSessionRequest.con firming(OpenSessionRequest.java:147)
org.eclipse.emf.internal.cdo.protocol.OpenSessionRequest.con firming(OpenSessionRequest.java:1)
org.eclipse.emf.internal.cdo.protocol.CDOClientRequest.confi rming(CDOClientRequest.java:103)
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedI nput(RequestWithConfirmation.java:118)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:317)
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(R equestWithConfirmation.java:98)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.jav a:68)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:237)
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:392)
org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:82)
org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:73)
org.eclipse.emf.internal.cdo.CDOSessionImpl.doActivate(CDOSe ssionImpl.java:808)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycl e.java:53)
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:69)
org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(Life cycleUtil.java:59)
org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:274)
org.eclipse.net4j.util.container.ManagedContainer.getElement (ManagedContainer.java:255)
org.eclipse.emf.cdo.internal.ui.actions.OpenSessionAction.do Run(OpenSessionAction.java:76)
org.eclipse.net4j.util.ui.actions.LongRunningAction$1.run(Lo ngRunningAction.java:164)
Re: [CDO] CDO View throws OutOfMemoryError [message #426113 is a reply to message #426107] Tue, 16 December 2008 12:23 Go to previous messageGo to next message
Saulius,
that looks really strange. Could you please provide more information
regarding the environment where you performed this action?
- How are you running CDOServer? Which backend are you using? Derby,
MySQL, PostgreSQL, Hibernate...
- Content of cdoserver.xml?
- Input values to the "open session" dialog (server description and
repository name fields)
Have you downloaded Net4J 2.0.0M3 as well?
Víctor.
Saulius Tvarijonas escribió:
> Saulius
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: [CDO] CDO View throws OutOfMemoryError [message #426137 is a reply to message #426107] Wed, 17 December 2008 03:22 Go to previous messageGo to next message
Saulius,
As Vik said, this is strange. And it will be hard to re-produce with
your exact code and setup. How much of it can you provide to us
(possibly via private email)?
Cheers
/Eike
Saulius Tvarijonas schrieb:
> of memory error. Heap limit is 1024mb, before connecting it was using
> about 150mb. And repository database is empty.
> Saulius
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [CDO] CDO View throws OutOfMemoryError [message #426138 is a reply to message #426137] Wed, 17 December 2008 03:31 Go to previous messageGo to next message
> [...] And it will be hard to re-produce with your exact code and
> setup. [...]
*without* ;-)
Re: [CDO] CDO View throws OutOfMemoryError [message #426139 is a reply to message #426113] Wed, 17 December 2008 03:33 Go to previous messageGo to next message
I am running CDOServer as plugin from my target platform. Which is
2.0.0M3. I have no problem with my application accessing server, so I
guess it should be something wrong on a client side. My cdo config is below.
I was not able to connect with negotiator enabled. Is CDO View supports
access with login/password?
I disabled negatiator and URL was tcp://localhost, Repository: repo1,
Autoregistry: false.
Build of CDO and Net4J I am running is 20081127. I believe it is M3.
Saulius
<cdoServer>
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
<negotiator type="challenge" description="users.txt"/>
</acceptor>
<repository name="repo1">
<property name="overrideUUID"
value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name="supportingAudits" value="true"/>
<property name="verifyingRevisions" value="false"/>
<property name="currentLRUCapacity" value="10000"/>
<property name="revisedLRUCapacity" value="100"/>
<store type="db">
<mappingStrategy type="horizontal">
<property name="qualifiedNames" value="true"/>
<property name="toManyReferences" value="ONE_TABLE_PER_REFERENCE"/>
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
</mappingStrategy>
<jdbcDelegate type="statement" />
<dbAdapter name="mysql"/>
<dataSource class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource" .../>
</store>
</repository>
</cdoServer>
On 12/16/2008 7:23 PM, Víctor Roldán Betancort wrote:
> Saulius,
> Cheers,
> Víctor.
