Home » Eclipse Projects » GEF » accessing to Workbench from EditPart
accessing to Workbench from EditPart [message #42524] Fri, 15 November 2002 10:04 Go to next message
hi all,
I want to open a new editor window when user double clicks on the figure of
a editpart. so I need to access to:
getActiveWorkbenchWindow().getActivePage().openEditor(...)
method. how can I access to Workbench ?
thanx,
ozgur
Re: accessing to Workbench from EditPart [message #42650 is a reply to message #42524] Fri, 15 November 2002 13:15 Go to previous messageGo to next message
Hi Ozgur,
I use the following code to open a new drawing in the same editor, that's
not the same you want but gives you propably a hint for your problem. The
code is part of the command for opening the new diagramm.
Dieter
public void execute() {
System.out.println("Called OpenKernelCommand.execute for" +
part.getClassName());
EditPartViewer viewer = editPart.getRoot().getViewer();
lastFactory = viewer.getEditPartFactory();
lastEditPart = viewer.getContents();
EditPart editPart = new PartNetKernelEditPart();
editPart.setModel(new PartNetKernelAdapter(part,
part.getKernel().getPartNetKernel()));
viewer.setEditPartFactory(new PartNetKernelPartFactory());
viewer.setContents(editPart);
((DefaultEditDomain)viewer.getEditDomain()).setPaletteRoot(P artsModelPlugin.
createPartNetPalette());
"Ozgur Kurt" <ozgurkurt@hotmail.com> schrieb im Newsbeitrag
news:ar30ct$d3t$1@rogue.oti.com...
> hi all,
of
> thanx,
> ozgur
Re: accessing to Workbench from EditPart [message #43430 is a reply to message #42524] Mon, 18 November 2002 09:07 Go to previous message
try doing this from your edit part:
getEditor().getEditorSite().getWorkbenchWindow().getActivePa ge().openEditor(...);
gett the editor from the DefaultEditDomain.
Ozgur Kurt wrote:
> hi all,
> thanx,
> ozgur
Previous Topic:excluding actions from commandstack
Next Topic:is it possible to hide connections, like in visual age
Current Time: Sat Jul 26 05:54:46 EDT 2025
Powered by FUDForum. Page generated in 0.05345 seconds
