Home » Eclipse Projects » SWTBot » how to test swing code
how to test swing code [message #42620] Thu, 09 July 2009 12:50 Go to next message
Ketan,
After getting hold of the swing componant, how can I pass the swing
componant to say FEST's class for testing it.
Can you show me some sample code?
In one of your earlier replies you had written the following :
"Ketan Padegaonkar-2 wrote:
No SWTBot does not provide for this. SWTBot currently only supports SWT
and eclipse. SWTBot can help you find out composites containing Swing
components.
You can pull out swing panels using SWT_AWT#getFrame(Composite) and test
it using a swing testing library.
I'd recommend using FEST (http://fest.easytesting.org/) for testing
swing panels. There is also Frankenstein written by a colleague on my
team (http://frankenstein.seleniumhq.org/) "
Re: how to test swing code [message #42659 is a reply to message #42620] Fri, 10 July 2009 00:19 Go to previous message
You'd get better traction on the FEST mailing list.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 9/7/09 22:20, lalitha wrote:
> Ketan,
> Thanks
> components.
Previous Topic:help with swing / rcp application testing
Next Topic:Support of Nebula FormattedText widget
Current Time: Sat May 03 00:07:16 EDT 2025
Powered by FUDForum. Page generated in 0.03774 seconds
