Home » Modeling » GMF (Graphical Modeling Framework) » Create generator model failed
Create generator model failed [message #42405] Thu, 07 September 2006 18:57 Go to next message
Hi.
I'm getting
Diagnosis of org.eclipse.gmf.mappings.impl.MappingImpl@1e5a42c{platform:/resource/test1/model/test1.gmfmap#/}
Validation failed unexpectedly for 'Mapping'. See log for details.
Validation failed unexpectedly for 'Label Mapping '. See log for details.
and
!ENTRY org.eclipse.gmf.validate 4 300 2006-09-08 01:49:14.663
!MESSAGE Validation failed unexpectedly for 'Label Mapping '. See log for details.
!STACK 0
java.lang.ClassCastException: org.eclipse.gmf.gmfgraph.impl.LabelImpl
at org.eclipse.gmf.mappings.impl.LabelMappingImpl.getDiagramLab el(LabelMappingImpl.java:159)
at org.eclipse.gmf.mappings.impl.LabelMappingImpl.eGet(LabelMap pingImpl.java:323)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:594)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:586)
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.hasNext(EContentsEList.java:416)
at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryPr oxyResolves(EObjectValidator.java:328)
at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryDe faultConstraint(EObjectValidator.java:183)
at org.eclipse.emf.ecore.util.EObjectValidator.validate(EObject Validator.java:168)
at org.eclipse.gmf.internal.validate.ValidatorChain.validate(Va lidatorChain.java:70)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:127)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:107)
in the .log after trying to 'Create generator model...' on the following
fileset:
test1.ecore:
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="test1">
<eClassifiers xsi:type="ecore:EClass" name="Entity">
<eStructuralFeatures xsi:type="ecore:EReference" name="forms" eType="#//Form"
containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Form"/>
</ecore:EPackage>
test1.gmfgraph:
<gmfgraph:Canvas xmi:version="2.0"
xmlns:gmfgraph="http://www.eclipse.org/gmf/2005/GraphicalDefinition" name="test1">
<figures
name="Default">
<figures
xsi:type="gmfgraph:Rectangle"
referencingElements="EntityNode"
name="EntityFigure">
<children
xsi:type="gmfgraph:Label"
referencingElements="EntityNameLabel"
name="EntityNameLabel"
text="entity">
<foregroundColor
xsi:type="gmfgraph:ConstantColor"
value="black"/>
</children>
<backgroundColor
value="lightBlue"/>
</figures>
<figures
xsi:type="gmfgraph:RoundedRectangle"
referencingElements="FormNode"
name="FormFigure">
<children
referencingElements="FormNameLabel"
name="FormNameLabel"
text="form">
<foregroundColor
value="black"/>
</children>
<backgroundColor
value="lightGray"/>
</figures>
<figures
xsi:type="gmfgraph:PolylineConnection"
referencingElements="forms"
name="forms">
<children
xsi:type="gmfgraph:PolylineDecoration"/>
</figures>
</figures>
<nodes
name="FormNode"
figure="FormFigure"/>
<nodes
name="EntityNode"
figure="EntityFigure"/>
<connections
name="forms"
figure="forms"/>
<labels
figure="EntityNameLabel"/>
<labels
figure="FormNameLabel"/>
</gmfgraph:Canvas>
test1.gmftool:
<gmftool:ToolRegistry xmi:version="2.0"
xmlns:gmftool="http://www.eclipse.org/gmf/2005/ToolDefinition">
<palette>
<tools
xsi:type="gmftool:ToolGroup"
title="test1">
<tools
xsi:type="gmftool:CreationTool"
title="Entity"
description="Create new Entity">
<smallIcon
xsi:type="gmftool:DefaultImage"/>
<largeIcon
</tools>
<tools
title="Form"
description="Create new Form">
<smallIcon
<largeIcon
</tools>
</tools>
</palette>
</gmftool:ToolRegistry>
test1.gmfmap:
<gmfmap:Mapping xmi:version="2.0"
xmlns:gmfmap="http://www.eclipse.org/gmf/2005/mappings"
<nodes>
<ownedChild>
<domainMetaElement
href="test1.ecore#//Entity"/>
<labelMappings
viewPattern="">
<diagramLabel
href="test1.gmfgraph#EntityNameLabel"/>
</labelMappings>
<tool
href="test1.gmftool#//@palette/@tools.0/@tools.0"/>
<diagramNode
href="test1.gmfgraph#EntityNode"/>
</ownedChild>
</nodes>
<diagram>
<diagramCanvas
href="test1.gmfgraph#test1"/>
<domainModel
href="test1.ecore#/"/>
<domainMetaElement
<palette
href="test1.gmftool#//@palette"/>
</diagram>
</gmfmap:Mapping>
Also there is
java.lang.ArrayStoreException
at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:188)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:666)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUn ique(NotifyingListImpl.java:384)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:368)
when i'm trying to open test1.gmfmap. What i did wrong?
wbr, eugen.
Re: Create generator model failed [message #42478 is a reply to message #42405] Thu, 07 September 2006 19:51 Go to previous message
The problem is that you have Label (in particular
Default::EntityFigure::EntityNodeLabel) and DiagramLabel with same name.
Name attribute is used to reference gmfgraph elements from other resources,
so you need always have different names at least for all externally
referenced notions.
Michael
Previous Topic:GeoShapes PaletteContainer
Next Topic:Problems using Node.createStyle(eClass)
Current Time: Tue Jul 22 19:08:41 EDT 2025
Powered by FUDForum. Page generated in 0.04386 seconds
