Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Can't set an attribute with an enumeration type
Can't set an attribute with an enumeration type [message #42766] |
Tue, 01 August 2006 08:59  |
Originally posted by: contact.noelios.com
Hi all,
I'm using EMFT/OCL within GMF to initialize an attribute of type
PublisherType (enumeration). The ECore package name is "model".
Here is the ECore excerpt:
<eClassifiers xsi:type="ecore:EEnum" name="PublisherType">
<eLiterals name="Bean" value="1" literal="Bean"/>
<eLiterals name="File" value="2" literal="File"/>
<eLiterals name="HTTP" value="3" literal="HTTP"/>
<eLiterals name="JMS" value="4" literal="JMS"/>
<eLiterals name="SOAP" value="5" literal="SOAP"/>
<eLiterals name="TCP" value="6" literal="TCP"/>
</eClassifiers>
Here is the GMF Mapping excerpt:
<initializers
body="model::PublisherType::Bean">
<feature
xsi:type="ecore:EAttribute"
href="model.ecore#//Publisher/type"/>
</initializers>
I'm trying to use the following OCL expression but get an OCL parsing
error: "model::PublisherType::Bean" (without quotes)
And the GMF error message:
Diagnosis of
org.eclipse.gmf.mappings.impl.MappingImpl@35a891 {platform:/resource/com.supplyinsight.designer/model/rule.gm fmap#/}
Invalid expression body 'model::PublisherType::Bean'. Cause: Invalid
org.eclipse.emf.ocl.parser.SemanticException: ERROR in
(enumerationOrClassLiteralExpCS): (Unknown type ([model, PublisherType,
Bean]))
Initialized 'Feature' must be owned by 'Domain Element' or its super type
Could someone help me fix my OCL expression?
Jerome Louvel
http://www.noelios.com
Re: Can't set an attribute with an enumeration type [message #42862 is a reply to message #42766] |
Tue, 01 August 2006 15:27   |
Hi Jerome,
Perhaps try not including the package, so just use 'PublisherType::Bean' in
the body.
Best,
Rich
On 8/1/06 8:59 AM, in article eanj7h$ib0$1@utils.eclipse.org, "Jerome
Louvel" <contact@noelios.com> wrote:
> Hi all,
> </eClassifiers>
> <initializers
> <feature
> </initializers>
> Diagnosis of
> org.eclipse.gmf.mappings.impl.MappingImpl@35a891{platform:/resource/com.supply
> insight.designer/model/rule.gmfmap#/}
> Bean]))
Re: Can't set an attribute with an enumeration type [message #42891 is a reply to message #42801] |
Tue, 01 August 2006 15:28   |
Hi Christian,
For feature initializers, a section in part 2 of the tutorial covers the GMF
functionality: http://wiki.eclipse.org/index.php/GMF_Tutorial_Part_2 and
includes a look (though possibly outdated) of what is generated.
Best,
Rich
On 8/1/06 3:15 PM, in article eao98e$niu$1@utils.eclipse.org, "Christian W.
Damus" <cdamus@ca.ibm.com> wrote:
> Hi, Jerome,
> Your OCL expression looks correct to me. You're simply trying to specify an
> enumeration literal.
> What does the code look like that GMF generates for initialization of the
> "type" feature? Perhaps the context of the expression is not correct. I'm
> not familiar with this usage of OCL in GMF. It may also be that the parser
> cannot guess that this expression is intended to indicate an enumeration
> literal (looks just like a reference to a type). A quotation of the
> generated code should help to determine that.
> Cheers,
> Christian
> Jerome Louvel wrote:
>> Hi all,
>> </eClassifiers>
>> <initializers
>> <feature
>> </initializers>
>> Diagnosis of
>> Bean]))
>> type
>> Thanks,
Re: Can't set an attribute with an enumeration type [message #42983 is a reply to message #42953] |
Tue, 01 August 2006 15:32   |
I agree... And expect to find a new Bugzilla if indeed it does work without
the package ;)
Best,
Rich
On 8/1/06 3:32 PM, in article eaoa7u$niu$4@utils.eclipse.org, "Christian W.
> Good idea, Rich. I hope that isn't the problem! The qualification by
> package should work, although it is subject to problems where multiple
> registered packages have the same name.
