Home » Modeling » OCL » 2 layers of iterate
2 layers of iterate [message #42510] |
Thu, 01 November 2007 10:22  |
Originally posted by: nickkirtley.gmail.com
I have the following code:
Component.allInstances()->iterate(i;sel : Set(Tuple(c1 : Component,c2
:Component,s : Bag(Component))) = Set{} |
if
i.oclAsType(Component).ownedConnector.end->size()=2 and
i.oclAsType(Component).ownedConnector.getAppliedStereotypes( )- >any(name='TypeConnector')->notEmpty()
then
i.oclAsType(Component).ownedConnector->select(j |
j.oclAsType(Connector).getAppliedStereotypes()->any(name='TypeConnector')- >notEmpty())->iterate(j.oclAsType(Component)
if
j.oclAsType(Component).ownedConnector->any(c |
c.oclAsType(Connector).getAppliedStereotypes()->any(name='TypeConnector')).end.role.type- >any(c|
c <>
i.oclAsType(Component)).oclAsType(Component).ownedConnector. getAppliedStereotypes()- >any(name='SuperTypeConnector')->isEmpty()
then
sel->including(Tuple{c1 = i.oclAsType(Component) ,c2 =
j.oclAsType(Component),s = Bag {} })
else
=j.oclAsType(Component).ownedConnector.end.role.type.oclAsTy pe(Component)- >select(k
| k.oclAsType(Component) <> j.oclAsType(Component))})
endif
else
sel
endif
I get the error:
14:9:16:11 ") else sel unexpected token(s)"
when I have two iterates and using tuples.
I've had this problem before but avoided it by solving the problem another
way, but that's not possible now.
Anyone know what the problem is? anyone else been able to use nested
iterates with tuple return value?
regards,
Nick
Re: 2 layers of iterate [message #42630 is a reply to message #42510] |
Thu, 01 November 2007 11:19   |
Hi, Nick,
It is entirely possible that this is a bug in the OCL grammar definition,
possibly in the rule for tuple literals, collection literals, iterators, or
some combination thereof. There is already one bug report on the
if-expression rule, so maybe that is related, too.
If you can raise a bugzilla report and attach a JUnit test case that
reproduces the problem, then we can look into it. Of course, the simpler
the expression, the easier it will be to debug, so it would be very helpful
if you could reduce the problem from the example below. :-)
Christian
Nick Kirtley wrote:
> if
> then
> if
> c <>
> then
> else
> endif
> else
> sel
> endif
> I get the error:
> regards,
> Nick
Re: 2 layers of iterate [message #47590 is a reply to message #42630] |
Tue, 08 January 2008 10:37   |
Hi, Nick and Christian.
Has this bug report been filed?
Is the only thing that needs to be done an example project? I'd
volunteer to create one based on Christian's EMF templates.
Best, Philipp
Christian W. Damus wrote:
> Hi, Nick,
> Cheers,
> Christian
> Nick Kirtley wrote:
>> if
>> then
>> if
>> c <>
>> then
>> else
>> endif
>> else
>> sel
>> endif
>> I get the error:
>> regards,
>> Nick
Re: 2 layers of iterate [message #47618 is a reply to message #47590] |
Tue, 08 January 2008 11:59   |
Hi, Philipp,
The OCL in-box hasn't yet been fed this particular delight.
cW
> Best, Philipp
>> Hi, Nick,
>> or
>> helpful
>> Cheers,
>> Christian
-----8<-----
Re: 2 layers of iterate [message #48607 is a reply to message #42510] |
Wed, 16 January 2008 06:54   |
hi christian,
Could you check this code to see whether this should work?
According to me it should but I might have made a mistake.
Component.allInstances()->iterate(i;pairs : Set(Tuple(c1 : Component, p1 :
Port)) = Set{} |
let comp: Component = i.oclAsType(Component) in
comp.ownedPort->iterate(j.oclAsType(Port) |
let po : Port = j.oclAsType(Port) in
pairs->including(Tuple{c1=comp, p1 = po }) ))
This should iterate through the components, then iterate through ports of
the components and add them to the tuple.
