Home » Modeling » EMF » Persisting an EMF model in a non-EMF persistance model
Persisting an EMF model in a non-EMF persistance model [message #421120] |
Fri, 25 July 2008 15:29 |
Originally posted by: swt.magellium.fr
Hello all,
I'm looking for a way to persist my EMF model using Hibernate, but I
think I cannot use Teneo in my case :
I have a "generic" database, that is to say, a DB that is designed to
work with multiple client applications.
Access to this DB is handled by a server java application which uses
Hibernate.
Client applications have access to the persistent model classes, and
they can send requests to the server via WebServices.
For instance, a client application can ask for model objects, modify
them, then send back the modifications to the server...
Now, I have to develop a new client application which will have it's own
EMF model. This EMF model is not the same as the persistence model of
the server application (so I will need to map the model objects of the
two models).
I can add new server WebServices, but I cannot change the server model
contents (I can add annotations or such things, but I cannot add a
dependency to EMF or change contents...).
So my client application must roughly manage the following actions :
- load persistent objects through webServices, then load them in the
local EMF model.
- work transparently with the EMF model
- save the EMF model modifications into the persistent model, and send
the updated persistent objects to the server to update the database
But many problems arise, that's why I'm asking the specialists ;-)
- How can I map the EMF model with the persistence model ?
- How to load objects from the persistent model in the EMF model ?
For instance, if my models (both the server persistence model and the
local EMF model) contain a class A, with a 1..1 reference to another
class B :
### Persistent Model :
public interface PersistentA {
long getId();
void setId(long id);
PersistentB getB();
void setB(PersistentB b);
public interface PersistentB {
long getId();
### EMF Model :
public interface A {
long getId();
B getB();
void setB(B b);
public interface B {
long getId();
I can ask the server for a specific instance of persistent class A
through web services. Then, I may manage to create the corresponding
instance of EMF class A, for example :
public A createA(PersistantA pa) {
A a = AFactory.eINSTANCE.createA();
a.setId(pa.getId());
a.setB(createB(pa.getB()));
public B createB(PersistantB pb) {
But if I use this kind of implementation, when loading any object in the
model, I will recursively load every dependencies to other objects, and
I will end up with "all" the database loaded on the client side...
A solution would be something like :
a.setB(createBProxy(pa, ...));
I won't continue with other implementations details, but I hope you will
understand the problems and that you'll be able to give me some pointers
on how to achieve all this...
Thanks a lot in advance !
Stephane
Re: Persisting an EMF model in a non-EMF persistance model [message #421133 is a reply to message #421120] |
Mon, 28 July 2008 04:52 |
Hi Stephane,
As you say this is not something for which you can use Teneo.
What you need is some kind of model-to-model transformation. I would transform the xml from the
webservice to xml which can be read by EMF. Afaik this is more or less a manual task but others know
more about this then I do (for example: http://www.eclipse.org/m2m/ but if your situation is simpler
you can use any other templating language, free-marker, xslt, straight java, also of interest is
probably what the open architectureware people are doing: www.openarchitectureware.org).
Regarding the proxying issue you mention. EMF has a nice proxying mechanism which you can use. What
you need to add is that you for EMF proxy resolving use the webservice. What I would do is use your
own resource implementation (extending XMLResourceImpl), load the converted xml from the webservice
into this resource and override the getEObject or getEObjectByID methods to use the webservice for
proxy resolving.
gr. Martin
SWT wrote:
> Hello all,
> Hibernate.
> two models).
> local EMF model.
> class B :
> long getId();
> PersistentB getB();
> long getId();
> ### EMF Model :
> long getId();
> B getB();
> void setB(B b);
> long getId();
> Stephane
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Persisting an EMF model in a non-EMF persistance model [message #421134 is a reply to message #421133] |
Mon, 28 July 2008 09:33 |
Hi Martin,
Model-to-model transformation is exactly what I need.
I knew about ATL, but OAW seems even better. I'll definitely have a look
at these solutions. Thank you.
Regarding the proxies, I tried to "copy" Hibernate's mechanism :
I have a global object (equivalent of Hibernate's session) where I can
attach or detach objects found via web services.
To attach an object, I load a persistent object through webservices,
then transform it into local model objects (via mapping). These
resulting objects are attached to the session (reference counted).
