Home » Language IDEs » C / C++ IDE (CDT) » Missing Autoconf option in org.eclipse.cdt_20020916.zip
Missing Autoconf option in org.eclipse.cdt_20020916.zip [message #42403] Thu, 19 September 2002 04:57 Go to next message
Originally posted by: kc.vinpol.pl
Well I have problem with autoconf
I have eclipse 2.0.1 and cdt plugin org.eclipse.cdt_20020916.zip
I've unzipped it in eclipse directory and now able to create
files,compile and run, but when I right click on project item
there is no such thing like Autoconf. Is this option missing from
this build or plugin is not correct installed ? How can I overcome this
problem ?
Thanks in advance
Krzysztof
Re: Missing Autoconf option in org.eclipse.cdt_20020916.zip [message #42447 is a reply to message #42403] Fri, 20 September 2002 05:20 Go to previous messageGo to next message
There are no Project managment support(such as autoconf, automake) in new
versions of CDT(since July, I think). But CDT developers planning to do
this support. Check out CDT mailing lists, plans and materials from CDT
meeting in July(on main CDT page).
Igor S. Zamyatin
Interstron Ltd.
email: isz@interstron.ru
tel: +7 (095) 269-4713
cell: +7 (902) 659-5838
www: http://www.interstron.ru
Krzysztof Cieniuch wrote:
> problem ?
> Thanks in advance
> Krzysztof
Re: Missing Autoconf option in org.eclipse.cdt_20020916.zip [message #42477 is a reply to message #42447] Fri, 20 September 2002 12:00 Go to previous message
Hi all,
Yes, Igor is correct.
There is no current support for autoconf. At this point the developer must
create a makefile in the root directory of their project. This is due to the
default builder calling make. Other implementations of builders will support
more complex and helpful tools such as autoconf.
(I updated the *autoconf* information on the Eclipse Wikki web, yesterday).
I thought that I had found all references to autoconf. Is this documented
elsewhere? If so please let me know and I'll update the required pages.
Tks
-Judy
"Igor Zamyatin" <isz@interstron.ru> wrote in message
news:amep8m$uc1$1@rogue.oti.com...
| Igor S. Zamyatin
| Interstron Ltd.
| > Hi,
| > problem ?
| > Thanks in advance
| > Krzysztof
Previous Topic:Installation help
Next Topic:Launching and debugging question
Current Time: Tue Jul 22 12:55:33 EDT 2025
Powered by FUDForum. Page generated in 0.04084 seconds
