Home » Newcomers » Newcomers » Eclipse refesh issues on rebuild using ant
Eclipse refesh issues on rebuild using ant [message #42687] Tue, 29 March 2005 03:13 Go to next message
Originally posted by: kevin_405.yahoo.com
Hi Guys,
I use ant to build my java project. The classes folder are shared by
eclipse and ant. i.e both of them generate the classes at the same
location.
The ant build usually does a clean before recompile.
The effect on the eclipse workspace is that I have to refresh my project
manually.
Is there something i can do in my ant build file to avoid having to do the
irritating refresh every time i do a rebuild.
Kevin
Re: Eclipse refesh issues on rebuild using ant [message #42841 is a reply to message #42687] Tue, 29 March 2005 10:12 Go to previous message
Originally posted by: eclipse.rizzoweb.com
Kevin wrote:
> Hi Guys,
> location.
> manually.
> the irritating refresh every time i do a rebuild.
How are you launching the Ant builds? If you launch them from Eclipse,
you can set up the Launch Configuration to automatically refresh the
Eclipse Project when the Ant build finishes.
HTH,
Eric
Previous Topic:Where can I get the Eclipse Chinese Pack?
Next Topic:Is the really impossible??
Current Time: Thu Jul 17 18:49:47 EDT 2025
Powered by FUDForum. Page generated in 0.07300 seconds
