Home » Archived » Test and Performance Tools Platform (TPTP) » Can't see the Hyades URL test in the run configuration
Can't see the Hyades URL test in the run configuration [message #42475] Thu, 24 November 2005 09:34 Go to next message
Originally posted by: newbie.xxxxxxxxxxxxxx.com
I'm following the Performance Testing with TPTP procedure found in the
online help of release 4.0.0 and I don't see the Hyades URL test option in
the run configuration. I only see the last option "Test" like in the
example.
Is is that the procedure is not up to date or am I missing someting in my
configuration?
Re: Can't see the Hyades URL test in the run configuration [message #42534 is a reply to message #42475] Thu, 24 November 2005 10:16 Go to previous messageGo to next message
The way that a TPTP Hyades URL test is launched was changed in 4.0+ but the
help contents were never updated in this release. Our documentations have
gone through major improvements in 4.1.
All test types now use the common "Test" launch configuration item to launch
a test suite.
"newbie" <newbie@xxxxxxxxxxxxxx.com> wrote in message
news:d738cd9c8a96910a8ddd299d799e0a57$1@www.eclipse.org...
> Hello,
> example.
> configuration?
Re: Can't see the Hyades URL test in the run configuration [message #42683 is a reply to message #42534] Thu, 24 November 2005 11:47 Go to previous message
Originally posted by: yves.xxxxxxxxx.xom
Thank you for your answer.
Now when I run a test, I get a "connection refused" error. is it trying to
connect to one of the two server specify in the Agent Controller? Do I
need to install one of those server?
Previous Topic:JVM error (vrash) on TPTP
Next Topic:Max Datapool records
Current Time: Sat Jul 26 05:06:52 EDT 2025
Powered by FUDForum. Page generated in 0.03497 seconds
