Home » Eclipse Projects » DTP » Connecting to Sybase via JDBC - Only see Schema under each Table
Connecting to Sybase via JDBC - Only see Schema under each Table [message #42468] Thu, 28 February 2008 17:45 Go to next message
I'm trying to connect to a Sybase database through the JDBC driver. It all
seems to work, and I can execute statements, but I can't see anything
apart from the Table (?) names, with 'Schema' below them. Nothing else.
Very annoying.
For reference, I have Eclipse EE 3.3.1 running on Ubuntu 7.10. I have
little idea about what the server's running. I believe, though I'm not
sure, that it's an old version of Sybase, so could that be part of the
problem?
Re: Connecting to Sybase via JDBC - Only see Schema under each Table [message #42560 is a reply to message #42468] Thu, 28 February 2008 23:27 Go to previous message
Originally posted by: brianf.sybase.com
Hi Andrew...
Are you connecting to an ASA or ASE database? There is some limited ASA
support in DTP Enablement now, but ASE support is very minimal. We are
expecting some ASE profile code to be added for this next milestone of the
Ganymede release.
"Andrew Thorburn" <nzipsi@gmail.com> wrote in message
news:2cf7b112304ecfe22de990593c4edc4a$1@www.eclipse.org...
> Very annoying.
> problem?
Re: Connecting to Sybase via JDBC - Only see Schema under each Table [message #590301 is a reply to message #42468] Thu, 28 February 2008 23:27 Go to previous message
Hi Andrew...
Ganymede release.
> Very annoying.
> problem?
Previous Topic:"No connection" on a database that I am connected to
Next Topic:MS Access empty schema
Current Time: Fri Jul 25 23:19:44 EDT 2025
Powered by FUDForum. Page generated in 0.45013 seconds
