GMF diagram generator chocking on colors [message #42805] |
Fri, 08 September 2006 08:31  |
Originally posted by: lod.staff.civ.org.pl
--------------010504090004000508060001
Content-Type: text/plain; charset=ISO-8859-2; format=flowed
as part of learning GMF I'm coding a simplified UML Class Diagram
editor. Unfortunately, I've ran into the following problem:
I'm creating a PolygonDecoration that represents the arrowhead of a
generalization relation. The relevant part of the GMFGraph definition is
visible in the attached screenshot.
The problem is that the generator messes up the decoration definition
code severely:
private org.eclipse.draw2d.PolygonDecoration createTargetDecoration() {
org.eclipse.draw2d.PolygonDecoration df = new
org.eclipse.draw2d.PolygonDecoration();
// dispatchNext?
df.setFill(true);ERROR: org.eclipse.emf.codegen.jet.JETException:
InvocationTargetException
org.eclipse.draw2d.geometry.PointList pl = new
org.eclipse.draw2d.geometry.PointList();
pl.addPoint(0, 0);
pl.addPoint(-1, -2);
pl.addPoint(-1, 2);
df.setTemplate(pl);
df.setScale(getMapMode().DPtoLP(7), getMapMode().DPtoLP(3));
return df;
I suspect that this is a bug. Is there a possible workaround? Or, what
am I doing wrong?
PS. I'm using version 1.0.0.v20060627-1200 of GMF.
Content-Type: image/png;
name="gmfcolordiagram.PNG"
Content-Disposition: inline;
filename="gmfcolordiagram.PNG"
iVBORw0KGgoAAAANSUhEUgAAARgAAADcCAIAAAAk4inNAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
GLNJREFUeF7tXcGuZkdxhpdhz5bVfQB2LHgDFmyzgd08gLdISTTrQCISIUtR UJCSC5ENkUax
GCTDxJEAOSECm8gQ2yNhj0z/0+N2TVdXdVV3V5/uc+pq9Ou/51ZXV39d3/nq nNM95/OffPLJ
59ifv//bv/7KV7/G2/hfHYGrIxCIZPRzd3dn5NndOgKrIfC5YkDf+9HPvvGX /4j/hePCAdzf
3wcihU+h/XZm4QQsj1llLHfrlusgUM6GQKFiiNRxbBxY9ODBA7kowcJgDjpZ j9pc5+07nUcE
si7ir9Fzgij9qo1/DsjX6YUk0scff/Ts2Yt/4fvHH//p6Yf/LyTSw4cPA4vS ZxXN+UnQ3yPj
Af+prTsnUjVz1jEgifT06QfP/70f/n344ft/eO+d//n1f1aJFCu6yKLwPXKJ r/GoJEsn9XR6
xkfgiTkzy87ZxaSE0wDP9/jcjwUzOWSiaggPeqOIlMQqxYnla50Mu0gkJJE+ +OAPMHvC91++
