Home » Language IDEs » PHP Development Tools (PDT) » Problem deploying plugin
Problem deploying plugin [message #42736] Wed, 15 August 2007 05:25 Go to next message
Originally posted by: andrei.serea.ama.us
Hi all,
I'm having a lot of trouble with exporting my plugin. It seems that for an
unknown reason, when trying to access a wizard from my plugin, Eclipse
throws a classnotfoundexception.
My situation is as follows: my plugin has all its sources in the folder src
and it depends on only one external jar file, called yac.jar.
I have a few questions:
1. Where do I add the yac.jar? In the build tab, under "Extra classpath
entries" or in the runtime tab, under "Classpath".
1. In the Build tab, I have to define a library where my sources will be
compiled. Do I have to add this too in the runtime tab under "Classpath"?
I have tried a thousand ways to do this, but none of them worked.
I am using Eclipse 3.2.1.
P.S. I noticed that there are many situations when the build.properties file
is not correctly generated, and once I even got a nullpointerexception while
changing different settings using the manifest editor (of course, I never
touched the generated files).
Help please and thanks in advance.
Re: Problem deploying plugin [message #43355 is a reply to message #42736] Wed, 15 August 2007 11:40 Go to previous message
Hi Andrei,
I believe you are looking for the platform newsgroup. This newsgroup is
for the PHP Development Tools project...
--Dion
Andrei Serea wrote:
> Hi all,
Previous Topic:M2 Release
Next Topic:bug in editor syntax
Current Time: Sun Jul 27 03:14:33 EDT 2025
Powered by FUDForum. Page generated in 0.03661 seconds
