Domain model validation in batch mode [message #42577] |
Mon, 31 July 2006 07:35  |
I wonder if it is possible to validate a domain model outside an OSGI
platform.
I created an EMF Domain model and I am using it outside eclipse (eg: EMF
batch mode only).
Is it possible to run a validation without loading EMFT plugins and just
reusing jars at runtime (as EMF does)?
regards,
Re: Domain model validation in batch mode [message #42673 is a reply to message #42644] |
Mon, 31 July 2006 10:42  |
Chris,
I reached the same conclusion.
I'll try to work with annotations and EMF validation mechanism.
regards,
- Lucas
"Chris McGee" <cbmcgee@ca.ibm.com> wrote in message
news:eal14o$862$1@utils.eclipse.org...
> Hello Lucas,
> The EMFT validation framework is tightly integrated into eclipse and OSGI
> at the moment. For example, constraints have to be contributed through an
> extension point.
> To "batch" validate your domain models you could try EMF's own validation
> framework. I don't believe that it requires eclipse.
> I hope this helps,
> Chris McGee
> lucas bigeardel wrote:
>> Hello,
>> platform.
>> batch mode only).
>> regards,
Re: Domain model validation in batch mode [message #584027 is a reply to message #42577] |
Mon, 31 July 2006 09:38  |
Hello Lucas,
OSGI at the moment. For example, constraints have to be contributed
through an extension point.
validation framework. I don't believe that it requires eclipse.
I hope this helps,
Chris McGee
> Hello,
> platform.
> batch mode only).
> regards,
Re: Domain model validation in batch mode [message #584044 is a reply to message #42644] |
Chris,
regards,
- Lucas
> Hello Lucas,
> extension point.
> I hope this helps,
> Chris McGee
>> Hello,
>> platform.
>> batch mode only).
>> regards,
FUDForum. Page generated in 0.03501 seconds