Then for each EReference in the newly created local model objects, I
create a proxy. Whenever a method is called on one of these proxy
objects, I load the real referenced object via webservices, and I
replace the proxy by the loaded object (and I count the reference to the
object in the session).
Should I rework this mechanism using EMF Resources ?
I'm not used to Resources (and ResourceSet...) but I think this may be
better : if I understand well, I should use my own ResourceImpl instead
of the "session" object I was talking about...
Are there any documentation on EMF proxies / Resources ?
I think I can find by myself, but with an example or something, it's
often faster :-)
Thank you Martin !
Stephane
Martin Taal wrote :
> Hi Stephane,
> transform the xml from the webservice to xml which can be read by EMF.
> Afaik this is more or less a manual task but others know more about this
> situation is simpler you can use any other templating language,
> free-marker, xslt, straight java, also of interest is probably what the
> mechanism which you can use. What you need to add is that you for EMF
> proxy resolving use the webservice. What I would do is use your own
> xml from the webservice into this resource and override the getEObject
> or getEObjectByID methods to use the webservice for proxy resolving.
> gr. Martin
> SWT wrote:
>> Hello all,
>> Hibernate.
>> two models).
>> local EMF model.
>> class B :
>> long getId();
>> PersistentB getB();
>> long getId();
>> ### EMF Model :
>> long getId();
>> B getB();
>> void setB(B b);
>> long getId();
>> the model, I will recursively load every dependencies to other
>> objects, and I will end up with "all" the database loaded on the
>> client side...
>> will understand the problems and that you'll be able to give me some
>> pointers on how to achieve all this...
>> Stephane
Re: Persisting an EMF model in a non-EMF persistance model [message #421135 is a reply to message #421134] |
Mon, 28 July 2008 10:13 |
Hi Stephane,
There is a difference between EMF and hibernate proxies which you should know although I am not sure
if it makes a difference for you.
The main difference between EMF and Hibernate proxies is that with Hibernate the object itself is
de-proxied while with EMF the reference is de-proxied. Here is an example of how de-proxying is done
for the Book referencing an EMF-proxied Writer (from the EMF library example):
public Writer getAuthor() {
if (author != null && ((EObject)author).eIsProxy()) {
InternalEObject oldAuthor = (InternalEObject)author;
author = (Writer)eResolveProxy(oldAuthor);
if (author != oldAuthor) {
if (eNotificationRequired())
eNotify(new ENotificationImpl(this, Notification.RESOLVE, LibraryPackage.BOOK__AUTHOR,
oldAuthor, author));
return author;
What you can see is that the eResolveProxy replaces the Writer instance in the author member. This
is different than the hibernate proxy approach which would would not replace the Writer (==the cglib
wrapped object) but would instead initialize the Writer/cglib object with the real object from the
webservice.
The advantage of EMF over the hibernate proxy approach is that with EMF you don't need to do the
proxying of each object yourselve, and you don't need cglib.
To explain a bit more what happens. The eResolveProxy method is implemented in the base class
BasicEObjectImpl, this eventually does this call: return EcoreUtil.resolve(proxy, this);
The EcoreUtil.resolveProxy gets the Resource from the EObject and from the Resource it gets the
ResourceSet, and then this call is done: resourceSet.getEObject(proxyURI, true)
which is implemented like this:
public EObject getEObject(URI uri, boolean loadOnDemand)
Resource resource = getResource(uri.trimFragment(), loadOnDemand);
if (resource != null)
return resource.getEObject(uri.fragment());
else
return null;
To get this working you should create your own ResourceImpl (which can replace your Session
concept). This resource only needs to implement the getEObject(String uriFragment) method which
calls the webservice to get the object. The uriFragment should map to something which you can use in
the webservice.
At runtime you create your resource through a ResourceSet (do new ResourceSetImpl() to get one). Now
the thing to watch here is that the url you use to create your resource with should match the url
used in the proxies. Otherwise the resourceset can't find your resource again. For example:
resource ur: mgr://my.great.resource
proxy uri: mgr://my.great.resource#object_identifier
Where object_identifier is passed to the getEObject(String uriFragment) in your resource.
