Home » Modeling » EMF » Bug: SetCommand changes order of elements in collection
Bug: SetCommand changes order of elements in collection [message #422648] |
Thu, 11 September 2008 13:23  |
Hi all,
I have filed a bug for this too (247048). The test tries to change the
eStructuralFeatures of an EClass instance via the SetCommand. In the
Result, the order of last two EAttributes is swapped, the test fails
with "expected:<[a1, b1, b2, b3, a2]> but was:<[a1, b1, b2, a2, b3]>"
package org.eclipse.bugs;
import static org.junit.Assert.assertEquals;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.emf.common.command.BasicCommandStack;
import org.eclipse.emf.common.command.Command;
import org.eclipse.emf.common.command.CommandStack;
import org.eclipse.emf.common.notify.AdapterFactory;
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.impl.EAttributeImpl;
import org.eclipse.emf.edit.command.SetCommand;
import org.eclipse.emf.edit.domain.AdapterFactoryEditingDomain;
import org.eclipse.emf.edit.domain.EditingDomain;
import org.eclipse.emf.edit.provider.ReflectiveItemProviderAdapterF actory;
import org.junit.Before;
import org.junit.Test;
* the following test fails
* expected:<[a1, b1, b2, b3, a2]> but was:<[a1, b1, b2, a2, b3]>
* @author av
public class SetCommandBug {
private CommandStack commandStack;
private EditingDomain domain;
@Before
public void setUp() {
AdapterFactory adapterFactory = new
ReflectiveItemProviderAdapterFactory();
commandStack = new BasicCommandStack();
domain = new AdapterFactoryEditingDomain(adapterFactory, commandStack);
@Test
public void testSetCommand() {
EClass eclass = EcoreFactory.eINSTANCE.createEClass();
EAttribute a1 = createAttribute("a1");
EAttribute a2 = createAttribute("a2");
eclass.getEStructuralFeatures().add(a1);
eclass.getEStructuralFeatures().add(a2);
List<EAttribute> list = new ArrayList<EAttribute>();
list.add(a1);
list.add(createAttribute("b1"));
list.add(createAttribute("b2"));
list.add(createAttribute("b3"));
list.add(a2);
Command command = SetCommand.create(domain, eclass,
EcorePackage.eINSTANCE
.getEClass_EStructuralFeatures(), list);
commandStack.execute(command);
assertEquals(list.toString(), eclass.getEAttributes().toString());
private EAttribute createAttribute(String name) {
// just to make toString() more concise
EAttribute attribute = new EAttributeImpl() {
public String toString() {
return name;
attribute.setName(name);
return attribute;
Re: Bug: SetCommand changes order of elements in collection [message #422650 is a reply to message #422648] |
Thu, 11 September 2008 14:21  |
Andreas,
Thanks so much for the simple test case! Hopefully the patch I've
attached does the trick.
Andreas Voss wrote:
> Hi all,
> import
> * @author av
> @Before
> commandStack);
> @Test
> list.add(a1);
> list.add(a2);
> @Override
> return name;
> return attribute;
Current Time: Sun Jul 13 12:47:23 EDT 2025
Powered by FUDForum. Page generated in 0.25651 seconds