>> Saulius
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: [CDO] CDO View throws OutOfMemoryError [message #426144 is a reply to message #426139] Wed, 17 December 2008 04:18 Go to previous messageGo to next message
--------------040202040403060707070008
Saulius,
Comments below..
> below.
If you're using any sort of negotiation you must usually ensure that the
INegotiators of both client and server side properly match together.
INegotiators are currently only supported by IConnectors. Since
server-side connectors are created by an IAcceptor you need to configure
the acceptor with the needed INegotiator so tat it can pass it down to
new connectors. If you do so you need to add a matching negotiator to
your client connector before connecting, too.
> Is CDO View supports access with login/password?
Not per view. But each view belongs to a session and this session has a
protocol and this protocol has a channel and this channel has a
connector and there we go ;-)
From a client point of view and with respect to negotiation the
protocol and channel are irrelevant (automatically created by the
session). Usually you create your session through CDOSessionConfiguration:
| // Prepare container
IManagedContainer container = ContainerUtil.createContainer();
Net4jUtil.prepareContainer(container); // Register Net4j factories
TCPUtil.prepareContainer(container); // Register TCP factories
CDOUtil.prepareContainer(container); // Register CDO factories
container.activate();
// Create connector
IConnector connector = TCPUtil.getConnector(container, "localhost:2036");
// Create configuration
CDOSessionConfiguration configuration = CDOUtil.createSessionConfiguration();
configuration.setConnector(connector);
configuration.setRepositoryName("repo1");
// Open session
CDOSession session = configuration.openSession();
session.getPackageRegistry().putEPackage(Model1Package.eINST ANCE);|
If you're pulling your client connector out of an IManagedContainer it
will already be connected. So you need to register a post processor with
the container to inject your negotiator into the connector *before* it
is returned. Please see also
http://wiki.eclipse.org/FAQ_for_CDO_and_Net4j#How_can_I_use_ authentication.3F
Cheers
/Eike
> Saulius
> <cdoServer>
> </acceptor>
> <store type="db">
> </mappingStrategy>
> <dataSource
> </store>
> </repository>
> </cdoServer>
Re: [CDO] CDO View throws OutOfMemoryError [message #426145 is a reply to message #426144] Wed, 17 December 2008 04:27 Go to previous messageGo to next message
Eike,
Sorry for confusing. When I wrote "CDO View" I mean CDO UI plugin :). I
understand CDOView interface. In my application we already have
authentication working with negotiator. So it is configured in my CDO
server and works from my client. I just wanted to know if CDO UI plugin
allows to connect to CDO server which is configured with negotiator.
Saulius
On 12/17/2008 11:18 AM, Eike Stepper wrote:
> Saulius,
> Comments below..
>> below.
> // Create connector
> // Open session
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> Saulius
>> <?xml version="1.0" encoding="UTF-8"?>
>> <cdoServer>
>> </acceptor>
>> <store type="db">
>> </mappingStrategy>
>> </store>
>> </repository>
>> </cdoServer>
>>> Saulius,
>>> Cheers,
>>> Víctor.
>>>> Hi,
>>>> Saulius
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: [CDO] CDO View throws OutOfMemoryError [message #426146 is a reply to message #426138] Wed, 17 December 2008 04:52 Go to previous messageGo to next message
I found problem. CDO UI and client were different. I guess differences
in CDO protocol caused OutOfMemoryError.
As I understand CDO & Net4J does not have functionality to check
protocol version. I understand that it is not possible for CDO Client
1.0.0 talk to CDO Server 2.0.0. But checking protocol versions could
help to handle such situations better. Instead of OutOfMemoryError it
could throw InvalidVersionException or something similar.
Saulius
>> setup. [...]
