Home » Archived » M2M (model-to-model transformation) » [ATL] rules library
[ATL] rules library [message #42363] Mon, 28 May 2007 10:34 Go to next message
Originally posted by: francopinchetti.yahoo.it
hello everybody,
wath I have to do to construct and import a library of ATL rules (if it is
possible)?
thank you very much
franco
Re: [ATL] rules library [message #42457 is a reply to message #42363] Mon, 28 May 2007 10:41 Go to previous messageGo to next message
it is
> possible)?
The module superimposition mechanism lets you import rules from other
ATL modules:
http://wiki.eclipse.org/index.php/ATL_FAQ#What.27s_this_ATL_ feature_called_.22superimposition.22.3F
Frédéric Jouault
Re: [ATL] rules library [message #42596 is a reply to message #42457] Mon, 28 May 2007 11:58 Go to previous messageGo to next message
Thank you, but I don't understand. I'd like to "call" a lazy rule writen in
an external module. What I've to do? I've to use the "uses" keyword?
Thank you
franco
"Fr
Re: [ATL] rules library [message #42713 is a reply to message #42596] Mon, 28 May 2007 12:16 Go to previous messageGo to next message
writen in
You have to add the module containing the rule you want to call in the
list of superimposed module in the launch configuration.
Frédéric Jouault
Re: [ATL] rules library [message #42804 is a reply to message #42713] Tue, 29 May 2007 02:54 Go to previous messageGo to next message
Sorry, but when you say "list of superimposed module" do you mean the libs
list? And what I've to write in the transformation to call the external
rule?
Thanks again
Sorry if I'm boring
franco
"Fr
Re: [ATL] rules library [message #42835 is a reply to message #42804] Tue, 29 May 2007 05:10 Go to previous messageGo to next message
> rule?
> Thanks again
> Sorry if I'm boring
> franco
> "Frédéric Jouault" <frederic.jouault@univ-nantes.fr> ha scritto nel
> messaggio news:f3ev93$9q3$3@build.eclipse.org...
>> Hello,
>> writen in
>> Regards,
>> Frédéric Jouault
No, Frédéric does not mean the libs list. In the Advanced tab of the Run
dialog you can add ATL modules to be loaded on top of the base module.
I've set up a documentation page on Superimposition on the ATL wiki:
http://wiki.eclipse.org/index.php/ATL_Superimposition
I hope that provides a conceptual picture of what Superimposition is.
Dennis
Re: [ATL] rules library [message #42866 is a reply to message #42835] Tue, 29 May 2007 05:26 Go to previous message
thank you very much. I don't have the Advanced tab. I think I've to update
my eclipse version.
thanks again
franco
"Dennis Wagelaar" <dennis.wagelaar@vub.ac.be> ha scritto nel messaggio
news:f3gqma$ukv$1@build.eclipse.org...
> No, Fr
Previous Topic:[ATL] problems with helpers
Next Topic:[ATL] Getting the text of a xml element
Current Time: Sun Jul 27 01:23:12 EDT 2025
Powered by FUDForum. Page generated in 0.03906 seconds
