Home » Newcomers » Newcomers » CVS: Authentication Error
CVS: Authentication Error [message #42597] Mon, 28 March 2005 23:36 Go to next message
I am giving the following setup in the Add Repository in Eclipse.
hostname: 127.0.0.1 - Is this the right way
Rep, path: /cvsrep
User: currently logged in User - Jaspreet
Password: I have no password on my XP Home user 'Jaspreet', so I leave it
blank
Connection type: pserver
Default Port
When I press validate, a prompt appears saying Password Required,
Authentication Error, Incorrect Username or Password. Is there any error
above?
I dont have any password on my Windows XP Home account 'Jaspreet', that I am
currently logged in. Am I specifying the username incorrectly.
Or is there any error in the CVS control panel setup?
In the CVSNT control panel, I've specified Run As User as Jaspreet, and
Default Domain Name as MYLAPTOP. How should I provide this information in
Eclipse repository so that I stop getting the authentication error?
Jaspreet
Re: CVS: Authentication Error [message #46605 is a reply to message #42597] Mon, 04 April 2005 06:04 Go to previous message
Check the CVSNT docs for how to integrate it with the Windows
authentication scheme (as far as I remember, it is not the
default setup); otherwise you will have a separate
authentication, names/passwords, for CVSNT.
Try to login to CVSNT from the command line - if that works,
then blame Eclipse.
Jaspreet wrote:
> Hi
> Rep, path: /cvsrep
> blank
> Default Port
> above?
> Jaspreet
Previous Topic:Where are the "Example Plug-ins"
Next Topic:CVSNT: What is a "repository prefix"?
Current Time: Fri Jul 18 00:24:55 EDT 2025
Powered by FUDForum. Page generated in 0.11236 seconds
