Home » Eclipse Projects » Subversive » Client too old problem
Client too old problem [message #42776] Mon, 02 March 2009 05:54 Go to next message
I get the next error when I try to checkout the AM3 project. Any idea
how could I solve it? Thanks in advance.
Ander.
Checkout operation for
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3.platform.extension.gmm4at l'
failed.
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3.platform.extension.gmm4as m'
failed.
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3.platform.core'
failed.
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3.platform.ui'
failed.
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3.platform.runtime.core'
failed.
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3.core'
failed.
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3.platform.extension.gmm4am w'
failed.
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3.extractor.launchers'
failed.
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3.repository.lightweight'
failed.
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3.modelhandler.emf'
failed.
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3.platform.extension.global modelmanagement'
failed.
' https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.am3 /plugins/trunk/org.eclipse.gmt.am3'
failed.
svn: This client is too old to work with working copy
'D:\prj\2008PFC_DSL\70.JISBD2009\eclipse_workspace'; please get a newer
Subversion client
Subversion client
Subversion client
Subversion client
Subversion client
Subversion client
Subversion client
Subversion client
Subversion client
Subversion client
Subversion client
Subversion client
Re: Client too old problem [message #42807 is a reply to message #42776] Mon, 02 March 2009 06:50 Go to previous message
Hello Ander,
On 03/02/09 11:54, Ander Zubizarreta wrote:
> Hello,
Does the file "format" in the .svn sub-directories contain one of these values?
"8" = Subversion 1.4 or
"9" = Subversion 1.5
This should be consistent for your local working copy.
It seesm that somewhere Subversion 1.5 is used (guess on the server), so switching the SVN Connector
to use 2.0 (supports 1.5) would help here. I wonder whether the AM3 project upgraded to use
Subversion 1.5?
After switching, doing svn cleanup on the root directory of your local working copy would update the
format to "9", i.e. switching all your files to use Subversion 1.5.
Cheers, Jörg
> Ander.
> failed.
> failed.
> failed.
> failed.
> failed.
> failed.
> failed.
> failed.
> failed.
> failed.
> failed.
> failed.
> Subversion client
> Subversion client
> Subversion client
> Subversion client
> Subversion client
> Subversion client
> Subversion client
> Subversion client
> Subversion client
> Subversion client
> Subversion client
> Subversion client
Previous Topic:Feature Request: Password saving for a session or timeout
Next Topic:Cannot install connectors - dependency problem
Current Time: Tue Jul 22 20:12:00 EDT 2025
Powered by FUDForum. Page generated in 0.04068 seconds