Note the protocol mgr, you can tell EMF which resource to create based on the protocol:
Resource.Factory.Registry.INSTANCE.getProtocolToFactoryMap() .put( "mgr", new MyGreatResourceFactory());
MyGreatResourceFactory implements Resource.Factory which has one method createResource(uri).
(I am not sure if this is currently the preferred way of doing this, but it works for me...)
To make live simpler at first you can also just override ResourceSetImpl with your own
implementation which always calls your one Resource to get the EObject. Then if this works fine move
back to the standard EMF way (as this allows more flexibility and is more standard).
gr. Martin
SWT wrote:
> Hi Martin,
> often faster :-)
> Thank you Martin !
> Stephane
> Martin Taal wrote :
>> Hi Stephane,
>> converted xml from the webservice into this resource and override the
>> getEObject or getEObjectByID methods to use the webservice for proxy
>> resolving.
>> gr. Martin
>> SWT wrote:
>>> Hello all,
>>> Hibernate.
>>> the two models).
>>> model contents (I can add annotations or such things, but I cannot
>>> add a dependency to EMF or change contents...).
>>> local EMF model.
>>> class B :
>>> long getId();
>>> PersistentB getB();
>>> long getId();
>>> ### EMF Model :
>>> long getId();
>>> B getB();
>>> void setB(B b);
>>> long getId();
>>> client side...
>>> Stephane
The Netherlands
Re: Persisting an EMF model in a non-EMF persistance model [message #421138 is a reply to message #421135] |
Mon, 28 July 2008 12:13 |
Martin,
Thank you a lot, you explained every little things that were still not
clear for me :)
I managed to use my own ResourceFactory (and my own Resource
implementation) last week, but I was using
"resourceSet.getResourceFactoryRegistry()
.getContentTypeToFactoryMap()
.put(Resource.Factory.Registry.DEFAULT_CONTENT_TYPE_IDENTIFI ER,
new CommResourceFactoryImpl());"
Now you've explained the details about URIs, all seems clear. Your
solution is way better! And with your explanation on EMF proxies,
everything becomes simpler :-D
I'll give it a try right now!
Stephane
Martin Taal wrote :
> Hi Stephane,
> know although I am not sure if it makes a difference for you.
> Hibernate the object itself is de-proxied while with EMF the reference
> is de-proxied. Here is an example of how de-proxying is done for the
> Notification.RESOLVE, LibraryPackage.BOOK__AUTHOR, oldAuthor, author));
> return author;
> in the author member. This is different than the hibernate proxy
> approach which would would not replace the Writer (==the cglib wrapped
> real object from the webservice.
> you don't need to do the proxying of each object yourselve, and you
> don't need cglib.
> implemented in the base class BasicEObjectImpl, this eventually does
> the Resource it gets the ResourceSet, and then this call is done:
> else
> return null;
> replace your Session concept). This resource only needs to implement the
> getEObject(String uriFragment) method which calls the webservice to get
> the webservice.
> ResourceSetImpl() to get one). Now the thing to watch here is that the
> url you use to create your resource with should match the url used in
> For example:
> in your resource.
> on the protocol:
> it works for me...)
> with your own implementation which always calls your one Resource to get
> the EObject. Then if this works fine move back to the standard EMF way
> gr. Martin
> SWT wrote:
>> Hi Martin,
>> look at these solutions. Thank you.
>> the object in the session).
>> instead of the "session" object I was talking about...
>> often faster :-)
>> Thank you Martin !
>> Stephane
>> Martin Taal wrote :
>>> Hi Stephane,
>>> EMF. Afaik this is more or less a manual task but others know more
>>> your situation is simpler you can use any other templating language,
>>> resolving.
>>> gr. Martin
>>> SWT wrote:
>>>> Hello all,
>>>> Hibernate.
>>>> own
>>>> of the server application (so I will need to map the model objects
>>>> of the two models).
>>>> local EMF model.
>>>> the local EMF model) contain a class A, with a 1..1 reference to
>>>> another class B :
>>>> long getId();
>>>> PersistentB getB();
>>>> long getId();
>>>> ### EMF Model :
>>>> long getId();
>>>> B getB();
>>>> void setB(B b);
>>>> long getId();
>>>> client side...
