Re: [buckminster-dev] help with CVS [message #3709] |
Thu, 14 February 2008 12:22 |
Hi Thomas - thanks for the reply...
Curious though. I can indeed check out ALL the projects into my eclipse
workspace using Eclipse CVS. Of course, with autobuild turned on I get the
following Errors/warnings
Errors:
Severity and Description Path
Resource Location Creation Time Id
Package 'org.demo.worlds' does not exist in this plug-in
org.demo.xml.provider/META-INF MANIFEST.MF line 10 1203009040895
253
Package 'se.tada.util.sax' does not exist in this plug-in
org.demo.xml.provider/META-INF MANIFEST.MF line 9 1203009040895
252
Project 'org.demo.xml.provider' is missing required library:
'jars/tada-sax.jar' org.demo.xml.provider Build path
1203008956345 240
'jars/worlds.jar' org.demo.xml.provider Build path 1203008956345
241
The project cannot be built until build path errors are resolved
org.demo.xml.provider Unknown 1203009040880 251
The project was not built since it depends on org.demo.xml.provider, which
has build path errors org.demo.hello.xml.world Unknown
1203009040926 258
Warnings:
An "source.jars/tada-sax.jar" build entry is missing org.demo.xml.provider
build.properties line 1 1203009040911 256
An "source.jars/worlds.jar" build entry is missing org.demo.xml.provider
build.properties line 1 1203009040911 257
The file "jars/worlds.jar" does not exist in the workspace
org.demo.xml.provider build.properties line 6 1203009040911 255
The folder "jars/" does not exist in the workspace org.demo.xml.provider
build.properties line 5 1203009040911 254
Which is what I would expect until I can get buckminster working :)
If you can think of anything that might cause this curious behaviour, I'd
certainly appreciate some insight - thanks!
Todd
Todd Lee
Software Tools
AMI Semiconductor
Tel: +1.519.884.9696 ext 2242
Fax: +1.519.884.0228
E-mail: todd_lee@amis.com
Thomas Hallgren
<thomas@tada.se>
Sent by: To
buckminster-dev-b Buckminster developer discussions
ounces@eclipse.or <buckminster-dev@eclipse.org>
g cc
Subject
02/14/2008 11:10 Re: [buckminster-dev] help with CVS
AM
Please respond to
Buckminster
developer
discussions
<buckminster-dev@
eclipse.org>
Hi Todd,
Buckminster has no special requirements for CVS support other then that
the Buckminster CVS feature is installed. It uses the built in CVS
support provided by the Eclipse IDE. If that works, Buckminster should
also work. I can't see anything wrong with your setup. So first question
I have to ask is - are you able to check out the
org.demo.hello.xml.world project into your workspace using the Eclipse CVS?
- thomas
Todd_Lee@amis.com wrote:
> Hi there,
> So I tried with little success yesterday to use buckminster in our local
> environment. After a bit of investigation, I'm wondering if it has
> something to do with our CVS repository?
> As a bit of background, no matter what I try to resolve, I seem to get
> errors like the following:
> Found searchPath default for component org.demo.hello.xml.world
> ERROR [0001] : No suitable provider for component
> org.demo.hello.xml.world:osgi.bundle was found in searchPath default
> ERROR [0001] : Provider
cvs(:pserver:leet@sam :/usr/local/share/projects/cvsrep,swt_root/scratch/leet/buck minstertest/helloworld/org.demo.hello.xml.world):
> No match found for component org.demo.hello.xml.world
> After banging my head on my desk for a while, I thought I'd try to
> eliminate possible sources of error so I elected to try a local setup
with
> the 'hello world xml' demo which I know works (btw - thanks Thomas, svn
> works now!). I exported the resolved/materialized (from eclipse svn repo)
> sources and added them to my local CVS for a test.
> I made a local copy of the cquery available on our network with the
> following contents (filename: hwdemo.cquery):
> <cq:componentQuery xmlns:cq="
http://www.eclipse.org/buckminster/CQuery-1.0"
> resourceMap="http://sam/ide/updates/dev/hwdemo.rmap">
> <cq:rootRequest name="org.demo.hello.xml.world"
> componentType="osgi.bundle" versionType="OSGi"/>
> </cq:componentQuery>
> I also made a local copy of the rmap likewise, changing the provider info
> to our local CVS (filename: hwdemo.rmap):
> <rmap
> xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
> xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0">
> <searchPath name="default">
> <provider readerType="cvs"
> componentTypes="eclipse.feature,osgi.bundle,buckminster" source="true">
> <uri
format=" :pserver:${user.name}@sam:/usr/local/share/projects/cvsrep,s wt_root/scratch/leet/buckminstertest/helloworld/{0} ">
> <bc:propertyRef key="buckminster.component" />
> </uri>
> </provider>
> </searchPath>
> <locator searchPathRef="default" pattern="^org\.demo\..*" />
> <redirect
> href=" http://www.eclipse.org/buckminster/samples/rmaps/dogfood2.rm ap"
> pattern=".*"/>
> </rmap>
> So I get into my eclipse workbench and do File-> Open component query...
> and enter my url. The CQUERY opens and I click 'resolve to wizard' with
my
> fingers crossed - and I get the error at the start of this message. It
> looks like it can't get the component info for this component, right? I
do
> a local cvs checkout and confirm that the META-INF dir and plugin.xml
file
> are where they are expected and sure enough, there they are (see attached
> screenshot).
> (Embedded image moved to file: pic23281.jpg)
> I assumed this is everything that would be required for successful
> resolution, but no joy...
> I'm left to think that the only possible point of failure is the point at
> which buckminster trys to actually get the component info from our CVS
> repo. Can you suggest a test that I can try locally to try and
> confirm/ruleout this option? Are there specific requirements for
> buckminster CVS support?
> Any help you can provide is greatly appreciated!
> Cheers
> Todd
> AMI Semiconductor - "Silicon Solutions for the Real World"
> NOTICE:
> This electronic message contains information that may be confidential or
privileged. The information is intended for the use of the individual or
entity named above. If you are not the intended recipient, please be aware
that any disclosure, copying, distribution or use of the contents of this
information is prohibited. If you received this electronic message in
error, please notify the sender and delete the copy you received.
> _______________________________________________
> buckminster-dev mailing list
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
NOTICE:
This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
FUDForum. Page generated in 0.04513 seconds
