Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP Automatic GUI Recorder
TPTP Automatic GUI Recorder [message #42393] Thu, 24 November 2005 05:54 Go to next message
Iam using the following combination to launch my Auto GUI editor. But i
could not even see the test folder inside my file->others->test
Stable build version :
tptp.test.sdk-TPTP-4.1.0-200509090100.zip
i extract this and replace the Auto GUI plugins with the files and folders
extracted from the below mentioned patch.
Technology Preview version of Automatic GUI:
org.eclipse.tptp.test.auto-TPTP-4.1.0-200511170100B.zip
But still i could not see any improvement, iam not able to see the test
folder created in side the file menu. Please let me know if iam missing
something inbetween.
thanks
UmaShankar.R
Re: TPTP Automatic GUI Recorder [message #42507 is a reply to message #42393] Thu, 24 November 2005 10:11 Go to previous messageGo to next message
The TPTP project is divided into four modules: Platform, Monitoring,
Tracing and Profiling, and Testing. The last three all require the platform
module.
It's perhaps easiest if you would just grab all modules by clicking the
"Runtime" or "SDK" link available beside "All". I would recommend grabbing
the following items from build: TPTP-4.1.0-200511170100B:
1) Under "TPTP Runtime and SDK" download:
All - Runtime
2) Under "Agent Controller" download:
The agent controller for your platform (e.g. Windows-IA32)
3) Under "Technology Preview" download:
Automated GUI Recording
4) Under "Requirements" download:
Everything listed under this section
Thanks for your interest in TPTP,
Ali Mehregani
"UmaShankar" <umashankar@clovissolutions.com> wrote in message
news:c90bca38e0c113b57427176a3b563ddb$1@www.eclipse.org...
> Hi
> thanks
> UmaShankar.R
Re: TPTP Automatic GUI Recorder [message #47637 is a reply to message #42507] Tue, 20 December 2005 08:36 Go to previous message
Thanks for your reply and i can make it working with the help of your
inputs. Now iam facing a different problem.
When i create a new test case for recording and as soon as the recording
starts, iam trying to follow the same example mentioned in the userguide.
I try creating a java project, but when i try to open the new project
dialog box, it hangs. I cannot further procedd clicking on any buttons or
any test editors.
Can u please help me on this? The dialog box by default is working fine as
soon as i terminate the recording.
The image versions used are as following:
- org.eclipse.tptp.test.auto-TPTP-4.2.0-200512011334.zip
- tptp.test.sdk-TPTP-4.2.0-200512011334.zip
- tptp.platform.sdk-TPTP-4.2.0-200512011334.zip
- eclipse-SDK-3.2M3-linux-gtk.tar.gz
- emf-sdo-xsd-SDK-2.2.0M3.zip
- GEF-runtime-3.1.zip
Thanking you in advance
UmaShankar.R
Previous Topic:Realtime Heap Analysis Graph Possible?
Next Topic:RAServer error under Kubuntu
Current Time: Wed May 14 04:30:06 EDT 2025
Powered by FUDForum. Page generated in 0.06729 seconds