>>>> Stephane
Re: Persisting an EMF model in a non-EMF persistance model [message #421144 is a reply to message #421135] |
Mon, 28 July 2008 15:02 |
Martin,
I have some more questions about EMF proxies :
When I implement the getEObject(String uriFragment) method, I can get
the persistent object via webservices, and I can create a new
corresponding model object.
In this case, all references of the new model object are null.
But I need them to be proxies, not null values !
Here is an example implementation :
public EObject getEObject(String uriFragment) {
if (/*...uriFragment...*/) {
// TODO specific cases...
} else {
return getNewEObject(uriFragment);
public EObject getNewEObject(uriFragment) {
// Retrieve the corresponding object in database
PersistentObject po = getByURI(uriFragment);
// Convert it to client model object
EObject modelObject = createFromPersistent(po);
return modelObject;
public EObject createFromPersistent(PersistentObject po) {
// It's an example, so let's keep it simple :
MyModelObject result =
MyFactory.eINSTANCE.createMyModelObject();
result.setAttr1(po.getAttr1());
result.setAttr2(po.getAttr2());
// etc. for all attributes
// Now the references :
result.setReferenceToOther(?????);
In this example, I don't know what to use for "?????".
My idea would be to create a new proxy instance of the referenced object
as follows :
OtherModelObject proxyToOther =
MyFactory.eINSTANCE.createOtherModelObject();
((BasicEObjectImpl) proxyToOther).eSetProxyURI(URI.createURI(getURI()
+ getURIFragment(po)
+ MyPackage.MyModelObject__OtherModelObject ));
result.setReferenceToOther(proxyToOther);
But it seems that if I continue this way, I will re-implement a lot of
the proxying mechanism... I don't even know if the cast
"(BasicEObjectImpl) proxyToOther" is legal / safe, and if it's the good
way for creating proxies...
Maybe I'm missing something ? Maybe there's a facility to handle proxies...
Thank you a lot in advance !
Stephane
Martin Taal wrote :
> Hi Stephane,
> return author;
> don't need cglib.
> else
> return null;
> the webservice.
> For example:
> in your resource.
> on the protocol:
> it works for me...)
> gr. Martin
> SWT wrote:
>> Hi Martin,
>> often faster :-)
>> Thank you Martin !
>> Stephane
>> Martin Taal wrote :
>>> Hi Stephane,
>>> resolving.
>>> gr. Martin
>>> SWT wrote:
>>>> Hello all,
>>>> Hibernate.
>>>> own
>>>> of the two models).
>>>> local EMF model.
>>>> another class B :
>>>> long getId();
>>>> PersistentB getB();
>>>> long getId();
>>>> ### EMF Model :
>>>> long getId();
>>>> B getB();
>>>> void setB(B b);
>>>> long getId();
>>>> client side...
>>>> Stephane
Re: Persisting an EMF model in a non-EMF persistance model [message #421146 is a reply to message #421144] |
Mon, 28 July 2008 15:37 |
Hi Stephane,
Afaics your approach is fine. I am not sure what you get from the webservice call is that xml or is
instances of the PersistenceObject? If it is xml then you can write a transformation from the
webservice xml to emf xml which also handles proxies (you need to check how EMF stores proxy
information in xml).
If you get PersistenceObjects then you can maybe write a more generic java transformation by using
the EClass and EFeatures of the model. It depends if there is an easy match to make from the
classname of the PersistenceObject and the membernames of the PersistenceObject to the
eclass/efeature names of the EMF model.
Maybe one of the core EMF developers can add some more information about creating proxies.
gr. Martin
SWT wrote:
> Martin,
> } else {
> return modelObject;
> as follows :
> Stephane
> Martin Taal wrote :
>> Hi Stephane,
>> should know although I am not sure if it makes a difference for you.
>> return author;
>> instance in the author member. This is different than the hibernate
>> with the real object from the webservice.
>> EMF you don't need to do the proxying of each object yourselve, and
>> else
>> return null;
>> the getEObject(String uriFragment) method which calls the webservice
>> can use in the webservice.
>> For example:
>> on the protocol:
>> ResourceSetImpl with your own implementation which always calls your
>> one Resource to get the EObject. Then if this works fine move back to
>> standard).
>> gr. Martin
>> SWT wrote:
>>> Hi Martin,
>>> can attach or detach objects found via web services.
