Home » Archived » XML Schema Definition (XSD) » Annotation appinfo troubles
Annotation appinfo troubles [message #42357] |
Tue, 27 April 2004 22:47  |
I am trying to add appinfo to an annotation for an xsd:enumeration (used on
an integer based restricted simple type - let's call it "foo").
If I use createApplicationInformation to create the appinfo on the
enumeration, an element declaration based on the type containing the
enumeration is printed without the type reference:
<xsd:complexType name="tComplex">
<xsd:sequence>
<xsd:element name="baz" type="xsd:string"/>
<xsd:element name="bar"/>
<xsd:element name="ttt"/>
The annotation, appinfo and my custom appinfo child elements are printed
fine together with the simple type containing the enumeration.
If I comment out the code that creates the appinfo, the element declaration
is printed with the proper type:
<xsd:sequence>
<xsd:element name="bar" type="tns:foo"/>
<xsd:element name="ttt" type="xsd:string"/>
I've tried commenting out the code that adds my own custom "any" content
under appinfo. The result is the same.
What is strange is that even elements based on xsd types (for example
xsd:string) are printed without their type as soon as one call to
createApplicationInformation is being made..
Unfortunately, I can't attach the entire code due to dependencies on other
libraries.
I am running version 1.1.0. Any suggestions are appreciated.
Valentin
Re: Annotation appinfo troubles [message #42416 is a reply to message #42357] |
Wed, 28 April 2004 07:45   |
Valentin,
You'll need to show at least some code to get useful help. (Or better yet, a
small example that reproduces the problem.) Calling
createApplicationInformation will do two things; it will ensure that an
underlying DOM exists by calling updateElement, if neccesarry, and then it will
create the node. So unless calling updateElement is causing a problem,
creating the appinfo should have no impact beyond what you do with it after.
Note that the XSDPrototypicalSchema example creates appinfo and it works
okay...
Valentin Baciu wrote:
> <xsd:sequence>
> <xsd:sequence>
> libraries.
> Valentin
Re: Annotation appinfo troubles [message #42469 is a reply to message #42416] |
Wed, 28 April 2004 11:55   |
Thanks for the reply Ed,
I've created a sample class that illustrates the problem. I'm attaching it.
If you have some time to try it, please make sure you run it under 1.1.0.
Valentin
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:408F994D.29B90297@ca.ibm.com...
> Valentin,
a
will
after.
> okay...
> > Hi,
on
> > <xsd:sequence>
declaration
> > <xsd:sequence>
other
> > libraries.
> > Regards,
> > Valentin
Re: Annotation appinfo troubles [message #42664 is a reply to message #42469] |
Wed, 28 April 2004 16:23   |
Valentin,
Thanks for the sample, I really appreciate that! Please open a bugzilla defect
with this sample code. As a workaround, call schema.updateElement at the end and
it should fix things up.
> Valentin
> > Valentin,
> a
> will
> after.
> > okay...
> > > Hi,
> on
> > > <xsd:sequence>
> declaration
> > > <xsd:sequence>
> other
> > > libraries.
> > > Regards,
> > > Valentin
> AnnotationSample.java Type: unspecified type (application/octet-stream)
> Encoding: x-uuencode
Re: Annotation appinfo troubles [message #42819 is a reply to message #42664] |
Thu, 29 April 2004 11:16  |
Done, https://bugs.eclipse.org/bugs/show_bug.cgi?id=60438
The workaround worked ;-)
news:409012C6.D483F563@ca.ibm.com...
> Valentin,
defect
end and
it.
1.1.0.
> > Valentin
> > > Valentin,
yet,
> > a
an
then it
> > will
problem,
> > after.
works
> > > okay...
> > > > Hi,
(used
> > on
> > > > <xsd:sequence>
printed
> > declaration
> > > > <xsd:sequence>
content
example
> > other
> > > > libraries.
> > > > Regards,
> > > > Valentin
Re: Annotation appinfo troubles [message #586131 is a reply to message #42357] |
Valentin,
okay...
> <xsd:sequence>
> <xsd:sequence>
> libraries.
> Valentin
Re: Annotation appinfo troubles [message #586155 is a reply to message #42416] |
Valentin
> Valentin,
a
will
after.
> okay...
> > Hi,
on
> > <xsd:sequence>
declaration
> > <xsd:sequence>
other
> > libraries.
> > Regards,
> > Valentin
Re: Annotation appinfo troubles [message #586254 is a reply to message #42469] |
Valentin,
> Valentin
> > Valentin,
> a
> will
> after.
> > okay...
> > > Hi,
> on
> > > <xsd:sequence>
> declaration
> > > <xsd:sequence>
> other
> > > libraries.
> > > Regards,
> > > Valentin
Re: Annotation appinfo troubles [message #586340 is a reply to message #42664] |
> Valentin,
defect
end and
it.
1.1.0.
> > Valentin
> > > Valentin,
yet,
> > a
an
then it
> > will
problem,
> > after.
works
> > > okay...
> > > > Hi,
(used
> > on
> > > > <xsd:sequence>
printed
> > declaration
> > > > <xsd:sequence>
content
example
> > other
> > > > libraries.
> > > > Regards,
> > > > Valentin
Current Time: Sun Jul 27 06:24:16 EDT 2025
Powered by FUDForum. Page generated in 0.04908 seconds
