Home » Eclipse Projects » Eclipse Platform » PropertyChangeEvent event not consistent when passing values for preference
PropertyChangeEvent event not consistent when passing values for preference [message #42742] Wed, 21 May 2003 15:21 Go to next message
I am running on Eclipse 2.1 Build id: 200303272130
I have a preference page that extends FieldEditorPreferencePage and
therefore uses FieldEditors to present and set the values.
I am using IPreferenceStore in my plugin.
I have noticed an inconsistency in the values passed to listeners of
property change events.
If I change a field on my preference page (e.g. BooleanFieldEditor) and
press "Apply" I get a PropertyChangeEvent that contains a newValue and
oldValue that are "Boolean" objects.
BUT
When I press the "Restore defaults" button and then "Apply" I get a
PropertyChangedEvent that contains newValue and oldValue as Strings to
represent the values "true" and "false".
It appears to be a problem because of the attempt to map between the older
IPreferenceStore and the newer Preferences classes.
Is this a bug or am I not using the property event values correctly?
Re: PropertyChangeEvent event not consistent when passing values for preference [message #44441 is a reply to message #42742] Thu, 22 May 2003 14:29 Go to previous message
Originally posted by: lynne_kues.oti.com
There is a bug report for this. Bug 9259 [Preferences] IntegerFieldEditor
returns inconsistent value types in PropertyChangeEvent. I will update it
to indicate that it happens for booleans also. You can add yourself to the
CC and vote for it, though its pretty low priority.
"Alan" <boxall@ca.ibm.com> wrote in message
news:bagjk5$32l$1@rogue.oti.com...
> BUT
Previous Topic:Umlauts in files get lost under linux
Next Topic:Have a external tool run two commands - possible?
Current Time: Sat Jul 26 10:39:04 EDT 2025
Powered by FUDForum. Page generated in 0.17704 seconds
