Home » Modeling » EMF » Attributes of type EnumSet<E>?
Attributes of type EnumSet<E>? [message #425152] Mon, 17 November 2008 11:20 Go to next message
In my model, I have several enums that can be combined, for example,
privileges such as READ, WRITE, and DELETE. Therefore, some classes have
multi-valued attributes of such enums.
EMF converts an EEnum into a Java enum, but uses an EList for a
multi-valued enum attribute. I would prefer to use an EnumSet instead.
Aside from the more efficient implementation, EnumSet.equals() ignores
the order in which the values have been added.
Is there a way to force the code generator to use EnumSet instead of
EList here? Are there any plans to add some sp ecial handling for
multi-valued enum attributes?
Andreas
Re: Attributes of type EnumSet<E>? [message #425154 is a reply to message #425152] Mon, 17 November 2008 12:52 Go to previous message
Originally posted by: cdamus.zeligsoft.com
Hi, Andreas,
Only Ed can speak to plans, but you can define an EDataType with
java.util.EnumSet as the "instanceTypeName." You can even add the E
generic type parameter (remember to enable Generics in the Ecore Editor
menu).
Then, it's just a matter of implementing the
createFromString/convertToString methods in your generated FactoryImpl
to serialize the enum-set values.
HTH,
Christian
> Andreas
Previous Topic:Re: Dynamic EMF Editor
Next Topic:Implementing Setters for Derived references
Current Time: Fri Jul 11 23:56:27 EDT 2025
Powered by FUDForum. Page generated in 1.04481 seconds
