Missing Autoconf option in org.eclipse.cdt_20020916.zip [message #42403] |
Thu, 19 September 2002 04:57  |
Originally posted by: kc.vinpol.pl
Well I have problem with autoconf
I have eclipse 2.0.1 and cdt plugin org.eclipse.cdt_20020916.zip
I've unzipped it in eclipse directory and now able to create
files,compile and run, but when I right click on project item
there is no such thing like Autoconf. Is this option missing from
this build or plugin is not correct installed ? How can I overcome this
problem ?
Thanks in advance
Krzysztof
Re: Missing Autoconf option in org.eclipse.cdt_20020916.zip [message #42477 is a reply to message #42447] |
Fri, 20 September 2002 12:00  |
Hi all,
Yes, Igor is correct.
There is no current support for autoconf. At this point the developer must
create a makefile in the root directory of their project. This is due to the
default builder calling make. Other implementations of builders will support
more complex and helpful tools such as autoconf.
(I updated the *autoconf* information on the Eclipse Wikki web, yesterday).
I thought that I had found all references to autoconf. Is this documented
elsewhere? If so please let me know and I'll update the required pages.
Tks
-Judy
"Igor Zamyatin" <isz@interstron.ru> wrote in message
news:amep8m$uc1$1@rogue.oti.com...
| There are no Project managment support(such as autoconf, automake) in new
| versions of CDT(since July, I think). But CDT developers planning to do
| this support. Check out CDT mailing lists, plans and materials from CDT
| meeting in July(on main CDT page).
| Igor S. Zamyatin
| Interstron Ltd.
| email: isz@interstron.ru
| tel: +7 (095) 269-4713
| cell: +7 (902) 659-5838
| www: http://www.interstron.ru
| Krzysztof Cieniuch wrote:
| > Hi,
| > problem ?
| > Thanks in advance
| > Krzysztof
FUDForum. Page generated in 0.44359 seconds
