Home » Eclipse Projects » DTP » MS Access empty schema
MS Access empty schema [message #42591] Fri, 29 February 2008 14:12 Go to next message
Originally posted by: shawn.w.karr.boeing.com
We are trying to use the JPA tools to create entities for an MS Access
prototype database. In both JPA and the Data Source Explorer, I can
connect to the database but end up stuck with an empty schema folder.
I've searched the newsgroups but have not found a useful answer. Has
anyone done this successfully?
Re: MS Access empty schema [message #42627 is a reply to message #42591] Fri, 29 February 2008 18:31 Go to previous message
Originally posted by: brianf.sybase.com
So far as I know I haven't seen anyone implement a MS Access database using
DTP. Nobody so far has stepped up to volunteer and we haven't had a call for
it (and haven't had time to implement the necessary code).
If you'd like to put in an enhancement request for it, please do and we'll
add it to the "Help Wanted" list of bugs for additional database support.
--Fitz
"Shawn Karr" <shawn.w.karr@boeing.com> wrote in message
news:ea8876b31d0963dbc2a2d10343b93686$1@www.eclipse.org...
Re: MS Access empty schema [message #590330 is a reply to message #42591] Fri, 29 February 2008 18:31 Go to previous message
--Fitz
Previous Topic:MS Access empty schema
Next Topic:How to start learning Data Tool?
Current Time: Sat Jul 26 18:43:27 EDT 2025
Powered by FUDForum. Page generated in 0.03395 seconds