> *without* ;-)
Re: [CDO] CDO View throws OutOfMemoryError [message #426149 is a reply to message #426145] Wed, 17 December 2008 05:52 Go to previous messageGo to next message
Saulius,
The shipped user interface (i.e. CDOSessions view) creates sessions
through the IPluginContainer. So my explanations still apply ;-)
Cheers
/Eike
> Eike,
> I understand CDOView interface. In my application we already have
> plugin allows to connect to CDO server which is configured with
> negotiator.
> Saulius
>> Saulius,
>> Comments below..
>>> Hi,
>>> below.
>> // Create connector
>> "localhost:2036");
>> // Open session
>> Cheers
>> /Eike
>>> Saulius
>>> <cdoServer>
>>> </acceptor>
>>> <store type="db">
>>> </mappingStrategy>
>>> </store>
>>> </repository>
>>> </cdoServer>
>>>> Saulius,
>>>> Cheers,
>>>> Víctor.
>>>>> Hi,
>>>>> Saulius
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
Re: [CDO] CDO View throws OutOfMemoryError [message #426151 is a reply to message #426146] Wed, 17 December 2008 05:54 Go to previous messageGo to next message
Saulius,
I think protocol version checking is worth a bugzilla so that we don't
forget about ;-)
Cheers
/Eike
> Saulius
>>> setup. [...]
>> *without* ;-)
Re: [CDO] CDO View throws OutOfMemoryError [message #426156 is a reply to message #426149] Wed, 17 December 2008 08:45 Go to previous messageGo to next message
Eike,
As I understand CDOSessions View out of box is not able to connect to
repository with negotiator. Unless somebody else prepares
UPluginContainer before CDOSessions View tries to connect.
It would be nice if CDOSessions View automatically could inject
ConnectorCredentialsInjector depending on URL. For example
tcp://admin:admin@localhost.
Saulius
On 12/17/2008 12:52 PM, Eike Stepper wrote:
> Saulius,
> Cheers
> /Eike
>> Eike,
>> negotiator.
>> Regards,
>> Saulius
>>> Saulius,
>>> Comments below..
>>>> Hi,
>>>> below.
>>> // Create connector
>>> "localhost:2036");
>>> // Open session
>>> Cheers
>>> /Eike
>>>> Saulius
>>>> <cdoServer>
>>>> </acceptor>
>>>> <store type="db">
>>>> </mappingStrategy>
>>>> </store>
>>>> </repository>
>>>> </cdoServer>
>>>>> Saulius,
>>>>> Cheers,
>>>>> Víctor.
>>>>>> Hi,
>>>>>> Saulius
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: [CDO] CDO View throws OutOfMemoryError [message #426160 is a reply to message #426156] Wed, 17 December 2008 09:04 Go to previous message
Saulius,
You can do so by contributing an IElementProcessor of your choice to the
extension point org.eclipse.net4j.util.elementProcessors.
Cheers
/Eike
> Eike,
> Saulius
>> Saulius,
>> Cheers
>> /Eike
>>> Eike,
>>> negotiator.
>>> Regards,
>>> Saulius
>>>> Saulius,
>>>> Comments below..
>>>>> Hi,
>>>>> below.
>>>> that the
>>>> configure
>>>> has a
>>>> // Create connector
>>>> "localhost:2036");
>>>> // Open session
>>>> with
>>>> Cheers
>>>> /Eike
>>>>> Saulius
>>>>> <cdoServer>
>>>>> </acceptor>
>>>>> <store type="db">
>>>>> </mappingStrategy>
>>>>> </store>
>>>>> </repository>
>>>>> </cdoServer>
>>>>>> Saulius,
>>>>>> Cheers,
>>>>>> Víctor.
>>>>>>> Hi,
>>>>>>> repository
>>>>>>> throws out
>>>>>>> using
>>>>>>> Saulius
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
Previous Topic:CDO server and client usage
Next Topic:teneo 1.0.1 and DuplicateMappingException
Current Time: Fri Jul 11 22:58:31 EDT 2025
Powered by FUDForum. Page generated in 0.25565 seconds