9TgS6bvf+avsM4IVCANZFIgEuUSVedWzNUwXWPNkFU42YbgVNoBlUmYPeZKl KZW+TI+URvH0
diJtREKSSH/84/+99967v//9/777zm9+99u33/7Vk7fefHSIIlFEyk7MReGC VKFmpUgMOZEy
sSqeF7B8YdErXv8UNROeTYogbJR/pwmVJNJ///rJf/3ijV/87N9//vjHb/70 9ceP7t/4yQ+q
RIq4qK6R+Myj2FKUJkqjeDp1EqmohFV5zEIt/sooEhTJqvaeJllXHghJpMeP /vX1f/mHH33/
Oz/8/rfDv/t/+pt/++e/ExIplnnyu3ZU5SMp5Bjy4NN5cSZGESkTMUZMslqR +pUnUvLvRFqB
YKs8R8oKpFTnJDGREya5gk6wREAzrHu4tCvaU11Q9R4+DtUy6wKDgCkHI8fN V8iwi8SgeKqo
RUT+EEnreb59sf6cH4b3uCwChkRadswNgTmRGkC7VBMn0qWm2wdrhYATyQpZ 93spBAyJFJ/b
+o8jcAUEDIl0Bfh8jI5ARMCQSK5InmTXQcCQSM0g/sUXvtzc1hs6AocgMJhI Q3YEBiLttSNw
8toCfsVTlkZ+434OrwYTqX9HYGBRWFskESW4SsA0lfGqi2KydqZstZcXtbhm Z+6tdv90O+Cc
fLpsL+OJNG1HYGfiCqdc0suQZKXWQHUqzJDYhFhd2Ww8kZp3BEYtgjsC+RoP pzhcIJetuEtz
DBML2wuztrpOL1tBV1SGLH7qV9wXszwPszGNV1UQXpkSbWMfT6SGHYGBMJBF cEdg/FNxbFRp
RyUTLI1wohcLp6ocYVoWe4eMzSjN/8qPBcKClad4ymjLEm9VRWA8kZp3BI5S JCGRYAZT1yeU
ZGX2WcoW/1qURMwEbFb1ptLeakK4QRsC44l04I5A/qycKRIlBZLkZgpFLGLF mm2ImfyUUZXW
tuzxVp9lwlgswl27zh2Bqrt2xUsaeXrhco7Pb0n5JCnGimmNG6YrK8kpQBLb 2Ll2by+dc8fC
MfM5EpP0uFQTFkjVi7GU07igYurAIuHxQegTV56Y9pFpWStqpPH42Ol2b1aK NARZyUMkYUcL
ps6CIQnBdDMGAcNT1IFr7Yqn9kXywIm0yESMDcOQSGMDdW+OwMoIOJFWnh2P bRsEDInUXNo1
N9wGdQ/0dAgYEul0WPmAHAESAUMiNQtLc0OfZ0fgKAQMiTR/SHf3d/M79R4d gYCAIZFUwjLk
SW4g0so7AttufLe18uSejIAhkVQj6d8RGFh0+9/GBaKEVwNIQu1PaKEHfhGG JNTbCfLln3hE
2NbNGhAwBFelSIFIaUdgmHLtOwJfefJKYFH65IEormqrYtefiBIPzLqnaoTQ QNKXyqEbV5Jq
EYACkdKOwJAEuncEPteiwKJQ10Uu8TUeRSS8HgIeoZa0RQCLKscvexNyJpnx 4cEYivqD/cQj
GI3s+MrLRBbJ3oWukQKRGnYEBsLEii6yKP4kLlFlXpFIVD6lqaLO8Xw6Jpql lGX0sNgFxbfs
OP61SGN+mGkskHVVBNbJ5gMjMSztVKMKREo7AsMs6t4RqFck5uwe/4RP6kym Muf1IpGK8kVd
xjBKkrGCoShD4yq1qGhV83t6Y0Miaa+R0o7AMHPadwS2XSNJMq94Pq4mn6Rk wrnFKBIVaqI9
rDCZ0q4t8tPToH+AhkRSBde/I1B11w7TQ1XataUjVQRCoCSFXLWoMyJSkeeq WT6xsSGRVIo0
8zkSlYhMvZed72OmQvuiYlA2uKOMS0XP2BuUo8wnRUgcOT8W+NcT06B/aIZE 6g9O60HyEEnr
c4j9mufyNaMaAvh8J4ZEUikSHHlzw/nw8T3yynNUtGtGdRQao/o1JNKoEN2P I7A+AoZEOo2w
rD+LHuHhCKxIJGfg4WnhAWgRMCSSNhS3dwT2RcCQSM3C0txw32nwyHdHwJBI 86H55jcfz+/U