This assumes that components have ports. But I did this to keep the query
as simple as possible.
Error given:
Results:
5:61:5:61 ") unexpected token(s)"
I installed the newest version, 1.2.0M4, and got a different error:
3:41:3:49 missing "| oclExpressionCS )" to complete scope
Although if I count the brackets they add up.
If I do the following it works:
Port)) = Set{} |
pairs->including(Tuple{c1=i.oclAsType(Component), p1 =
i.oclAsType(Component).ownedPort->any(true) }) )
Results:
org.eclipse.ocl.uml.UMLEvaluationEnvironment$TupleImpl@59f4f0c1
org.eclipse.ocl.uml.UMLEvaluationEnvironment$TupleImpl@71f3491f
org.eclipse.ocl.uml.UMLEvaluationEnvironment$TupleImpl@75b03ff0
org.eclipse.ocl.uml.UMLEvaluationEnvironment$TupleImpl@63d1f0a7
org.eclipse.ocl.uml.UMLEvaluationEnvironment$TupleImpl@533622bb
Your thoughts?
regards,
Nick
Re: 2 layers of iterate [message #48711 is a reply to message #48607] |
Wed, 16 January 2008 09:24   |
Hi, Nick,
The problem with your example, below, is the attempt to place an
expression "j.oclAsType(Port)" where a variable declaration is required in
the iterate() expression. Moreover, when only one variable is specified in
an iterate, it is the accumulator, which requires declaration of a type and
initial value expression (the iterator variable being implicit).
This whole expression can be simplified, though, thus:
Component.allInstances()->collect(c |
c.ownedPort->collect(p | Tuple{c1 = c, p1 = p}))->asSet()
which takes advantage of the fact that the "collect" iterator flattens
nested collections.
Note that there is no need for any oclAsType() casting.
Christian
> Port)) = Set{} |
Re: 2 layers of iterate [message #48770 is a reply to message #48741] |
Wed, 16 January 2008 11:03   |
Hi, Nick,
As I indicated, the problem was in the declaration of iterator/accumulator
variables in the nested iterate expression. Thus, the following parses:
Component.allInstances()->iterate(i; pairs : Set(Tuple(c1 : Component, p1 :
Port)) = Set{} |
let comp : Component = i.oclAsType(Component) in
comp.ownedPort->iterate(j; pairs2 : Set(Tuple(c1 : Component, p1 : Port))
= Set{} |
let po : Port = j.oclAsType(Port) in pairs2->including(Tuple{c1 = comp,
p1 = po}) ))
but does not achieve the goal of collecting all (component, port) pairs. It
only gets the pairs for the last component because the result of the inner
iterate *replaces* the "pairs" value in the outer iterate.
Christian
Nick wrote:
> I know that it can be solved much easier but the whole point of this was
> to try an iterate within an iterate. Does it work once you correct the
> problem?
> nick
Re: 2 layers of iterate [message #52678 is a reply to message #52651] |
Tue, 11 March 2008 11:44  |
Hi, Nick,
Indeed, OCL queries can become large. I guess that's partly a consequence
of the relatively small and simple syntax. :-)
The classic text on OCL is the Warmer and Kleppe book which, I think, has
been updated for OCL 2.0. A search for the keywords "Warmer" and "OCL" on
Amazon should find it easily.
I can't actually recommend this book, though, because I have never read it.
The only reference that I have is the specification.
HTH,
Christian
nick wrote:
> hi,
> I was looking back at this question of mine.
> OCL queries can, in my opinion, be quite complicated. What's the best book
> on OCL and in particular (relatively) complicated queries out there?
> What do you use Christian?
> cheers,
> Nick
Current Time: Tue Jul 22 13:03:19 EDT 2025
Powered by FUDForum. Page generated in 0.06965 seconds
