Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Can't set an attribute with an enumeration type
Can't set an attribute with an enumeration type [message #42766] Tue, 01 August 2006 08:59 Go to next message
Originally posted by: contact.noelios.com
Hi all,
I'm using EMFT/OCL within GMF to initialize an attribute of type
PublisherType (enumeration). The ECore package name is "model".
Here is the ECore excerpt:
<eClassifiers xsi:type="ecore:EEnum" name="PublisherType">
<eLiterals name="Bean" value="1" literal="Bean"/>
<eLiterals name="File" value="2" literal="File"/>
<eLiterals name="HTTP" value="3" literal="HTTP"/>
<eLiterals name="JMS" value="4" literal="JMS"/>
<eLiterals name="SOAP" value="5" literal="SOAP"/>
<eLiterals name="TCP" value="6" literal="TCP"/>
</eClassifiers>
Here is the GMF Mapping excerpt:
<initializers
body="model::PublisherType::Bean">
<feature
xsi:type="ecore:EAttribute"
href="model.ecore#//Publisher/type"/>
</initializers>
I'm trying to use the following OCL expression but get an OCL parsing
error: "model::PublisherType::Bean" (without quotes)
And the GMF error message:
Diagnosis of
org.eclipse.gmf.mappings.impl.MappingImpl@35a891 {platform:/resource/com.supplyinsight.designer/model/rule.gm fmap#/}
Invalid expression body 'model::PublisherType::Bean'. Cause: Invalid
org.eclipse.emf.ocl.parser.SemanticException: ERROR in
(enumerationOrClassLiteralExpCS): (Unknown type ([model, PublisherType,
Bean]))
Initialized 'Feature' must be owned by 'Domain Element' or its super type
Could someone help me fix my OCL expression?
Jerome Louvel
http://www.noelios.com
Re: Can't set an attribute with an enumeration type [message #42801 is a reply to message #42766] Tue, 01 August 2006 15:15 Go to previous messageGo to next message
Hi, Jerome,
Your OCL expression looks correct to me. You're simply trying to specify an
enumeration literal.
What does the code look like that GMF generates for initialization of the
"type" feature? Perhaps the context of the expression is not correct. I'm
not familiar with this usage of OCL in GMF. It may also be that the parser
cannot guess that this expression is intended to indicate an enumeration
literal (looks just like a reference to a type). A quotation of the
generated code should help to determine that.
Christian
Jerome Louvel wrote:
> Hi all,
> </eClassifiers>
> <initializers
> <feature
> </initializers>
> Diagnosis of
> Bean]))
> type
Re: Can't set an attribute with an enumeration type [message #42862 is a reply to message #42766] Tue, 01 August 2006 15:27 Go to previous messageGo to next message
Hi Jerome,
Perhaps try not including the package, so just use 'PublisherType::Bean' in
the body.
Best,
Rich
On 8/1/06 8:59 AM, in article eanj7h$ib0$1@utils.eclipse.org, "Jerome
Louvel" <contact@noelios.com> wrote:
> Hi all,
> </eClassifiers>
> <initializers
> <feature
> </initializers>
> Diagnosis of
> org.eclipse.gmf.mappings.impl.MappingImpl@35a891{platform:/resource/com.supply
> insight.designer/model/rule.gmfmap#/}
> Bean]))
Re: Can't set an attribute with an enumeration type [message #42891 is a reply to message #42801] Tue, 01 August 2006 15:28 Go to previous messageGo to next message
Hi Christian,
For feature initializers, a section in part 2 of the tutorial covers the GMF
functionality: http://wiki.eclipse.org/index.php/GMF_Tutorial_Part_2 and
includes a look (though possibly outdated) of what is generated.
Best,
Rich
On 8/1/06 3:15 PM, in article eao98e$niu$1@utils.eclipse.org, "Christian W.
Damus" <cdamus@ca.ibm.com> wrote:
> Hi, Jerome,
> Cheers,
> Christian
>> Hi all,
>> </eClassifiers>
>> <initializers
>> <feature
>> </initializers>
>> Diagnosis of
>> Bean]))
>> type
>> Thanks,
Re: Can't set an attribute with an enumeration type [message #42953 is a reply to message #42862] Tue, 01 August 2006 15:32 Go to previous messageGo to next message
Good idea, Rich. I hope that isn't the problem! The qualification by
package should work, although it is subject to problems where multiple
registered packages have the same name.
cW
Richard Gronback wrote:
> Hi Jerome,
> in the body.
> Best,
> Rich
<snip>
Re: Can't set an attribute with an enumeration type [message #42983 is a reply to message #42953] Tue, 01 August 2006 15:32 Go to previous messageGo to next message
I agree... And expect to find a new Bugzilla if indeed it does work without
the package ;)
Best,
Rich
On 8/1/06 3:32 PM, in article eaoa7u$niu$4@utils.eclipse.org, "Christian W.
> cW
>> Hi Jerome,
>> in the body.
>> Best,
>> Rich
> <snip>
Re: Can't set an attribute with an enumeration type [message #43014 is a reply to message #42891] Tue, 01 August 2006 15:35 Go to previous messageGo to next message
Thanks, Rich, for the pointer. Nice tutorial.
Doesn't look like the problem is in that code, to me. I suspect you're
right about the package name.
cW
> Hi Christian,
> GMF functionality: http://wiki.eclipse.org/index.php/GMF_Tutorial_Part_2
> and includes a look (though possibly outdated) of what is generated.
> Best,
> Rich
Re: Can't set an attribute with an enumeration type [message #43088 is a reply to message #42766] Tue, 01 August 2006 20:00 Go to previous messageGo to next message
Hi Jerome,
as already mentioned in the other posts your OCL expression looks correct.