e3QEAgKGRFIJy5AHsoFIozb2Uc9YLvvsxW7gdp5nMtyQSKph9G/sCywKy8Al opQtESjGyROp
ee4lXatwqwY/KtRRfnDAzCKMZiggztF/c/zCGAyJpFIkuLHv2bOPtBv7Xnvt 3cCi9MkPvric
J2tioUjWc5mG0N/RqOSWRDKqLziDkn6FDBGaGRJJGEE0gxv7nj59X7WxL2pR YFGo6yKX+Bqv
SKTiWjVsCU9vRXmh1g0wzIxNIg7Yp7AX2G/2PfNMdcTzEEcI7YtDKOpAEVIM fnIosYe4pdFR
Z8YMT36KsWcqqw2JpFWkho19gTCQRXFjX+ISVeZR2ME5gIShjkv8CLMz5ZzE J2+TpS8/kGLa
FTlP6UZ2vGiW0SzDRDJkPAXVI0XCSPrioz2ASFpFan7VX4Mi4VMgNbtZIsJf +ZNlNcOaMx6m
COZJs1sh53GCZjgUedh8psANJbBLaC88xWTjPYBIWkXqedVf8zUSPiUzzMkm taoMEPTqaV44
r9V6yZRIeMiwUMyKvWJxJdQEDF1qKIF9IJGEemBY2gkjiGb9G/tUd+2Kc8xX C/ivkpzguSTx
oLXpJxLDVYpIuMmoVKbOdPxkjeqdGW+eQqp0VxmrFGnmcyRKHCTFMV/axXyC fjBjMwP8Kzyv
F1lR7KXoFjavdsSHCgUBuqoOBwOSFUvZr5TEZXKXgcyMLqMi7g7Hk53+mAn9 LCoVNxY3ljxE
0g6hyDqtE7fvQSCbglEzMsrPC6L2jJBvq1Ik6Kq5ocVYxsJtEeHpfY4lEl8y NIO5yjVS8wC8
oSOwAgKGRFpKWFbA2mM4MQIrEqmZgc0NTzzBPrQ5CBgSac4AvBdHYAUEDInU rA/zG64wEx7D
1ggYEmkjXO4f3G0UrYe6IAKGRJovLG093ha6hhfB3N8vOD39Ialu31MLAqph qHqpetvRwJBI
u8ARWBR2XshFqfgkXjVYbdox9tVgVH05kVTzCI0NidSmDyG4mQ2fvHp7MVn6 rOKoykvKm9YJ
ZS/xI7FJcTqRqglAzmlzy90bxoousih8jVziazwmoeFyLGbxWPSAF4bxzYsP 4+XBxJnCncaD
L51WQeipVbF55jD5UfF29xQ6uSJFQaM+4+BvhAEsijsCP+MSce+hmCXwYOJJ do7H+VrMIWHz
LMUzJhS7LgbJ6w8OBvZbHNFlWXQ7rZzprKAayyhFEhIJm8GMh3LBO2TKsExh IBMafGZEymS2
KGUq/E9mbEikmZc6zbOiukZqViRYHRXTnTrZU7KAqzIsUwOJVOUhE2fz1OzV 0JBIuwChumun
LYeqJZBQ0JhSsLm0wz6pYIREoui9Syb0xGlIpC0U6Xa9pHyOlBU5MXviDyML 0CA1gUqVDIpF
YNacKguZYJggeW/FILOOmMK1Jzs3amtIpI1QkD9E2mhQHupMBAyJtIsizYTb +zorAoZEOitk
Pi5HoHB5aQeKK5Idtu55NQQMFcmJtNpkezx2CBgSyS5o9+wIrIaAIZFckVab bI/HDgFDItkF
TXm+u/f9efNR9x5vCBgSSaVIQ/6n1UCklffnFVcYDUxDa/8DQz2fK0MiqcDq f2NfYFHYByER
Jbw0QRJqf5oKPeA1ECk8yoN8qRsfA0RG7lOC3ultDImkUiT4xr4whdo39r3y 5LabKH3y09a2
nkVIA6ZroYcGIsVOJf6rRDp9xhsN0JBIqojhG/vCZKve2Be1KLAo1HWRS3yN RxEpW40WUxMu
gYMpjpeuMc2zszu2xJqTgqRigD7TdxxV5pkKm6IiDgMrFY4kg06VCZsaGxJJ q0gNb+wLhIEs
ivvzEpeoMq9IJHwwO3lT53I+sWCCUpYwdWDi4uTOgsyM+SHwvWMqFumRdK/Y Fw5eqJObkuel