>>> be better : if I understand well, I should use my own ResourceImpl
>>> often faster :-)
>>> Thank you Martin !
>>> Stephane
>>> Martin Taal wrote :
>>>> Hi Stephane,
>>>> if your situation is simpler you can use any other templating
>>>> proxy resolving.
>>>> gr. Martin
>>>> SWT wrote:
>>>>> Hello all,
>>>>> Hibernate.
>>>>> it's own
>>>>> of the two models).
>>>>> local EMF model.
>>>>> another class B :
>>>>> long getId();
>>>>> PersistentB getB();
>>>>> long getId();
>>>>> ### EMF Model :
>>>>> long getId();
>>>>> B getB();
>>>>> void setB(B b);
>>>>> long getId();
>>>>> corresponding instance of EMF class A, for example :
>>>>> in the model, I will recursively load every dependencies to other
>>>>> client side...
>>>>> some pointers on how to achieve all this...
>>>>> Stephane
The Netherlands
Re: Persisting an EMF model in a non-EMF persistance model [message #421150 is a reply to message #421146] |
Mon, 28 July 2008 16:22 |
Martin,
The webservices can provide xml, but it'll be a xml generated with JAXB
(to be confirmed with the server-side developers), not an XMI conforming
to an Ecore model (that's why I think the XML approach would be
difficult). Webservices can also directly provide "PersistentObjects"
through the XFire library.
Anyway, if I want to try "webservice xml to EMF xml transform". Could
you please give me some starting point (url or so...) ?
The match between "PersistentObjects" and the EMF model is generally
easy (mainly 1..1 relationships) but there are some special cases which
can hopefully be managed "by hand" (that is to say, I think I'll be able
to first use an hard-coded transform before using ATL/oAW in order to be
generic...)
So, using this approach, I just need to know how to properly create EMF
proxies... I'll search some more today, and maybe create an new
discussion focusing on EMF proxy creation tomorrow...
Thank you again !
Stephane
Martin Taal wrote :
> Hi Stephane,
> webservice call is that xml or is instances of the PersistenceObject? If
> it is xml then you can write a transformation from the webservice xml to
> proxy information in xml).
> java transformation by using the EClass and EFeatures of the model. It
> depends if there is an easy match to make from the classname of the
> creating proxies.
> gr. Martin
> SWT wrote:
>> Martin,
>> } else {
>> return modelObject;
>> object as follows :
>> good way for creating proxies...
>> proxies...
>> Stephane
>> Martin Taal wrote :
>>> Hi Stephane,
>>> done for the Book referencing an EMF-proxied Writer (from the EMF
>>> library example):
>>> return author;
>>> from the Resource it gets the ResourceSet, and then this call is
>>> else
>>> return null;
>>> can replace your Session concept). This resource only needs to
>>> implement the getEObject(String uriFragment) method which calls the
>>> which you can use in the webservice.
>>> standard).
>>> gr. Martin
>>> SWT wrote:
>>>> Hi Martin,
>>>> often faster :-)
>>>> Thank you Martin !
>>>> Stephane
>>>> Martin Taal wrote :
>>>>> Hi Stephane,
>>>>> would transform the xml from the webservice to xml which can be
>>>>> know more about this then I do (for example:
>>>>> http://www.eclipse.org/m2m/ but if your situation is simpler you
>>>>> java, also of interest is probably what the open architectureware
>>>>> proxy resolving.
>>>>> gr. Martin
>>>>> SWT wrote:
>>>>>> Hello all,
>>>>>> Hibernate.
>>>>>> it's own
>>>>>> of the two models).
>>>>>> local EMF model.
>>>>>> send
>>>>>> another class B :
>>>>>> long getId();
>>>>>> PersistentB getB();
>>>>>> long getId();
>>>>>> ### EMF Model :
>>>>>> long getId();
>>>>>> B getB();
>>>>>> void setB(B b);
>>>>>> long getId();
>>>>>> client side...
>>>>>> you will understand the problems and that you'll be able to give
>>>>>> me some pointers on how to achieve all this...
>>>>>> Stephane
Current Time: Mon Apr 29 06:19:37 GMT 2024
Powered by FUDForum. Page generated in 0.03051 seconds