The problem is most likely caused by failure of enumerationLiteral's package
lookup through the global package
registry (used as default, see org.eclipse.emf.ocl.parser.EcoreEnvironment).
This can happen if
1) your model code is not generated and package not registered using
'org.eclipse.emf.ecore.generated_package'
extension point which populates the package registry.
2) GMF should ensure that used domain model packages are forced to be
initialized in the global EPackage.Registry by
simply accessing the package instance there. It is necessary to make it
visible for OCL env lookup (which skips EPackage.Descriptor entries).
During GMF mappings validation, packages of all referenced domain metamodel
elements get initialized as described.
Your error messages come from validation and I can see yet another message:
'Initialized 'Feature' must be owned by 'Domain Element' or its super type'
indicating that no domain element is selected or it does not contain the
initialized feature.
Check if your mapping model specifies domain metamodel at all or the
enumeration is not from a different one.
All further details are rather GMF specific so we should continue at
'eclipse.modeling.gmf'.
/Radek
"Jerome Louvel" <contact@noelios.com> wrote in message
news:eanj7h$ib0$1@utils.eclipse.org...
> Hi all,
> </eClassifiers>
> <initializers
> <feature
> </initializers>
> Diagnosis of
> Bean]))
> type
> Jerome Louvel
Re: Can't set an attribute with an enumeration type [message #43108 is a reply to message #42983] Wed, 02 August 2006 04:06 Go to previous messageGo to next message
Hi Christian and Rich,
I've tried removing the package name from my OCL expression, and it
indeed works!
<initializers
body="PublisherType::Bean">
<feature
</initializers>
FYI, I'm only using one EMF model in this application. Here is an
excerpt of the generated EMF package:
public interface DesignerPackage extends EPackage
String eNAME = "model";
String eNS_URI = "http://www.supplyinsight.com/designer/model";
String eNS_PREFIX = "designer";
I've entered a related bug report at:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=152563
Jerome
Re: Can't set an attribute with an enumeration type [message #43139 is a reply to message #43088] Wed, 02 August 2006 04:17 Go to previous message
Hi Radek,
> This can happen if
This was not the case, my EMF model was generated and working fine
before setting the OCL expression. In my model plugin, I do have:
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri = "http://www.supplyinsight.com/designer/model"
class = "com.supplyinsight.designer.model.DesignerPackage" />
</extension>
I'm not sure to follow you in the details, but I understand that it may
be an issue with the package registration in order to make it accessible
by OCL.
Correct, this was another unrelated issue that I fixed right after.
As it works without the package name, I assume that my mapping model is
correct, let me know if you still need to check this detail.
I've entered the bug report in EMFT/OCL for now, let's see if it moves
somewhere else :-)
Jerome Louvel
Re: Can't set an attribute with an enumeration type [message #584117 is a reply to message #42766] Tue, 01 August 2006 15:15 Go to previous message
Hi, Jerome,
Christian
> Hi all,
> </eClassifiers>
> <initializers
> <feature
> </initializers>
> Diagnosis of
> Bean]))
> type
Re: Can't set an attribute with an enumeration type [message #584141 is a reply to message #42766] Tue, 01 August 2006 15:27 Go to previous message
Hi Jerome,
the body.
Best,
Rich
> Hi all,
> </eClassifiers>
> <initializers
> <feature
> </initializers>
> Diagnosis of
> Bean]))
Re: Can't set an attribute with an enumeration type [message #584161 is a reply to message #42801] Tue, 01 August 2006 15:28 Go to previous message
Hi Christian,
Best,
Rich
> Hi, Jerome,
> Cheers,
> Christian
>> Hi all,
>> </eClassifiers>
>> <initializers
>> <feature
>> </initializers>
>> Diagnosis of
>> Bean]))
>> type
>> Thanks,
Re: Can't set an attribute with an enumeration type [message #584192 is a reply to message #42862] Tue, 01 August 2006 15:32 Go to previous message
cW
> Hi Jerome,
> in the body.
> Best,
> Rich
<snip>
Re: Can't set an attribute with an enumeration type [message #584201 is a reply to message #42953] Tue, 01 August 2006 15:32 Go to previous message
the package ;)
Best,
Rich
> cW
>> Hi Jerome,
>> in the body.
>> Best,
>> Rich
> <snip>
Re: Can't set an attribute with an enumeration type [message #584216 is a reply to message #42891] Tue, 01 August 2006 15:35 Go to previous message
cW
> Hi Christian,
> Best,
> Rich
Re: Can't set an attribute with an enumeration type [message #584237 is a reply to message #42766] Tue, 01 August 2006 20:00 Go to previous message
Hi Jerome,
This can happen if
/Radek
> Hi all,
> </eClassifiers>
> <initializers
> <feature
> </initializers>
> Diagnosis of
> Bean]))
> type
> Jerome Louvel
Re: Can't set an attribute with an enumeration type [message #584254 is a reply to message #42983] Wed, 02 August 2006 04:06 Go to previous message
indeed works!
<initializers
<feature
</initializers>
Jerome
Re: Can't set an attribute with an enumeration type [message #584270 is a reply to message #43088] Wed, 02 August 2006 04:17 Go to previous message
Hi Radek,
> This can happen if
<package
</extension>
by OCL.
somewhere else :-)
Jerome Louvel
Previous Topic:OclInvalid and Collections
Next Topic:CDO ResourceManager lifecycle
Current Time: Tue Jul 15 10:41:26 EDT 2025
Powered by FUDForum. Page generated in 1.14156 seconds