iVtkDEGR0hv7wnz87rdvv/2rJ2+9+Yi6dkphB+Y0KBKvHjjncEIkDw1Eyto2 EwmrjfYIMwp8
ClAdYca4SMqNDWMhRUpv7Atz8OZPX3/86P6Nn/ygSqQIR9s1UlGacJVVVYaM ZsLiB08kTL74
veiZiqdHkfjSrt/z2Kxd0JshkVSj7X9jn+quHWaLqrRrS6xqaQfdMkWUBZGK IswXclX1o8ip
SoxdjA2JpLpGmvkcqZivMWmSDqQkgEfwd143qMIJd1TMuRRnMYYimZkhMN7g n7LEzVoJESiC
uQsl2uI0JFJbQD2tJA+Revw3t82o2+xnhYZnGstAPA2JpFIkOKTmhgNxGeKK Up4hzic7OdNY
LKAzJJJFuO7TEVgTAUMinUZY1pw5j2opBFYkkh0DQ33yH9/6kn9KEFgqTdcP xpBICw4+sOiL
X3/N/1UR8DsK2uw1JFKzsDQ3rA4+5Ec1h9wgIBDOOFUw3QAiYEik+UCHxat8 p65IwtOEK5I2
ew2JpBKWIQ9kA5H4jX1yRQo4CnPulGauSAsRSRVK/8a+53spHvCiFBUJBkbR wIhIkq77mQmD
bxuIK5Iqe4PxKooEN/Y9e/aRdmPfk1devb0y7NNPCoWoSJI8a8u/KgckXVed VA36g3dFWohI
qlDgxr6nT99XbeyLWhRYdHtZ2HMuUTVeUqSUiynnUrTxT/F4Me+xquC22RHc HewFiiS0jE6S
ZfYrDI8KQGJTZJ0rkip711Kkho19N8IAFr148V7iErr3QCkSJgxFJMqySr+M Obx9ltzFTosE
6AkbCp0r0kJEUoUCN/a9+85vVBv7GhSpqD/F5M5S04hImcpJiATznmkupxZ0 6Iqkyt61FClt
7Pv54x9rN/Y1XyNhoSgyB5ZYWZ0moRZf2mFtURFJEoDExhVJSx5ob3izQRVW /8Y+1V277Hpd
nmcSS2xTJJKQnMVLNaoLuf4wQYYeXZFU2buQIs18jkRdXUTsKI3CtwGgcXPb 4r0EfPshzSt1
rYUNsLQKgwxd+DXSQkTShtJvb7Gyoci6YjZnKrf1r65I2mw0LO1UKxu0cbfZ y1c2UFc1xVvV
W3OmGLwrkjbBDImkDWWCva+1E3LeFUmbjYZEWlORfD+SEAFtJl3c/lREWpC6 F0+v6wzfkEjX
AdFH6ggYEmm+Pszv0RPIEYgIGBJpI4jvH/ir/jaarhVDNSTSfH1o6/G21DW8 COb+fsX56Y5J
df8NGwubC826R7OuA0MirTvolyMLLLrtvBCLUvqvEpuzR9uQsa8Go+rLidSc tIZEatOH5pGE
hg09Pnn19mKy9FntXZWXlDetE8pe4kdik+J0IlUTgJzT5pa7N4wVXWTRbUfg c0bxNR6T0FEZ
Xlx3ApmAOZps0t8ze6p5Zp/MilOAnVO93C6RP42Z6brYPLaFI+Kj2j1bqvGf UJGiLlGfEZEb
YQCLXuwITFwiyrwikeDB+J0/gtM3E4RqcyZlqbbF47z+4LHAfjEDmXFVs/AE BoZEWhydUYok
JBI2w2Il5OEoIuEJYsYCVDY/WSR1WnzGTcMzJFLDFUvnUBt6VF0jNSsSrI6K kkWd7ClZoE7/
KkWSE6kqkkycnXO6S3NDIu0CgequnbYcqpZAQkErgikPpsoErHKQG9XmyaB4 rtklE3riNCRS
gz70jCS0betR+xwpK3JSYVNMppSOsVVWzkGlSgbFIjBrTpWFTDApbL4ypMz4 UTOFa+ec7tLc
kEi7QBDilD9E2mhQHupMBAyJ1KYPPYOf32NPtN72TAgYEulMMPlYHAEeAUMi zdeH+T16ejkC
L6457YCYn9bze7RDzz3vhYChIu0FhEfrCPQgYEik+fowv8ce6L3tmRAwJNJG MPnt740ma81Q
DYk0Xx/aetQ+kF1zIqmohiw1GOJkL9y00RoSSRvKUfaqJUIhSPyMXxu5Ni8Z +2ow2r6KY6HW