> cW
> Richard Gronback wrote:
>> Hi Jerome,
>> in the body.
>> Best,
>> Rich
> <snip>
Re: Can't set an attribute with an enumeration type [message #43139 is a reply to message #43088] |
Wed, 02 August 2006 04:17  |
Hi Radek,
You wrote :
> as already mentioned in the other posts your OCL expression looks correct.
> The problem is most likely caused by failure of enumerationLiteral's package
> lookup through the global package
> registry (used as default, see org.eclipse.emf.ocl.parser.EcoreEnvironment).
> This can happen if
> 1) your model code is not generated and package not registered using
> 'org.eclipse.emf.ecore.generated_package'
> extension point which populates the package registry.
This was not the case, my EMF model was generated and working fine
before setting the OCL expression. In my model plugin, I do have:
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri = "http://www.supplyinsight.com/designer/model"
class = "com.supplyinsight.designer.model.DesignerPackage" />
</extension>
> 2) GMF should ensure that used domain model packages are forced to be
> initialized in the global EPackage.Registry by
> simply accessing the package instance there. It is necessary to make it
> visible for OCL env lookup (which skips EPackage.Descriptor entries).
> During GMF mappings validation, packages of all referenced domain metamodel
> elements get initialized as described.
I'm not sure to follow you in the details, but I understand that it may
be an issue with the package registration in order to make it accessible
by OCL.
> Your error messages come from validation and I can see yet another message:
> 'Initialized 'Feature' must be owned by 'Domain Element' or its super type'
> indicating that no domain element is selected or it does not contain the
> initialized feature.
Correct, this was another unrelated issue that I fixed right after.
> Check if your mapping model specifies domain metamodel at all or the
> enumeration is not from a different one.
As it works without the package name, I assume that my mapping model is
correct, let me know if you still need to check this detail.
> All further details are rather GMF specific so we should continue at
> 'eclipse.modeling.gmf'.
I've entered the bug report in EMFT/OCL for now, let's see if it moves
somewhere else :-)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=152563
Jerome Louvel
Re: Can't set an attribute with an enumeration type [message #584117 is a reply to message #42766] |
Tue, 01 August 2006 15:15  |
Hi, Jerome,
Christian
> Hi all,
> </eClassifiers>
> <initializers
> <feature
> </initializers>
> Diagnosis of
> Bean]))
> type
Re: Can't set an attribute with an enumeration type [message #584141 is a reply to message #42766] |
Hi Jerome,
the body.
Best,
Rich
> Hi all,
> </eClassifiers>
> <initializers
> <feature
> </initializers>
> Diagnosis of
> Bean]))
Re: Can't set an attribute with an enumeration type [message #584161 is a reply to message #42801] |
Hi Christian,
Best,
Rich
> Hi, Jerome,
> Cheers,
> Christian
>> Hi all,
>> </eClassifiers>
>> <initializers
>> <feature
>> </initializers>
>> Diagnosis of
>> Bean]))
>> type
>> Thanks,
Re: Can't set an attribute with an enumeration type [message #584192 is a reply to message #42862] |
cW
> Hi Jerome,
> in the body.
> Best,
> Rich
<snip>
Re: Can't set an attribute with an enumeration type [message #584201 is a reply to message #42953] |
the package ;)
Best,
Rich
> cW
>> Hi Jerome,
>> in the body.
>> Best,
>> Rich
> <snip>
Re: Can't set an attribute with an enumeration type [message #584237 is a reply to message #42766] |
Tue, 01 August 2006 20:00  |
Hi Jerome,
This can happen if
/Radek
"Jerome Louvel" <contact@noelios.com> wrote in message
news:eanj7h$ib0$1@utils.eclipse.org...
> Hi all,
> </eClassifiers>
> <initializers
> <feature
> </initializers>
> Diagnosis of
> Bean]))
> type
> Jerome Louvel
Re: Can't set an attribute with an enumeration type [message #584270 is a reply to message #43088] |
Hi Radek,
> This can happen if
<package
</extension>
by OCL.
somewhere else :-)
Jerome Louvel
Current Time: Sat Jul 26 14:42:46 EDT 2025
Powered by FUDForum. Page generated in 0.08842 seconds
