Support of Nebula FormattedText widget [message #42690] |
Fri, 10 July 2009 03:54  |
Good morning,
I want to use SWTBot to write all the tests for our Eclipse RCP
application.
Now I got a problem with an widget that is used in the application.
It's the Nebula FormattedText widget.
The application uses a lot of these textfields.
If I use the setText() methode on a formattedText (as seen below)
bot.textWithId("key", "value").setText("65451,4545");
it only sets the text until the comma ("65451") the rest is ignored.
Mabye the problem is the Formatter the application uses for this textfield.
But if I type the same text into the formattedText widget by hand, it's
all fine.
Is there a possibility to get it working?
Benjamin
FUDForum. Page generated in 0.06274 seconds