Ig1xrkVvTXtDIrXpQw9MDT2qFq1GFvVE+OJWqdIJ1akkGIlNdUQ9AVSdn8Ng QFpsCsSobRRQ
oxJPshVrmQ1ezwaX0lXX8vFsrC6Wg80zhqRfsy/FkJiBb5oSPWEbEqlBH3pG EtryW/pgPL6x
r7gKliFSmppoAz8xsYfIYGcyTG5uSKTJI9F2N0qR8MLn4hFmfXR2vucdZgmd jZpqq/KJqSJ0
W71g087RRvaGRDpKkVToq66RiidaCZFgyZddaEmaV/stsouXDsZnM5FUyJ/M 2JBIuyClumuH
80/ChGJdRFVEQvXICMl7a/OJK72sqKNk1ku7kcm/hSKFAWufIxWvvOElB1Xa ZcdhmiaflF5B
/3CS5MHALookZC51GB5mA6fiHJlYS/pyRbpNi69sWDI5dwrKkEi7KNJO0+Wx roqAIZFWHbLH
5QiMR8CQSK5I46fLPa6KgBNp1ZnxuLZCwJBIW+HgwToCXQgYEslLu66Z8cZb IWBIpI1wuLu7
2yhaD3VBBAyJtIsihQeygUhnfWPfgjl3ypAMibQLXoFF4c1IElGSLMqkVscI V80wZtnShF3g
vUichkTaQpEePnwYWJQ++VmnlpZJckVCJGZ9TU/XkvDcphMBQyJ1RmbdPFZ0 kUXhe+QSX+MV
s7m4hq26BI4anZBv1uC4fy0ChkQ6SpEkb+wLhIEsim/sS1yiyjzJQu9oI19t nU1YlUhVA20G
uP0QBAyJNCQ+OydtisSsoYYUEhIJX/bwPHEW2eVDp2dDIh2lSCpEmq+RYi8U YYREwqHyNxtU
Q3PjmQgYEmnmMHr6Ut21YyqxBkWqEinxyrWoZ4ontDUk0haKFCCWP0cqZjN1 syFNHiRDtXLL
btxlbf0O+ARKtHVhSKS2gA5pJXmIdEhgLkSHwN7QqSGRdlGkBtTmNHEWzcF5 SC+GRBoSnztx
BLZAwJBIrkhbZIAHOQQBJ9IQGN3J1REwJNLVofXxXwkBQyJ5aXelRLr6WA2J tBG0y97+3gjD
i4dqSKRdFEn+QPbiueLDZxAwJNIuuKuWCFXXFlAPf5jj2WoGiFu1u11APn2c hkTaQpGaF61q
n5ZSy4tShmEDvPL19Om47wANibQ4KG3bKHDeU2vt8HGsPDxVnEiLp9BLtYNd rEcp0kYb+5xI
duk32bMrkm6reVF/4pw1bKNwIk1Od7vuDIl0lCKpwGq+RoLkcSKpMD+lsSGR dsFLddcuGxS1
E5Y6Xm2elA1+yb7vAuyl4jQk0haKFCZb/hzJYmMfvsGdkZC5OX6pTF18sIZE WnzkMLylVjZo
b6xvhPOJQzUk0i6KtNTsOouWmg55MIZEkgfhlo7A7ggYEskVaffk8PjlCDiR 5Fi5pSNAImBI
JEfdEbgOAoZE8tLuOmnkIzUk0kbgLnX7eyPcPNSEgCGRdlEk+QNZzxtHgELA kEi7gK5aIlTd
aafd2JehJHyOVA1jF/BPE6chkbZQpOZFq8KM/0z6n783if8RrgbyfUo1IA/4 e312DwhqSpcr
bOzDA7Xg5xQ4r96JIZGOUqSNNvZ1EknLuqsnu+X4DYlkGfYA322KNHxjX1bO MZdYQssB0LgL
PQKGRDpKkVQgNF8jxV469yM1K5JrkWqWJxgbEmlC9EO6UN21y3q0JhK1A2rI wN3JQAQMibSF
IgUo5c+RLDb2wbnkN/kly2QmvMs3MF3cFYWAIZE2An3ZlQ1ewu2SRYZE2kWR lp0qZ9GyU1O4
uN0oVg/VEVgWAVekZafGA9sJASfSTrPlsS6LgCGRlh2zB+YIDEfAkEh+s2H4 bLnDZREwJNKy
Y8aBLXv7eyMMLx6qIZF2UST5A9mL54oPn0HAkEi74K5aIlTdUWe3sa/a9S6A nzJOQyJtoUjN
i1a1T0sl9sySH9/Mtzj9DIm0+MjbtlGkQaXMLm6sgMvhYhOhngj5tji2FwzP kEhHKdK5N/ZJ
mHbBPD58yIZEOnxsfABtinTUxr4ka4ujetnwDIk0X5EaZrH5GglndtQK+Alt hErCmAk9NIDg
TfoRMCRSf3BzPKju2mUhTdvY5yyakwzNvRgSaQtFCsDJnyMduLHPN/M1p/ic hoZEmjOAIb0s
u7LBhWjI/E5wYkikXRRpAsptXTiL2nA7pJUhkQ4Zj3fqCByCgCGRXJEOmVHv 9BAEDIl0yHi8
U0fgEAT+DISnN1NvfCk/AAAAAElFTkSuQmCC
--------------010504090004000508060001--
Re: GMF diagram generator chocking on colors [message #42872 is a reply to message #42805] |
Fri, 08 September 2006 10:21   |
I've submitted https://bugs.eclipse.org/bugs/show_bug.cgi?id=156702.
For now as a workaround, set the foreground color for connection rather than
for its decoration.
It will definitely work with almost the same visble results.
Michael
"Mikolaj Koziarkiewicz" <lod@staff.civ.org.pl> wrote in message
news:edrnq7$jin$1@utils.eclipse.org...
> Hello,
> code severely:
> // dispatchNext?
> pl.addPoint(0, 0);
> pl.addPoint(-1, 2);
> df.setTemplate(pl);
> return df;
> am I doing wrong?
> Regards
Re: GMF diagram generator chocking on colors [message #42903 is a reply to message #42805] |
Fri, 08 September 2006 10:30   |
Also I ve found that you may fix it by just setting the name for your
decoration.
It does not seem reasonable to set the names for decorations, but they are
figures and as such generator assumes that they have names.
Its a pity that it is not validated prior to generation for now.
Michael
> Hello,
> code severely:
> // dispatchNext?
> pl.addPoint(0, 0);
> pl.addPoint(-1, 2);
> df.setTemplate(pl);
> return df;
> am I doing wrong?
> Regards
Re: GMF diagram generator chocking on colors [message #44321 is a reply to message #42903] |
Mon, 11 September 2006 04:47  |
thanks for the help and for making the bug submission! Indeed, naming
the decoration has solved the problem.
Mikolaj
Michael Golubev wrote:
> decoration.
> Michael
>> Hello,
>> code severely:
>> // dispatchNext?
>> pl.addPoint(0, 0);
>> pl.addPoint(-1, 2);
>> df.setTemplate(pl);
>> return df;
>> am I doing wrong?
>> Regards
FUDForum. Page generated in 0.03461 seconds
